Open Excalibur projects
An Excalibur project can be opened from the Excalibur projects list. By default, the project opens in the canvas view. The project capabilities determine the available tools. The sections below describe the various project items you'll encounter based on the type of project you're opening and its corresponding resources.
Images and video from a web service
All Excalibur projects have an image, a set of images, an imagery layer, or a video layer from which the Excalibur project was created. The image or images may be available in the supported focus view based on the type of imagery.
If the last analysis layer in the project is deleted or becomes inaccessible, the project is not usable until a new analysis layer is added. If you open the project, a warning will appear notifying you which analysis layer for the project is inaccessible. You will be able to add a new analysis layer on the Analysis Layer tab in the Project Details.
Bookmarks tool
A bookmark is a navigation shortcut to a position on a map or perspective in the map to return to later. When you create a bookmark, it references the map it was created from. You can save a project bookmark through an Excalibur project in the canvas and use web map bookmarks if the web map being used in the project has bookmarks saved to it.
The Bookmarks
menu lists all the bookmarks in the associated project and in the web map being used within the project. You can click the Zoom to bookmark extent
button on a bookmark as a shortcut to navigate to a position in the project.
Create a bookmark
Create bookmarks by clicking Create Bookmark from the Bookmarks
menu located in the header of the map panel. To save a bookmark, complete the following steps:
In the project, navigate to the location or extent in the map you want to bookmark.
Provide the following:
Name—A memorable name for the bookmark
Description—A summary of the bookmark
Click Save.
The bookmark appears in the Project Bookmarks menu.
Edit a project bookmark
To edit a bookmark, complete the following steps:
In the project, click Bookmarks
.Locate the bookmark on the Project tab and click Edit Bookmark
.Edit the Name and Description of the bookmark.
Optionally, adjust the extent of the map.
Click Save to update your changes. Click Cancel to return to the Project Bookmarks menu.
Delete a project bookmark
To delete a bookmark, complete the following steps:
.Locate the bookmark on the Project tab and click Delete Bookmark
.The bookmark is removed from the project bookmarks.
Use web map bookmarks
To use a web map bookmark, the web map being used within the project must have bookmarks saved to it. Bookmarks can be saved to web maps when they are created in Map Viewer in Portal for ArcGIS, ArcGIS Online, or ArcGIS Pro. To use a web map bookmark in an Excalibur project, complete the following steps:
Ensure that the web map being used in the project has bookmarks saved to it. If needed, navigate to the project details to switch the project web map.
.Locate the web map bookmarks on the Web Map tab.
Click the Zoom to bookmark extent
button on the web map bookmark as a shortcut to navigate to the position of that bookmark in the project.
To edit or delete a web map bookmark, this must be done within the web map in Map Viewer in Portal for ArcGIS, or ArcGIS Online, or ArcGIS Pro.
View and edit project instructions
To view and edit the project instructions within an open project, complete the following steps:
Click More
in an open project.Click Instructions
.Review the Project Instructions and Projects Resources and References for this project.
If you are the project owner or an admin, click Edit and make any changes to the written instructions.
Click Update to save any changes.
Click
to close Instructions.
Project web map
When an Excalibur project is created, a web map is created also and set as the project web map. Any Excalibur project can include an existing web map that contains layers to provide context for an Excalibur project.
When you open a project, the web map appears in the Map Panel. If the web map contains layers, the layers are overlaid on top of the image in both the map panel and the Focus Panel if an image service is being used as the focus layer. These layers can be turned on or off, or you can interact with them to view additional information.
Time slider
When you open the canvas or a project that contains a time-enabled Imagery Layer, Tiled Imagery Layer, Map Image Layer, OGC service such as a WCS layer, or Feature layer, a time slider is available on the Time Slider tab. Each time-enabled layer has a time element that can be used to filter the layer using the interactive time slider.
Adjust the time slider
The time slider will have two handles representing start and end times. You can adjust these handles to set intervals to filter a view based on the desired time extent. You can also use the date and time inputs to set a custom range.
To adjust the time, complete the following steps:
By default, the time slider will be disabled. Turn on the time slider by clicking Enable in the Time Slider tab.
Click to grab the start time handle and drag it along the timeline to the desired start time.
Alternatively, you can manually enter a start date and time using Start Date and Time.
Click to grab the end time handle and drag it along the timeline to the desired end time.
Alternatively, you can manually enter an end date and time using End Date and Time.
Click and drag in the middle of the time slider control to manually move the desired time extent.
To automatically loop through your desired time extent, click Play to loop through the timeline.
You can also click Pause to stop at a desired point in time.
The time-enabled layers dynamically update based on the defined start and end time.
To manually step through your desired time extent, do the following:
Click Previous
to step back to the previous time interval.Click Next
to move forward to the next time interval.
Change the time display
Change how the large of a time window the time slider visualizes in the time-enabled layers by choosing the slider time interval size, and the starting and ending datetime.
Click options
.Click Settings
.Choose a time display method:
Show current interval—Show data that is within a set time range.
Show features progressively— Progressively show data that is within a set time range. Layers are accumulated in the view as the end of the time interval moves forward.
Show from a time instant—Show data that falls on a single instance in time, where the beginning and end of the interval are the same.
Set the Start Date and Time.
Set the End Date and Time
Next use playback buttons or time slider controls to visualize temporal change with the enabled layers.
Playback position
Open the time slider options
, sselect the Settings
option, and within the Playback Position section choose From start time to play the time slider from the beginning of the slider or From position saved with map to play the slider from the saved position within the web map.
Play rate
, select the Settings
option, and set the speed at which the time interval plays in the Playback Rate slider. You can move the slider between Fast, to increase the speed, and Slow to decrease the speed.
Apply muted effect
There may be times when you want to view all features in the observation layer or layers at one time but only keep visual focus on the ones within your desired time range. Selecting the Apply Muted Effect
option will fade any layers or features outside your defined time extent and highlight only those layers or features within the defined range. In the time slider options
, select the Apply Muted Effect
option to do this.
Use the feature table
The feature table provides an interactive tabular view of any context or observation layers in the Excalibur project. You can use the table to select or deselect a row and view the corresponding features highlighted on the map.
To use the feature table, complete the following steps:
In an Excalibur project, click to expand the Feature Table tab.
The table expands and displays the attributes and details of the selected layer. The total feature count and total selected feature count are displayed above the table.
Use the drop-down menu to select the layer you want to view.
ArcGIS Knowledge spatial entity observation layers are not currently supported with the Feature table, so only Feature Layer observation layers appear here.
The table dynamically updates with the selected layer.
Click each column to sort the field in ascending or descending order.
Check the check box next to each feature to select the desired features.
The corresponding features are highlighted on the map. The total selected features dynamically update every time a feature is selected or deselected.
Click Clear to deselect all features.
