Attribute field use and management
Each layer in a hosted feature layer contains an attribute table that stores the data for the layer. Each table contains rows (features) and columns (fields). How you interact with the attribute table of a hosted feature layer depends on your role in the organization and the layer's configuration. Most users can view the layers and use them in their maps and apps, but only the layer owner or an administrator can manage attribute fields.
View and interact with attributes
Anyone who is not the layer owner or an administrator in the organization can only interact with the attribute table's contents. If the hosted feature layer or hosted table has been shared with you, you can do the following with the attribute table's contents:
  • View the table's contents, related records and photos, and statistics. See Show tables for more information.
  • If the layer owner has enabled editing, you can update the contents of the attribute table. If the layer owner has enabled attachments, you can attach related photos or other files to specific features.
  • If the layer owner has configured descriptions for the fields, you can see those descriptions on the layer's item page. Open the item page for the hosted feature layer or hosted table and click the Data tab to access field descriptions.
Manage attribute fields
If you own the layer or are an administrator of the organization, you can view and edit data in the attribute table, and you can perform the following field management operations from the Data tab of the layer's item page:
Members of shared update groups can also perform some of these operations.
Layer owners and organization administrators can add fields to, delete fields from, and calculate field values for hosted feature layers in Map Viewer as well.
