Use Canvas views
There are multiple views you can use to work with your imagery and video in the ArcGIS Excalibur Canvas. The metadata of the imagery and video determines the available views.
To open the Canvas, you can:
  • Connect directly to imagery or video layers after searching for these in the Search and Discover page.
  • Open layers from the Analysis Layers page
  • Open feature layers from the Observation Layers page
  • Publish your own imagery or video.
  • Open an empty Canvas using the Open Canvas button on the side-navigation bar in the app.
Map Panel
After finding suitable imagery and connecting to the canvas view, the imagery appears in the Map Panel by default. The Map Panel allows you to spatially view imagery on top of a default basemap, where the imagery is automatically orthorectified and is aligned with the map.
The following are the default behaviors of the Map Panel:
  • The Map Panel is zoomed to the extent of the service if it's connected using a web service or connected through the Analysis Layers page. It's zoomed to the extent of the queued image or images if it's connected from Search and Discover.
  • The image metadata table is collapsed by default, but when expanded, it displays the records of your imagery if you are using an image collection layer.
  • You can zoom in and out on the map using the zoom-in and zoom-out buttons.
  • Return to the extent of the imagery if you are viewing imagery in the canvas or return to the saved extent of the project using the Default Map View button below the zoom buttons.
  • Search for a specific address or location using the Find address or place widget.
  • Holding down a right-click will allow you to alter the orientation. You can reset the orientation using the Reset map orientation button.
  • You can change the basemap using Basemaps located in the map panel toolbar.
  • View an overview map using the Overview Map button located in the Map Panel header.
  • To view a legend, click Map Legend in the Map panel toolbar.
Use the image metadata table
The image metadata table allows you to see information about your imagery and interact with each image. The table is only available for query-enabled image collection layers. Based on the imagery format and type, the table contains metadata about each record in the table. Use the table to identify images, manage selections, filter results, view images in the Focus Panel, and customize the information displayed:
  • Selecting images—select an image by clicking the check box in the row, which results in the corresponding footprint being highlighted on the map.
  • Set as Focus Image—optionally set an image as the focus image in the Focus Panel by clicking Set as Focus Image .
  • Draw to Filter—use the Draw to Filter action to draw an area of interest (AOI) on the map. The map and table update to display only images that intersect the AOI. Select Clear Area of Interest to remove the filter.
  • Column visibility—the image metadata table displays a select few metadata fields. To view more or fewer fields, click Column visibility on the table button to show or hide columns on the table.
  • Navigate records—Use the pagination controls to move through image records in the table when pagination is available. Pagination is only available if the layer contains less than 500 records.
  • Switch imagery layers—If multiple catalog-enabled image collection layers are available, use the layer selector to switch the table between layers. The table updates to display metadata for the selected layer.
  • Additional options available using the Options menu:
    • Show Selection to display only selected images.
    • Zoom to Selection to zoom to selected image footprints.
    • Show All to restore all images.
    • Clear Selection to remove the current selection.
    • Refresh Data to update table with updated records.
Use the feature table
The feature table provides an interactive tabular view of any context or observation layers in the Canvas. Similiar to the image metadata table, you can use the feature table to identify features, manage selections, filter results, trace the source layer a feature was collected on, and customize the information displayed:
  • Selecting images – You can select a feature by clicking the check box in the row, which results in the corresponding footprint being highlighted on the map.
  • Trace Observation - Use the Trace Observation option to view the source imagery or video layer that was used when an observation was collected. Tracing an observation helps you understand the source data, review metadata, and access the original project or layer when available.
  • Draw to Filter - You can use the Draw to Filter action to draw an area of interest (AOI) on the map. The map and table update to display only features that intersect the AOI. Select Clear Area of Interest to remove the filter.
  • Column visibility - By default, the feature table displays a select few metadata fields. To view more or fewer fields, click Column visbility on the table button to show or hide columns on the table.
  • Manage attachments - If the feature layer supports attachments, you can manage them directly from the feature table in the Attachments column. You can add attachments using the Select File option or drag-and-drop, download existing attachment, replace attachments with updated files, and delete attachments when they are no longer needed.
  • Navigate records - Use the pagination controls to move through records in the table when pagination is available. Pagination is only available if the layer contains less than 500 records.
  • Switch feature layers - If multiple feature layers are available, use the layer selector to switch the table between layers. The table updates to display metadata for the selected layer.
    • Show Selection to display only selected features.
    • Zoom to Selection to zoom to selected features.
    • Show All to restore all features.
Time slider
When you open the canvas or a project that contains a time-enabled Imagery Layer, Tiled Imagery Layer, Map Image Layer, OGC service such as a WCS layer, or Feature layer, a time slider is available on the Time Slider tab. Each time-enabled layer has a time element that can be used to filter the layer using the interactive time slider.
Adjust the time slider
The time slider will have two handles representing start and end times. You can adjust these handles to set intervals to filter a view based on the desired time extent. You can also use the date and time inputs to set a custom range.
To adjust the time, complete the following steps:
  1. By default, the time slider will be disabled. Turn on the time slider by clicking Enable in the Time Slider tab.
  2. Click to grab the start time handle and drag it along the timeline to the desired start time.
    Alternatively, you can manually enter a start date and time using Start Date and Time.
  3. Click to grab the end time handle and drag it along the timeline to the desired end time.
    Alternatively, you can manually enter an end date and time using End Date and Time.
  4. Click and drag in the middle of the time slider control to manually move the desired time extent.
  5. To automatically loop through your desired time extent, click Play to loop through the timeline.
    You can also click Pause to stop at a desired point in time.
    The time-enabled layers dynamically update based on the defined start and end time.
  6. To manually step through your desired time extent, do the following:
    • Click Previous to step back to the previous time interval.
    • Click Next to move forward to the next time interval.
Change the time display
Change how the large of a time window the time slider visualizes in the time-enabled layers by choosing the slider time interval size, and the starting and ending datetime.
  1. Click options .
  2. Click Settings .
  3. Choose a time display method:
    • Show current interval—Show data that is within a set time range.
    • Show features progressively— Progressively show data that is within a set time range. Layers are accumulated in the view as the end of the time interval moves forward.
    • Show from a time instant—Show data that falls on a single instance in time, where the beginning and end of the interval are the same.
  4. Set the Start Date and Time.
  5. Set the End Date and Time
  6. Next use playback buttons or time slider controls to visualize temporal change with the enabled layers.
Playback position
Open the time slider options , sselect the Settings option, and within the Playback Position section choose From start time to play the time slider from the beginning of the slider or From position saved with map to play the slider from the saved position within the web map.
Play rate
Open the time slider options , select the Settings option, and set the speed at which the time interval plays in the Playback Rate slider. You can move the slider between Faster, to increase the speed, and Slower to decrease the speed.
Apply muted effect
There may be times when you want to view all features in the observation layer or layers at one time but only keep visual focus on the ones within your desired time range. Selecting the Apply Muted Effect option will fade any layers or features outside your defined time extent and highlight only those layers or features within the defined range. In the time slider options , select the Apply Muted Effect option to do this.
Split view
You can also view imagery in split view, which allows you to use the Map Panel and Focus Panel at the same time. This is helpful because you can view the imagery aligned to a map (in the Map Panel) and view the same imagery as it was captured in its native perspective (in the Focus Panel).
Switch to split view
To view the imagery in split view, complete the following steps:
  1. With the image metadata table expanded, select an image.
    The selected image footprint is highlighted in cyan.
  2. Click the Set as Focus Image button in the image metadata table.
    A split view of the selected image appears in both the Map Panel and the Focus Panel. If the selected image is within the current extent, it remains at the current map extent. If the selected image is outside of the current extent, it zooms to the extent of the image. All imagery, other than the selected image, is turned off in the Map Panel, allowing you to focus on the selected image.
    You can only view one image at a time in the Focus Panel.
    You can use the Sync Extents button in either the Map Panel or the Focus Panel. Using the Sync Extents button in the Focus Panel syncs the extent of the Map Panel to the current extent of the Focus Panel for better orientation. Using the Sync Extents button in the Map Panel syncs the extent of the Focus Panel to the current extent of the Map Panel for better orientation. If the extent of the Map Panel is outside the extent of the image that is set as the focus image in the Focus Panel, an error occurs if the Sync Extents button is clicked.
  3. Click the Close button on the Focus Panel to close the split view.
    The Map Panel extent remains centered on the previously focused image, and all other imagery in the image metadata table is automatically turned back on.
Focus Panel with imagery
When you're using split view, you can expand the view of the focused image to a maximized state, allowing you more room to work with the focused image in its native perspective.
Expand the Focus Panel
To maximize the state of the focus view, complete the following steps:
  1. Click the Expand Focus Panel button in the corner of the Focus Panel.
    Once the panel is expanded, you can continue to work with the focused image.
  2. Optionally, click the Reset to Split View button on the Focus Panel to switch back to split view.
View metadata
You can view an image's metadata at any time by expanding the Image layer metadata .
  1. Click Image layer metadata in the Focus Panel header to view the corresponding metadata of the focused image.
    The metadata tray can be viewed in three sizes by clicking the expand button at the bottom of the tray. Clicking this button cycles through the three sizes. The middle size is the default.
  2. Optionally, click Copy to clipoard in the metadata tray to copy the image metadata to the clipboard.
Use the Rotate View tool
The Rotate View tool allows you to rotate an image in the Focus Panel.
To rotate an image, complete the following steps:
  1. Click Rotate View in the Focus Panel.
  2. Click and drag the outer ring to rotate the image.
  3. Click the center of the widget to reset the tool to Top Up.
  4. Click Collapse to collapse the tool.
    The image remains in its last rotated position.
Use the Go-to Coordinate Tool
The Go-to Coordinate tool allows you to input coordinates using one coordinate system and output to different coordinate systems using multiple notation formats. You can input a coordinate to quickly pan-to and center on the corresponding location on the map or capture any coordinate location by clicking directly in the map view.
You can change the coordinate format using the drop-down menu (default is XY), copy the coordinate, or clear it. Entering a new coordinate removes the previous location pin. An error message appears if the coordinate is invalid or outside the Image Focus extent.
The Capture Coordinate tool allows you to click directly in the map panel to populate the coordinate field. The selected location is pinned and centered in the same way as manually entered coordinates.
Use the Flash location tool
The Flash location tool is available in Split View and helps you visually match locations between the map panel and focus panel. When activated, clicking a location in either panel briefly flashes and centers that same geographic location in both panels, making it easier to confirm alignment between views.
Focus Panel with oriented imagery
When connected to an oriented imagery layer as the analysis layer, the oriented imagery widget is visible in the Focus Panel. This widget provides tools used to identify locations in the Map Panel and an imagery viewer for exploring available oriented images that depict the area of interest. Panning and zooming the image dynamically illustrates the camera's field of view on the map. You can also use the Oriented Imagery Metadata table that becomes available when you are connected to an oriented imagery layer. This table has the same functionality as the image metadata table.
For more information about the oriented imagery widget, see Work with the oriented imagery viewer.
Work with video views
You can use ArcGIS Excalibur to view and analyze video layers in the canvas. By default, the video is displayed in split view, which allows you to play a video while having geospatial context of what is being viewed if the video layer contains this information.For more information on working with video in ArcGIS Excalibur, see here to learn about analyzing video.
