Manage map image layers
Owners of map image layers who have the privilege to publish server-based layers and organization administrators can manage a layer's configured settings and stop and start the service exposed by the layer.
If your service is published on a federated server secured with web-tier authentication (such as Integrated Windows Authentication (IWA), lightweight directory access protocol (LDAP), or client-certificate authentication), you cannot configure service and layer settings through the portal website. In such cases, you must use ArcGIS Server Manager on the federated server to manage service and layer settings.
Start and stop services
Starting and stopping services are common actions you'll need to perform when administering map image layers. For example, you may stop a service to update its properties and start it for your changes to take effect.
Start a service
Starting a service makes it available for client access. When you start a service, the server initiates the minimum number of instances you specified. As clients request the service, the server returns an available instance. If none are currently available, the server initiates more instances to meet demand until the maximum number of instances is reached. At this point, any new clients that make a request for the service are placed in a queue for the next available instance.
To start a service, follow these steps:
Sign in to an organization as the item owner with publishing privileges or as an administrator.
Open the item page for the layer.
Click the Settings tab and scroll to the Map image layer section.
Click the Start button.
The service you selected in the module starts.
Stop a service
When you stop a service, the server immediately removes all instances of that service from the server. This frees up any machine resources that were dedicated to the service. Clients that were using the service may fail to work properly because the service is no longer available.
To stop a service, follow these steps:
Sign in to the organization as the item owner with publishing privileges or as an administrator.
Click the Stop button, and click the Stop service button in the pop-up window.
The service you selected in the module stops.
Manage map image layer settings
Manage the configuration and parameters of your map image layer.
Manage allowed operations
The Map, Data, and Query operations are enabled for layers by default, and the Map operation is always enabled. To manage whether the Query or Data operations are allowed on your map image layer, complete the following steps:
Click the Settings tab.
Scroll to the Map image layer section and expand the Configuration heading.
Under Operations, the Map, Query, and Data options are turned on by default. These operations are described in the following table:
Map
The Export Map, Generate Renderer, Generate KML, and Query Legends methods can be used. This operation cannot be turned off.
Query
The Identify method can be used.
Data
The Find, Query, and Query Related Records methods can be used.
Turn off the Data and Query toggle buttons to turn off these operations.
Click Save to apply the changes you have made.
Prevent users from changing layer appearance or drawing behavior
You can choose to prevent users from changing the appearance of drawing behavior of the web layer. For example, users will not be able to change symbology, labeling, or the order of component layers. To do so, complete the following steps:
Under Dynamic workspace, turn off the Allow per request modification of layer order and symbology toggle button.
Disabling this option prevents users from changing the appearance or drawing behavior of the web layer. For example, users cannot change symbology, labeling, or the order of component layers.
Enable dynamic layers
If you want to dynamically add data to your map image layer, you must set up a workspace to contain the data you want to add. Dynamic workspaces can be any supported database, enterprise geodatabase, file geodatabase, or file directory on disk that is accessible to the ArcGIS Server site that the map service powering your map image layer was published to. For more information, see Dynamic workspaces.
To enable dynamic layers on your map image layer, complete the following steps:
Under Configured dynamic workspaces, ensure that the Allow per request modification of layer order and symbology toggle button is turned on.
Under Configure dynamic workspaces, click Add.
Select the dynamic workspace type from the Workspace type drop-down menu.
Specify a workspace ID.
When a client requests to add a layer in an application, the ID is included in the request. This is used to identify the workspace from the pool of available workspaces. The ID can be any string of characters and contain spaces.
Specify the path to the workspace. This varies depending on the type of workspace you selected:
Enterprise Database—Choose the database connection you want to use by clicking Your device and browsing to the file. Alternatively, drag the file on to the window from a file browser on your local machine. You can optionally lock the database version that users can access. To do so, check the Lock version box.
File Geodatabase—Specify the path to the file geodatabase you want to use. Keep in mind that you'll need to add feature classes or tables to that file geodatabase at a later time.
Raster Folder—Specify the path to the folder that contains the rasters you want to use.
Shapefile Folder—Specify the path to the folder the contains the shapefiles or dBASE files you want to use.
Layers Folder—Specify the path to the folder that contains the layers you want to use.
The Layers Folder workspace is only available for map image layers shared from ArcGIS Pro. As such, only layer files from ArcGIS Pro (
.lyrx) are supported for use in this workspace type.Click Add to add the workspace.
Choose how the map image layer will be drawn
To choose whether the map image layer will be drawn dynamically from data or by using tiles from cache, complete the following steps:
Under Layer drawing, choose how the map image layer will be drawn:
Dynamically from data
Data is retrieved and drawn each time it is requested. This is the default option.
Use tiles from cache
Data is drawn from cached images generated at map scales you define.
For more information, see Map caching.
If you use tiles from cache, additional settings may become available.
Optionally, under Visible range, use the slider to set the map scales for which tiles are generated.
A default scale range is provided. Depending on the purpose of your map and the estimated cache size, you may choose not to cache very large or small scales.
Under Tiling scheme, review the settings determined when you published the service. These settings cannot be modified from the layer's item page.
Set your tiling scheme—The tiling scheme determines the scale levels, tile dimensions, and tile origin of the cache.
Image format—If all sublayers in the web layer have vector data sources, the default setting is PNG. If one or more sublayers has a raster data source, the default setting is MIXED.
Compression—Compression is available only if the format is JPEG or MIXED. PNG formats are not compressed. You can use values between 0 and 100. Higher values result in larger file sizes with higher-quality imagery. Lower values result in smaller file sizes with lower-quality imagery. The default value is 75.
Under Tiles, expand the Tile details heading.
Review the current tile range defined on the layer and the tile status.
Optionally, check the Allow this layer to be downloaded and used in offline mode box.
If you have enabled the layer to be downloaded and used in offline mode, optionally set a limit to the tiles that can be exported.
Optionally, check the Create tiles on demand box.
Not checked
Tiles are built only through caching, either automatically or manually. This is the default.
Checked
Tiles that are not cached are created on demand (that is, when a client application requests them). This occurs mainly in the following situations:
Tiles are cached automatically on the server, and you specified an area of interest for the cache extent. In this case, tiles are cached only for the area of interest. Tiles are created on demand for the rest of the map extent.
You cache tiles manually on the server. In this case, tiles are cached for the scales selected in the Manage Map Server Cache Tiles tool. Tiles are created on demand for scales that are not selected.
Specify the maximum records returned by user queries
To specify a value for the maximum records returned by a user query, complete the following steps:
Sign in to the organization as the item owner with publishing privileges.
Scroll to the Map image layer section and expand the Parameters heading.
Under Properties, specify a value for Maximum records returned by server.
This setting determines the maximum number of records returned by a user query. A large number may result in slower performance. The default value is 2,000.
Manage advanced options
To manage advanced options for your map image layer, complete the following steps:
Expand the Advanced heading to set the following parameters:
Enter a value in the Maximum number of coded domains box to specify the maximum number of domain codes returned from fields, subtypes, layers, and tables. The default value is 25,000.
Specify values in the Maximum image height and Maximum image width boxes. These values represent the maximum height and width in pixels of images the map service can export. The default for both values is 4,096.
Enter a value in the Maximum sample size box to specify the maximum number of records that is sampled when a class breaks renderer is computed. The default value is 100,000.
Enter a value in the Maximum selection count box to specify the maximum number of features that can be highlighted in an export request. The default value is 2,000.
Enter a value in the Maximum unique ID count box to specify the maximum number of unique identifiers that can be returned in a single query. The default value is 10,000.
Optionally, disable schema locking.
The Enable schema locking option is turned on by default to prevent modifications to datasets that are used by reference in the map image layer.
Optionally, enable identify relates.
The Enable identify relates option is turned off by default. When enabled, information from related tables is returned when a feature is identified. If disabled, information from related tables is not returned.
Specify the time zone of the data
If your map image layer contains date fields, you can specify the time zone of the data. If you don't specify a time zone, the dates are assumed to be stored in UTC. Complete the following steps:
Under Date fields, click the Time zone of the data drop-down menu and choose the time zone in which your date values are stored.
Specifying the time zone in which the dates are recorded allows date and time values to be converted correctly when users interact with the map image layer.
If you choose Unknown, date and time values will not be converted. Choose this option if your date fields do not have a known time zone or if multiple time zones are represented in the data. Unknown time zones do not apply to editor tracking date fields. Editor tracking date fields in UTC will remain in UTC even when the service's time is set to unknown.
- If you choose a time zone other than None (Assumed UTC) or Unknown and you want the time zone to account for daylight saving time, check the Values are adjusted for daylight savings box.
If you chose a time zone other than None (Assumed UTC) or Unknown, optionally click the Preferred time zone drop-down arrow and choose a time zone to use when displaying queries from the map image layer.
If you don't specify a time zone, date fields will be displayed in UTC.
- If you choose a preferred time zone other than None (Assumed UTC) or Unknown and you want the preferred time zone to account for daylight saving time, check the Values are adjusted for daylight savings box.
Manage anti-aliasing settings
With the anti-aliasing mode option, you can make the jagged edges in your map look smooth. With the text anti-aliasing mode option, you can control how text is smoothed or rendered. To control these options, complete the following steps:
Under Anti-aliasing settings, click the Anti-aliasing drop-down arrow and choose the anti-aliasing mode.
None
No anti-aliasing is performed.
Fastest
Minimal anti-aliasing is performed, optimized for speed.
Fast
Some anti-aliasing is performed, optimized for speed, with better quality than to be achieved with Fastest. This is the default.
Normal
A good balance for speed and quality.
Best
The best quality for anti-aliasing. This option takes the longest to render.
Click the Text anti-aliasing drop-down arrow and choose an anti-aliasing text option.
None
No text anti-aliasing is performed.
Normal
Text anti-aliasing is performed as determined by the font type. Each font has parameters created by the font author that define at which sizes the font should be drawn for anti-aliasing.
Force
Text is always drawn with anti-aliasing, regardless of font parameters. This is the default and recommended setting.
Additional layers and capabilities
The following additional settings may be available for the map image layer:
If server object extensions (SOEs) or server object interceptors (SOIs) have been added to your organization, you can enable the extensions on map image layers from the item page. To learn more, see Enable service extensions.
If you created a data snapshot when you published a map image layer from cloud data warehouse data in ArcGIS Pro, you can update the snapshot after the source data changes. See Refresh data for snapshot layers for instructions.
When publishing map image layers from most data sources, you can enable WCS and KML to provide the layer with additional capabilities. You can manage these properties from the item page of map image layers that have WCS or KML enabled. To learn more, see the following:
You can also enable WMS and WFS as additional layers on some map image layers. To learn more, see the following:
WCS and KML capabilities and WMS and WFS layers are not available for map image layers published from cloud data warehouse data.
