Use search and discover
Using the search functionality, you can perform an interactive search and selection of available imagery and video from a web service. You can also set search settings, preview imagery, view image metadata, and queue images and videos for further use.
Access Search and Discover
You can access Search and Discover from the following in ArcGIS Excalibur:
On the ArcGIS Excalibur home page, click Find Through: Search and Discover.
From anywhere in the application, click Search
in the side menu.
Once the Search and Discover page is open, connect to an active layer to begin your search experience.
Select an active layer
Before performing a search, an active layer must be set. A list of layers is available in the Collections panel located at the top of the search map. You can also use the Browse button to browse available layer collections to perform search and discovery if no layers have been connected yet.
To select an active layer, complete the following steps:
Click Browse or Collections
to open the Browse Collections panel.The Browse Collections panel opens with the Layers tab open by default.
Switch to the Saved tab to view any saved search layers or the Add from Web tab to connect to a layer via URL.
The Layers tab displays all available layers within your organization that you can use for search and discovery.
On the Layers tab, search for a specific layer using the search bar at the top of the layer list.
Connect to a layer by clicking the Connect button.
You can change the connected active layer at any time by following steps 1-4 again. Any existing results and filters will be reset when a new layer has been selected. You can also save the current connected layer so it will appear on the Saved tab in the Browse Collections panel by clicking the star next to the service name at the top of the page.
Once an active layer is set, you can search for imagery or video within your organization as described below.
Search by map extent
You can search on the active layer using your current map extent.
Pan and zoom to an area of interest in the map.
The default basemap and map extent can be set in My Settings.
Click Run Search
.If images or video exist in the active layer, the map pans and zooms to the extent of the results, footprints appear on the map, and results are listed in the Results Table.
Search by area of interest geometry
A search can be performed on a defined area of interest geometry. See Apply an area of interest filter for more information.
Search by saved search query
When you need to search against the same layer on a regular basis, you can create saved search queries against your filters and active layer. This allows for a single-click search and discovery later. At a minimum, you must enter a name for your saved query. Optionally, you can provide a description of the query.
To create a saved search query, complete the following steps:
Apply the filters you want your layer to search against.
Optionally, you can click Run Search
to see a list of your search results before proceeding to the next step.Once you apply the filters of your choice, click Save
.The Create a New Saved Query dialog box appears.
Provide information about your query:
Name (required)
The query filters you selected appear in a list under Query Settings.
Click Save Query
to save your query.
Your query saves and appears in the My Saved Queries list.
My Saved Queries
The My Saved Queries list contains all the saved queries on layers you previously had saved queries. Clicking Queries
opens a list that shows all the queries you saved across multiple layers.
Use a query to search for imagery or video
To use the My Saved Queries list to search for imagery or video, complete the following steps:
Open Search and Discover.
Click Queries
.The My Saved Queries list opens to the saved queries.
Locate the query you want to search against and click
to run the search.Your results appear in the Results list and on your layer.
Running a saved query on a layer that is not the active layer will clear the Results tab, change the map extent, and update the active layer to the layer defined in the query.
Edit a saved query
You can edit a query if you want to change the saved query Name or Description. To edit your saved query, complete the following steps:
Click Queries
.My Saved Queries opens to the saved queries.
Locate the query you want to edit and click
to make changes to the query.The query details appear.
Click Edit
and change the Name or Description.Click Save Query
to save your changes.
Delete a saved query
You can delete a query if it is no longer applicable. To delete your saved query, complete the following steps:
Click Queries.
Locate the query you want to delete and click the trash can
to delete the query.A message appears asking you to confirm your deletion.
Click Delete. Optionally, click Cancel to return to the My Saved Queries list.
You can delete all saved queries by clicking the Delete All
button in the corner of the My Saved Queries list.
