Search and discover results
After successfully searching for video or imagery in the Search and Discover page, you can view and analyze the results in the Search Results panel. In this panel, you can also preview selected results, view metadata, and add images or videos of interest into the Cart to then be used for further analysis.
The Search Results panel contains other options that allow you to interact with images or video. These options include:
  • Show Selected —shows the selected results and hides all unselected results in the list. You can select items individually by using the checkbox next to each item name in the list, or by using the selection draw tools in the map. These draw tools include:
    • Draw Rectangle
    • Draw Point
  • Filter —opens additional filters for customizing your search criteria. Learn more about applying search filters.
  • Show Cart —opens the search cart to show images or video added to it.
View the details of your search results
You can preview image and video search results to quickly assess whether the content is relevant to their mission or area of interest. For video results, You will search within the footage by defining an area of interest on the map and using timeline markers to identify specific periods when that location was covered, making it easier to focus on the most relevant segments of video. Detailed metadata is available, providing additional information about the selected image or video, including technical properties and other supporting details to aid analysis and decision-making.
Preview a result
You can preview an image or video to analyze the result before working with it further.
  1. In the Search Results panel, click View Details on an item in the list. The View Details button appears as or depending on the result as an image or a video.
The Details panel opens and a preview of the image or video appears. You can further inspect the image or video by zooming in or out and panning around the image, or by playing the video in the previewer. Additionally, you can compare what is in the preview to what is on the map using the Zoom to this item button.
Search within a video
If you use an area of interest filter against a video layer, a list of markers is displayed showing the number of times the specified location intersects with the video coverage and the duration of each marker. These are displayed in the Timeline Markers table. The markers appear on the video player timeline when connecting to the Canvas view with the video layer. Click a marker to view that point of time in the video.
To add timeline markers, do the following:
  1. In the Search Results panel, click View Details on a video in the list.
  2. Expand the Search Within Video section if not already expanded.
  3. Use the geometry tools on the top of the map to draw a point or polygon to define an area of interest within the footprint of the video coverage area.
  4. If the area of interest defined is an area that is shown at a point of time in the video coverage, the Timeline Markers table will populate with the information regarding when the coverage begins and how long the coverage is on that area of interest.
Select the individual markers and click Add to Cart . The markers appear in the video player timeline when connecting to the Canvas view or when creating a project. Click a marker to go to that point in the video.
View metadata
Additional metadata can be viewed to gain a greater understanding of the image or video.
  1. In the Search Results panel, click View Details on an item in the list. The View Details button appears as for an image or for a video.
  2. View the Image Metadata or Video Metadata sections within the Details panel.
Add images and video to the cart
With the search Cart you collect and organize imagery and video results for later use. Individual results are added directly to the Search Results list by clicking Cart , or from the result's Details panel by selecting Add to Cart .
Review items in the My Cart panel before proceeding. In the cart you can remove individual items, clear the cart, connect the selected results in the Canvas, or create a new project.
Create an Excalibur project
Create an Excalibur project based on the images or videos in the Cart . Complete the following steps to create a project in the My Cart panel:
  1. Click Create New Project.
    The Create an Excalibur Project dialog box appears.
  2. Provide information for the following parameters:
    • Title (required)
      This name should be unique. If the same name as an existing folder in your content is detected, a new folder is created in your content with the word copy appended to it.
    • Folder Name (required)
    • Project Instructions (required)
    • Summary (optional)
    • Tags (optional)
  3. Choose to share the project publicly, share with your organization, or keep it private.
    The default setting is Owner. Optionally, you can also share the project with a group.
  4. Click Create to create the project.
    Your new project opens, and a folder for your project is created in your content.
  5. Click More > Project Details to edit additional project information.
Connect to the canvas
You can connect directly to the Canvas with the images or videos added in the Cart without having to first create a project. In the My Cart panel, click Connect to Canvas to open the canvas. Learn more about the canvas.
Remove items from the cart
To remove a single image from your cart, click the Cart button at the top of the window and click the trash can next to the item. The selected item is removed from the list. To remove all images in the queue, click Clear Cart.
