Use ArcGIS Pro with ArcGIS Enterprise
ArcGIS Enterprise and ArcGIS Pro can be used together for sharing maps, layers, and packages.
  • You can add data from ArcGIS Enterprise to ArcGIS Pro.
  • You can publish feature, tile, and scene layers, web maps, web scenes to ArcGIS Enterprise from ArcGIS Pro.
  • You can publish a layer from ArcGIS Pro to a federated ArcGIS Server site to share it automatically to your ArcGIS Enterprise organization.
Use ArcGIS Pro with your ArcGIS Enterprise organization
An ArcGIS Enterprise organization is accessed as a portal in ArcGIS Pro. Add the portal, set it as the active portal, and sign in to it.
Once you sign in to the active portal, you can share the following with it:
Add a portal to ArcGIS Pro and make it active
ArcGIS Pro connects to ArcGIS Online by default. To connect to your ArcGIS Enterprise organization, add the portal's URL.
  1. Click the Project tab and click Portals.
    You can also access the Project tab from the Manage Portals link on the log-in menu.
  2. Click Add Portal.
  3. Provide the portal URL on the Add Portal dialog box and click OK.
    The URL's format is https://webadapter.example.com/arcgis.
    If your portal uses public key infrastructure (PKI)-based client certificate authentication, a prompt appears.
  4. Do one of the following:
    1. Choose a certificate when prompted and click OK.
    2. Provide your four-digit personal identification number (PIN) when prompted and click OK.
  5. To make the new portal connection the active portal, right-click the URL and click Set As Active Portal.
Sign in to the portal
If your ArcGIS Enterprise organization uses built-in accounts, sign in to your portal. If the organization use Integrated Windows Authentication (IWA), you are signed in automatically. If the organization uses client certificate authentication, you are already signed in because you specified your certificate and PIN when adding the portal to ArcGIS Pro.
  1. Right-click the active portal's URL and click Sign in.
  2. Type your portal username and password, and click Sign In.
Share packages
You can share basemap, layer, map, and project packages from ArcGIS Pro with your organization so others can download and use them. See Introduction to sharing packages in the ArcGIS Pro help for more information.
Share link charts
You can create and share link charts from ArcGIS Pro with your organization so others can use them in ArcGIS Knowledge Studio projects. See Share a web link chart in the ArcGIS Pro help for more information.
Share web maps and scenes
You can create maps and scenes in your project in ArcGIS Pro to convey information, tell a story, or answer questions. You can share these maps and scenes with your organization so that others can download them. When you share maps and scenes, the layers they contain also publish to your organization.
To share a map, add layers to a map in ArcGIS Pro and click Share As Web Map on the Share tab to get started.
To share a scene, add 3D layers to a scene in ArcGIS Pro, as well as other reference layers, and click Share As Web Scene on the Share tab to get started.
See Share a web scene in the ArcGIS Pro help for complete instructions.
Share tile or feature layers
You can publish feature or tile layers from ArcGIS Pro to your ArcGIS Enterprise organization. Add layers to a map in a project and click Share As Web Layer on the Share tab to get started.
See Introduction to sharing web layers in the ArcGIS Pro help for complete instructions.
Tip:
To publish all the layers in a map at once, you can share a web map, as mentioned in the previous section.
Share scene layers
To publish hosted scene layers from ArcGIS Pro to your ArcGIS Enterprise organization. Add 3D layers to a scene in ArcGIS Pro, right-click the layer in the Contents pane, and click Share As Web Layer to get started.
See Share a web scene layer in the ArcGIS Pro help for complete instructions.
