Use the Project Details page
The Project Details page is where you can view important information and details about the Excalibur project. You can access the page from the Excalibur projects list by clicking View Details for the desired Excalibur project. If you are the owner of the project or have administrative privileges, you can edit information about the Excalibur project.
Excalibur projects created before ArcGIS Excalibur 4.0 must be upgraded for users to access them. When the project owner or an administrator opens the project it will be automatically upgraded and can be accessed by users for collaboration based on its sharing properties.
Project information
Once you access the project detail page, you will be brought to the About page, where you can see and edit the following:
  • Project Title
  • Project Thumbnail
  • Project Summary
  • Project Description
  • Tags
  • Sharing
Edit the project information
If you are the project owner or have administrator privileges, you can make edits to the project's information. To edit project details, complete the following steps:
  1. From the side-navigation bar in the app, click Excalibur Projects to open the list of projects.
  2. Click View Details on the desired project card.
  3. On the About tab, click Edit in the Project Information section.
  4. Edit or remove the thumbnail or the text for the project information fields.
  5. Click Save to update the changes or click Cancel to disregard any changes.
  6. Click Edit in the Tags section and add or remove any tags. Optionally, add tags from My Saved Tags.
  7. Click Save to update the changes or click Cancel to disregard any changes.
  8. Click Edit in the Sharing section. Choose to share the project with your organization, make it public, or keep it private. Optionally, share the project with any portal groups available in your organization.
  9. Click Save to update the changes or click Cancel to disregard any changes.
View the Analysis Layers in the project
On the Project Details page, you can view information about the analysis layers that are being used within the project.
To view the analysis layers, complete the following steps:
  3. Click the Analysis Layers tab.
Here you can view the analysis layers that are added to the project. Each layer card will give you the options to View Details, Preview Layer, and Remove Layer.
Layers set as the basemap in the project can not be removed.
You can add more layers to the project by clicking Add Analysis Layers , selecting the layers you want to add, then clicking Save .
View and edit project instructions
All ArcGIS Excalibur projects are required to have project instructions, which are directions to help guide a user through a task. The project instructions are defined when the project is created and can be viewed at any time while a project is open, including any supporting materials or Workflows items added from Workflow Manager.
You must be the project owner to edit the project instructions. If you are not the owner you can only view the project instructions.
To view or edit the project instructions in the Project Details, complete the following:
  3. Click Instructions.
  4. Review the Project Instructions, Projects Resources and References, and Workflow Manager itmes for this project.
    The Workflow Manager section will only appear if the environment is federated with an ArcGIS Workflow Manager Server.
  5. If you want to make changes to the Project Instructions, click Edit .
  6. Use the text editor to provide instructions, create a list of tasks, or remove any unwanted text.
Add new instructional resources and references
Instructional resources and references provide additional materials for an Excalibur project, including Microsoft Word documents, Microsoft Excel spreadsheets, images, PDFs, and Microsoft PowerPoint presentations. Users can view or download resources they have permission to access. Private or group-shared items are only visible to users with access. Only project owners and administrators can add or remove resources and references.
To add new resources and references in a project, complete the following steps:
  3. Click the Instructions tab.
  4. Click Upload File .
  5. Choose a supporting file in the source file input.
  6. Enter the following:
    • Title (required)
    • Folder name
    • Tags
    • Sharing level or groups to share it to
  7. Click Create Item to upload the file.
The file shows in the list of the Project Resources and References. You can click Options to Open, View Details, or Remove the file.
Add existing instructional resources and references
To add existing resources and references in a project, complete the following steps:
  4. Click Add Existing Items .
  5. Select the existing items you want to add to your project.
  6. Click Save to add the items.
Add a Workflow item from Workflow Manager
With ArcGIS Workflow Manager integration in ArcGIS Excalibur, organizations can connect workflow-driven business processes with the imagery and video analysis activities performed in Excalibur. For example, a Workflow Manager job may assign an analyst to review imagery, conduct damage assessments, perform feature extraction, or complete an inspection-based workflow as part of a larger organizational process. By associating Workflow Manager jobs with Excalibur projects, analysts can access their assigned work and complete project tasks without leaving their operational environment.
Workflow Manager jobs are available through the Workflow Jobs tab in the project instructions, where analysts can view job details, monitor progress, and perform Workflow actions such as starting jobs, pausing work, placing jobs on hold, releasing holds, and completing workflow steps.
As Workflow actions are performed in Excalibur, updates are automatically synchronized with Workflow Manager, ensuring job status and progress remain current across both applications. This integration streamlines the transition between work assignment and task execution, improves visibility into project progress, and helps organizations maintain consistency with established workflows and business processes.
To interact with Workflow Manager within ArcGIS Excalibur project instructions, a Workflow item needs to be added to an Excalibur project first.
Before you begin, ensure these perquisites have been met:
  • Your environment is federated with an ArcGIS Workflow Manager Server.
  • Your account is licensed to use Workflow Manager.
  • A Workflow Item has been created and a table has been created with an extended property in ArcGIS Workflow Manager. When creating the table, ensure the following is used for the Name and Alias fields:
    • In the Name and Alias inputs for the Table, type excalibur_project for Name and Excalibur Project for the Alias. All remaining values should not be changed.
    • In the Name and Alias inputs for the Extended Property, type project_id for the Name and Project ID for the Alias. All remaining values should not be changed.
Once these requirements have been met, complete the following to add a Workflow item to a project:
  4. Click Select Workflow Item in the Workflow Manager section.
  5. Choose the existing items you want to add to your project.
  6. Click Next.
  7. Review the available jobs that appear. If multiple job templates are utilizing the same extended property table, you may see jobs appearing from multiple job templates.
  8. Choose one or more jobs to include in the project.
  9. Click Add.
The chosen Workflow item and jobs are added to the Workflow Manager section of the Project Instructions.
Update or remove associated Workflow jobs
After adding a Workflow item to your project instructions, you can add or remove jobs without removing the entire Workflow item.
To remove jobs, complete the following:
  1. From the side navigation bar in the app, click Excalibur Projects to open the list of projects.
  4. Click More next to the Workflow name.
  5. Select Add or Remove Jobs.
  6. Update the job selection by selecting new jobs or deselecting previously selected jobs.
  7. Click Save.
The Workflow Manager section updates to reflect the updated set of jobs.
Remove a Worfklow item from the instructions
If a Workflow item is no longer needed for an Excalibur project, the Workflow item can be removed.
To remove a Workflow item, complete the following:
  5. Select Remove Workflow.
A confirmation dialog opens.
  1. Click Remove.
The Workflow item and all associated jobs are removed from the Excalibur project.
Change the project web map
When an Excalibur project is created, a web map is also created and set as the project web map. However, you can change the project web map at any time in the project details.
  3. Click the Web Map tab.
  4. Click Select Existing Map .
  5. Choose a web map and click Save .
    A dialog box appears, notifying you that changing the project web map will update all the current layers in the project, including any observation layers or GeoEnrichment definitions.
    • If you selected a web map that you own, you have the choice to replace the current project web map with the web map you selected, or create a copy of the web map you have selected and use this copy as the project web map instead.
    • If you selected a web map that you do not own, you will only have the option to enter a Web Map Title. This will create a copy of the web map you have selected and will use this copy as the project web map.
    The new web map appears in the preview. You can use the widgets in the preview to zoom in and out, look at the context layers in the project, and view the legend. You can also change the web map again using the same process.
Optionally, you can also create a new web map or save a copy of the current web map by clicking the drop-down menu next to Select Existing Map and using the Create New or Save As options. This is helpful if you do not own the project web map and want to have your own web map so you can make edits to it.
Once you create a new web map or save a copy of the current web map, this will be saved in your project folder in your portal content and will replace the current project web map. This may affect observation layers and GeoEnrichment definitions within the project.
Add an observation layer to the Excalibur project
Adding observation layers to a project provides a workflow for collecting observations from imagery or video, including resources for accomplishing observations, editing, and creating derived information products from these activities. These layers provide observation tools in the Tools Panel when you open an Excalibur project. An observation layer can be a feature layer or an ArcGIS Knowledge graph entity layer. Feature layers in your project web map or feature layers added through the Add Layer menu are automatically added as observation layers in your project if the layer has editing capabilities enabled.
License:
ArcGIS Knowledge graph layers are only supported in ArcGIS Enterprise.
ArcGIS Knowledge graph layers must be spatial entities. Nonspatial entities and relationships are not supported. Additional capabilities not supported for knowledge graph spatial entity layers include the following:
  • Collecting observations in the Focus Panel
  • Integration with the Time Slider and Feature Table
Choose an existing observation layer
To add an existing observation layer, complete the following steps:
  3. Click the Observation Layers tab.
  4. Click Add Existing .
  5. Select one or more observation layers and click Save .
The new layer appears on the Observation Layers tab and is available to use in your project and in the observation tools.
Create an observation layer
To publish a new observation layer, complete the following steps:
  4. Click Create New .
  5. Provide information for the following details:
    • Type a Layer Name.
    • Define the layer's geometry type by choosing Point, Polygon, or Line.
  6. Choose to add the Excalibur Calculated Fields, Analyst Comments Field, or Observation Certainty Field values to the layer.
    You can edit additional layer information, add and remove fields, edit the layer styling, and edit specific layer settings after the layer is published.
  7. Click Create Layer.
Configure an observation layer
After creating an observation layer, the Layer Details page opens. Here you can view additional information and configure fields, styling, and other layer settings. Learn more about configuring an observation layer.
Configure the project to use deep learning
Deep learning models can be added to your project that can then be used with the Deep Learning tool in the project canvas. Deep learning is available when the project contains an ArcGIS imagery layer, ArcGIS tiled imagery layer, or ArcGIS tile layer. See the requirements for more information on using deep learning in ArcGIS Excalibur.
See Use deep learning models to learn more.
Enhance an Excalibur project with GeoEnrichment definitions
Adding a GeoEnrichment definition to the project helps enhance your observations with information from a related layer to help automate the observation collection workflow. You can choose which fields are automatically populated in the point or polygon observation layer by matching them to fields in one or more related polygon context layers. When an observation is collected within or intersects the selected polygon layer, attributes from that layer will automatically populate in the observation layer.
To create a GeoEnrichment definition in an Excalibur project, you must be the project owner or a portal administrator. You also must have a point or polygon observation layer in the Excalibur project and an additional polygon layer in a web map that has been added to the project. Only one GeoEnrichment definition can be made per observation layer, but each observation layer can have multiple context layers as a part of its definition helping to automate the process of relating an observation to one or more contextual layers in the project.
Create a GeoEnrichment definition in an Excalibur project
To create a GeoEnrichment definition in a project, complete the following steps:
  3. Click the GeoEnrichment tab.
    A message appears if the project does not meet the requirements to create a GeoEnrichment definition.
  4. Click New Definition .
  5. Select a point or polygon observation layer as the observation layer from the drop-down.
  6. Select a polygon layer as the source layer.
  7. Once the observation and source layers have been selected, choose the field names from each layer that you want to match.
  8. Click Add GeoEnrichment Definition next to the field inputs.
    Once you add a field matching pair, the table populates.
  9. Provide a description for the GeoEnrichment definition.
  10. Click Create when finished.
Edit a GeoEnrichment definition in an Excalibur project
You can edit a GeoEnrichment definition if you are a project owner or administrator. To edit a GeoEnrichment definition in a project, complete the following steps:
  4. Click Update on an existing definition.
    Edit the following as needed:
    • Edit the description.
    • Remove existing field matches.
    • Edit existing field matches.
    • Add new field matches.
  5. Click Update once you make changes to the definition.
Add related information products
Related information products are any supported item types that are associated to an Excalibur project. Related information products are created and uploaded using Export Tools in the related Excalibur project. Once a report, screenshot, or video frame is uploaded to the project, a relationship is created with the item to the Excalibur project.
Additionally, a project owner or administrator can add a related information product through the Project Details page. These products can be viewed or downloaded by any user who has sharing permissions to view the item. If an item is shared privately or to specific groups, only the users with access to the item will see it visible in the Excalibur project. When adding a related information product from content, the supported products and applications are Microsoft PowerPoint, Microsoft Word documents, Microsoft Excel spreadsheets, image files, ArcGIS Dashboards, ArcGIS Experience Builder, ArcGIS StoryMaps, ArcGIS Web AppBuilder, and ArcGIS Instant Apps.
To add a related information product in a project, complete the following steps:
  3. Click the Products tab.
  4. Click Add Products .
  5. Select the products you want to save to your project.
  6. Click Save to add the products.
Click Options to choose to Open, View Details, or Remove the products. Items added from Export Tools are also added to the Products tab of your Excalibur project.
Delete an Excalibur project from the project details
To delete an Excalibur project, click Delete next to Open Project . A dialog box prompts you to confirm your project deletion. You can delete additional items related to the Excalibur project. However, you may only delete projects and items you own, unless your account has administrator privileges.
