Access the more menu
The More
menu contains additional options for your project. This menu is only available when you are in a project.
View project instructions
All ArcGIS Excalibur projects are required to have project instructions, which are directions to help guide a user through a task. The project instructions are defined when the project is created and can be viewed at any time while a project is open, including any supporting materials.
To view the project instructions, do the following:
In an open project, click More
.Click Instructions
.The Instructions panel dynamically loads the project instructions, including any optional supporting materials.
Edit project instructions
When working on a project as the project owner or if you are signed in with an account that has administrator privileges, the project instructions can be edited from the Instructions tool.
To modify the project instructions, do the following:
.Click Instructions
Click Edit
.A text editor opens and the instructions may be modified.
Click Update to save modifications. Alternatively, click Cancel to close without saving changes.
Instructions are modified for the project details.
View Excalibur project details
You can learn more about your Excalibur project by accessing the project details. The Project Details page is where you can view important information and details about the Excalibur project. You can also add additional capabilities to an Excalibur project on the Project Details page.
To view the Project Details page:
in the top right of the screen.Click Project Details
To learn more about the Project Details page, see Project Details.
