View and configure layer details
The Layer Details page provides information and management options for analysis layers in ArcGIS Excalibur. Depending on the layer type, you can view layer metadata, update item information, access service endpoints, and manage layer-specific settings.
To open the Layer Details page, complete the following:
  1. From the Analysis Layers page, click on the layer you would like to view the details of.
  2. In the Layer Information flyout panel, click the drop-down arrow next to View in Canvas and select More Details to view more information about this layer.
The Layer Details page opens for the selected layer.
An Item Details section is available to view specific details about the layer item. You can also click Preview at the top of the page to view a preview of the current layer or click View in Canvas to open the layer in the canvas.
View and Update Layer Information
Most layer types include an Overview page where you can view and update item information as the layer owner or an administrator.
As the layer owner or administrator, you can update:
  • Summary
  • Thumbnail
  • Description
  • Sharing level
  • Tags
To update layer information as the item owner or an administrator:
  1. Open the Layer Details page.
  2. Locate the item information you want to edit.
  3. Click Edit .
  4. Make your changes.
  5. Click Save.
Your changes are saved to the layer item.
View Layer Metadata
The Layer Metadata section provides information about a layer and its associated service.
Depending on the layer type, metadata may include:
  • Capabilities
  • Key Properties
  • Statistics
To view the metadata of a layer:
  2. Scroll to the Layer Metadata section.
  3. Expand a metadata category to view additional information.
  4. Additionally, click View All to open the rest endpoint for the service to view more metadata for the layer.
Work with ArcGIS Imagery Layers
ArcGIS Imagery Layers provide access to imagery-specific metadata and layer management settings.
In addition to viewing item information and metadata, as a layer owner or admin you can:
  • Rename the layer.
  • Enable and disable delete protection.
  • Delete the layer.
Rename the layer
To rename an imagery layer:
  2. Click the Settings tab.
  3. Update the layer name.
  4. Click Save.
The layer name is updated.
Delete the layer
To delete an imagery layer:
  3. Click Delete .
  4. Confirm the deletion.
The layer is permanently removed.
Work with Feature Layers
Feature Layers provide additional configuration options for managing observations, fields, and layer appearance. These options can be modified if you are the layer owner or are an administrator.
Feature Layers can contain one or more sublayers.
Manage layer settings
Service-level settings may include:
  • Layer name
  • Editing
  • Editor Tracking
  • Deletion Prevention
To update Feature Layer service-level settings:
  2. Ensure you are on the page for the top-most layer in layer selector at the top of the page.
  3. Click the Settings tab.
  4. Modify the desired settings.
    • If you disable Editing on a feature layer, users can still view and query the layer, but they can no longer make edits through the feature service. This means they cannot add features, update existing features, delete features, edit attributes, or edit geometry. Layer owners and administrators will still be able to make edits.
    • If you disable Editor Tracking on a feature layer, the account information for the person who creates or edits a feature in the feature layer along with the date and time the edit was made will no longer be recorded.
  5. Click Save.
Layer-level settings may include:
  • Layer name
  • Attachments
  • Time
To update Feature Layer layer-level settings:
  2. Use the layer selector at the top of the page to select a sublayer or click a layer in the Layers section in the Overview page.
    • Disabling attachments removes all existing attachments from the layer and prevents users from adding more attachments.
    • Disabling Time turns off the layer's temporal behavior and causes all records to be displayed without time-based filtering.
  5. Click Save.
Customize layer styling
You can configure the appearance of feature layers through the Style tab if you own the layer or are an administrator.
To update layer styling:
  3. Click the Style tab.
  4. Click Edit .
  5. Change the layer styling using the available styling options. Learn more about styling feature layers.
  6. Click Save to save the styling changes to the layer.
Create or update fields
You can add and update fields for feature layers through the Fields tab if you own the layer or are an administrator.
The Fields tab contains the following sections:
  • Layer Fields—These fields are editable attribute fields that store information about each observation and define what users can view, enter, or edit when collecting observations.
  • System-Managed Fields—This consists of the following:
    • Excalibur Fields—These fields are managed by the application. They automatically populate values from metadata in the source analysis layer when an observation is collected.
    • Editor Tracking Fields—These fields automatically record who created or updated an observation, along with the data and time of those changes. Editor tracking must be enabled on the feature layer to capture this information.
Create a new Layer Field
To create a new Layer Field:
  3. Click the Fields tab.
  4. Click Create in the Layer Fields section.
  5. Define the required field properties. See the table below for more information on each of these inputs.
  6. Choose if this field requires a value or if it should be optional by checking or unchecking the Required Field option.
  7. Optionally, define a Domain Type (domain of coded values or range) option for the new field by selecting Coded Values or Range. A Range domain cannot be made for a new field of type String.
  8. If you selected a domain of coded values, enter a value for the Name and Code parameters for each domain in your pick list, ensuring you add each domain to the list by clicking Add .
  9. Click Save.
The field is added to the layer.
See the table below for specific information on each input for the new field:
Property Description Required Requirements and Restrictions Editable After Creation
Field Name The internal name used to store the field. Yes Must begin with a letter. Can contain only letters, numbers, and underscores (_). Maximum length is 63 characters. Must be unique. No
Display Name The label displayed to users throughout the application. No Duplicate values are allowed. Special characters are supported. Yes
Description A description of the field and its intended purpose. Yes Maximum length is 500 characters. Cannot contain < or > characters. Yes
Type Defines the field category. See table below for supported types. Yes Selected when the field is created and cannot be changed later. No
Value Type Defines the type of data accepted by the field. Yes Determines the data that can be stored in the field. Yes
Mapped Source Fields Source field names that map incoming data to the observation field. At least one At least one mapped source field is required. Duplicate source fields are not allowed. Source field names must follow the same naming rules as Field Name. Yes
See the table below for more information on the Data Types supported:
Data Type Description
String Any sequence of characters.
Double Numbers with decimal places.
Integer Whole numbers from -2,147,483,648 to 2,147,483,647 (long integer).
Big Integer Whole numbers from -9,007,199,254,740,991 to 9,007,199,254,740,991. Use this type when you need to store numbers that do not fit within the range of the Integer data type.
Date Stores both date and time values. For more information, see Date and time fields in ArcGIS Enterprise.
Date Only Stores a date but no time value. This is useful when time is not needed, such as recording the day a permit expires or a customer's birth date.
Time Only Stores a time but no date value. Time is stored in 24-hour format, such as 16:30 for 4:30 PM. This field type is useful for recording values such as business hours and bus schedules.
Edit an existing Layer Field
You can update certain properties of an existing layer field as requirements evolve.
To edit a Layer Field:
  1. Click Edit Field button on the layer you would like to edit.
  2. Update the field properties as needed. The Field Name, Type, Required Field, and Domain Type inputs cannot be edited after initial creation.
  3. Click Save.
Changes are immediately reflected in the field configuration.
Delete a Layer Field
If a Layer Field is no longer needed, it can be removed from the configuration.
To delete a field:
  1. Click Delete Field on the layer you no longer want.
  2. Review the confirmation message.
  3. Click Delete.
The field is permanently removed from the Observation Fields configuration.
Update system-managed fields
Excalibur Fields are system-provided fields that support observation and imagery analysis workflows. You can determine which Excalibur Fields are available during collection with a feature layer.
The provided Excalibur Fields are:
  • Name
  • Layer Type
  • Sublayer ID
  • Portal Item ID
  • Image ID
  • Service URL
  • Project ID
  • Observation Collection Time (Local)
  • Image Collection Time (UTC)
  • Video Time
  • Observation Lat Lon
  • Native XY Coordinates
  • Collection Map Scale
  • Security Classification
  • Predicted NIIRS
  • Sensor Name
Additional fields are included if they were created by an administrator within the App Level Configuration Settings.
To manage these Excalibur Fields:
  1. Click Modify Selection in the System-Managed Fields section.
  2. Enable or disable the desired fields by clicking the checkbox next to a specific field under the Excalibur Fields section.
  3. Click Save.
Your selections are saved and applied to future observation layer configurations.
Customize Excalibur Field Properties
Excalibur Fields support additional customization options.
For Excalibur Fields, you can:
  • Update the display name. (Available for all fields)
  • Update the field description. (Available for the Name, Image Collection Time (UTC), Security Classification, Predicted NIIRS, and Sensor Name fields)
Mapped source fields cannot be edited, but administrator-added mappings can be modified or deleted in the App Level Configuration Settings.
To edit an Excalibur Field:
  1. Select the field.
  2. Click Edit Field .
  3. Update the field properties as needed.
  4. Click Save.
Configure Editor Tracking Fields
Editor Tracking fields store information about feature creation and editing activity.
These fields are automatically maintained by the system and cannot be added, removed, or reconfigured beyond their display names.
To update an Editor Tracking field:
  1. Open the field.
  2. Select Edit Field .
  3. Update the display name.
  4. Click Save.
Work with Oriented Imagery Layers
Oriented Imagery Layers contain a parent layer and related sublayers. Available sublayers may include an Oriented Imagery layer and a Footprint layer.
Use the layer selector at the top of the page to move between the parent layer and available sublayers.
To view sublayer information:
  3. Review the available information and metadata.
Update sublayer description
Each layer and sublayer contains its own metadata and endpoint information.
To update a sublayer description:
  1. Select a sublayer.
  2. Edit the description.
  3. Click Save.
Work with On-Demand Video Layers
On-Demand Video Layers provide access to video-specific metadata and layer management settings to allow you to manage video services and individual stream settings.
In addition to viewing item information and metadata, you can do the following:
  • Rename the layer.
  • Enable or disable deletion protection.
  • Delete the layer.
Rename the layer
To rename a video layer:
  4. Update the layer name.
  5. Click Save.
Delete the layer
To delete a video layer:
  4. Click Delete .
  5. Confirm the deletion.
Update settings
Individual stream-level settings may include:
  • Export Clip
  • Frames
  • Thumbnail Previews
To update these stream-level settings:
  2. Use the layer selector at the top of the page to select a substream or click a stream in the Streams section in the Overview page.
    • Disabling Export Clip will prevent the use of the Video Clip tool in the Canvas.
    • Disabling Frames will prevent the use of the Video Frame tool in the Canvas.
    • Disabling Thumbnail Previews will remove the previews that appear when a viewer hovers their cursor over the video progress bar.
  5. Click Save.
Work with Livestream Video Layers
Livestream video layers provide additional controls for managing active video streams.
  • Rename the layer.
  • Start or Stop all streams in the service.
  • Delete the layer.
Rename a video layer
  5. Click Save.
Start or stop all streams
To start or stop all streams:
  4. Choose to Start All or Stop All streams.
  5. Confirm the action in the dialog.
All streams in the service will start or stop based on the option you chose.
Delete a video layer
  4. Click Delete .
Individual stream settings
  • Rename the stream.
  • Start and Stop the stream.
  • Convert the stream to an on-demand video layer.
To update these stream-level settings, complete the following.
Rename a video stream
To rename an individual stream:
  4. Update the stream name.
  5. Click Save.
The name is updated.
Start or stop a video stream
To start or stop the stream:
  4. Choose to Start Stream or Stop Stream.
The stream will either be started or stopped based on which option you chose to do.
Convert a stream
To convert the stream to an on-demand video layer:
  4. Ensure the stream is stopped.
  5. Click the Convert button and choose to convert the stream to a new on-demand video layer or to convert the stream and move it to an existing video layer. You are required to update the stream name when converting it.
Update the Poster for a video layer
Video layer streams will have an additional Poster section where item owners can add a new poster to be used for the video layer. A poster is a placeholder image that displays before media plays and will be the still frame you see on a video player before it starts.
The poster image must be a .jpg, .jpeg, or .png and must be less than 2MB in size.
To update the poster, follow these steps:
  3. Click Edit in the a Poster section in the Overview page.
  4. Upload an image to be used as the poster.
  5. Click Save.
Work with other Layer Types
Map Image Layers, Tile Layers, Tiled Imagery Layers, WCS layers, WMS layers, and WMTS layers use a simplified Layer Details experience.
For these layer types, you can:
  • View and update item information.
  • Review layer metadata.
  • Access service endpoint information.
No additional settings, fields, or styling options are available at this time.
