Add ArcGIS layer data to Excel
You can add and edit an ArcGIS Online or ArcGIS Enterprise layer attribute table in a Microsoft Excel worksheet. Any edits made to the ArcGIS layer attribute data in the Excel worksheet directly update the hosted layer in ArcGIS.
See the Esri Community blog article for more information and a video about adding an ArcGIS layer to Excel.
This functionality is only available for feature layers.
Add a feature layer or group layer to a map and an Excel worksheet
Complete the following steps to add a feature layer or group layer to a map and an Excel worksheet:
From the map tools, click the Layers button
.The Layers pane appears.
In the Layers pane, click Add
.The Add layer pane appears.
Click the ArcGIS tab.
Click to select a hosted ArcGIS Online or ArcGIS Enterprise feature layer from the drop-down menu.
If necessary, click Add attribute table to Excel and layer to map
If the layer added is a feature layer or a group layer with feature layers, the connected attribute table is shown and reflected in Excel with the features populating the map.
A few things to remember:
If you have added an ArcGIS layer with its attribute table to an Excel worksheet, or if you have shared an Excel layer to ArcGIS Online or ArcGIS Enterprise, you cannot create another layer from the same Excel data.
Only organization administrators or layer owners can perform delete, rename, or insert column operations to update the fields of the ArcGIS layer.
When adding a layer to your map, you may consistently get the following error: Layer view requires layer with query capability. When adding new features to an ArcGIS layer, no features are drawn on the map. See the ArcGIS for Excel Frequently asked questions topic for troubleshooting information.
Edit hosted stand-alone or related tables
ArcGIS for Excel supports editing stand-alone, related, and join tables that are associated with a hosted ArcGIS layer in ArcGIS Online or ArcGIS Enterprise. Associated tables in layers brought from a remote source into your worksheet can be edited directly in Microsoft Excel.
You can use the Sync with ArcGIS tool
on the Map data tab to refresh and sync the ArcGIS Online or ArcGIS Enterprise attribute table with the connected table in Microsoft Excel.
If you made edits to the layer's feature attributes using ArcGIS Pro or ArcGIS Online Map Viewer, ArcGIS for Excel detects such changes and a notification indicates that your data may need to be synced back to Excel. This notification is not supported in ArcGIS Enterprise.
Related tables define a relationship between two tables. The associated data isn't appended to the layer's attribute table as it is with a join. For example, you can associate a table containing parcel ownership information with the parcel's layer data because they share a parcel identification field.
If you need to view related tables side by side on the same screen, you can use Microsoft Excel's native feature. See Compare two or more worksheets at the same time.
ArcGIS Pro
You can create related tables using ArcGIS Pro and publish the table layer to ArcGIS Online or ArcGIS Enterprise. You can bring the table layer into an Excel worksheet using ArcGIS for Excel for editing purposes.
ArcGIS for Excel does not support creating related tables in Excel.
Learn more about hosted related tables in ArcGIS Pro
Learn more about tables in ArcGIS Pro
Learn more about joins and relates in ArcGIS Pro
ArcGIS Survey123
You can bring data from ArcGIS Survey123 to Excel to review or edit. There are many options for authoring XLSForm-compliant spreadsheets; Excel is the most commonly used. Once the table is imported into Excel, you can start the editing process using ArcGIS for Excel.
Learn more about hosted related tables in Survey123
Learn more about tables in Survey123
Learn more about Survey123 repeats
View and edit single-layer attributes
Complete the following steps to add and edit attributes of a single feature layer:
In the Layers list, click More options > Show layer details
to view the layer details in ArcGIS Online.On the ArcGIS Online details page, click the Data tab.
The tab shows the default Table view of the attributes.
Click Settings and ensure that the Enable editing check box is checked in the Feature layer (hosted) section.
When editing is enabled, you can edit a hosted feature layer in the Excel table.
Add the hosted feature layer to Excel.
Once you edit the table in Excel, it automatically synchronizes with the hosted layer in ArcGIS.
View and edit group layer attributes
Complete the following steps to view and edit group layer attributes:
When editing is enabled, you can edit a group layer in the Excel table.
Add the group layer to Excel.
In Excel, check a check box or boxes from the Select attribute tables widget.
Click Add.
The attribute table for each feature layer in the group layer opens in a new, separate worksheet. All layers are added to the map at once.
Optionally, click Cancel to exit the widget and select another feature layer or group layer.
Optionally, click the Visualization tab in the remote web map layer to view the layers that were added to the map in Map Viewer. This is identical to your map in Excel.
Add columns
You can add new columns to your table. Use the table's Configure new fields pane to add new columns and fields to your worksheet.
In the Microsoft Excel worksheet, type in a new column header. The Configure new fields pane appears.
The Field name corresponds to the header you have added to your worksheet in the new column.
Select a field Type from the drop-down menu.
Click OK.
Edit feature layer fields
In ArcGIS Online and ArcGIS Enterprise, all field management operations remain the same when added to the Excel worksheet. In the ArcGIS Fields view, for example, if you set Unique to Yes in the Settings table and attempt to add a duplicate value in the Excel worksheet, you may receive an error message.
Complete the following steps to edit feature layer fields:
Optionally, click Settings and ensure that the Enable editing check box is checked in the Feature layer (hosted) section.
When editing is enabled, you can edit the feature layer in the Excel table.
On the Data tab, click the Fields view next to the Table view.
In the Fields view, you can edit the ArcGIS feature layer field settings. The feature layer details, such as objectID, Description, Field Value Type, and Settings, appear in a list. You can create lists in the remote hosted layer. Different ArcGIS products have different terminology for this action, for example, Create list in ArcGIS Online and Coded value domain in ArcGIS Pro.
ArcGIS for Excel supports ArcGIS Pro layers containing a SubType field published to ArcGIS. You can bring that field as a layer to the Excel worksheet for editing. ArcGIS for Excel supports editing SubType group layers. You can add SubType group layers to an ArcGIS for Excel map and edit the attribute data directly in the Excel worksheet.
Choose and add field types
Every feature class and table is made up of fields that are defined by their data types.
When you create feature classes and tables, you select a specific data type for each field. A field's data type is the most important property because the data type you select determines the type of data the field can store. Additional field properties that can be set—such as precision, scale, and length of a field—are also dependent on the data type of the field.
Sign in to ArcGIS.
Add data from ArcGIS.
In Excel, type in an empty column by adding a header.
The Choose field type pane appears. Select from the options.
Support is now available for Big integer if you are working with large numbers. Learn more about Big Integer.
Add new rows to a feature layer attribute table in an Excel worksheet
To add a new row to a feature layer attribute table in your Excel worksheet, complete the steps in the following sections:
Add a feature layer with location data to Excel
You can add attribute data (containing address, coordinates, longitude, and latitude columns) of a feature layer to Excel.
Sign in to ArcGIS.
In Excel, type in an empty row.
The Add features to ArcGIS layer pane appears. The Location data in the spreadsheet check box remains unchecked.
Location data from the spreadsheet automatically populates the Layer field, and the longitude and latitude drop-down boxes with the corresponding fields from the spreadsheet.
Click Save to return to the Excel worksheet.
Type longitude and latitude values in the respective columns in your worksheet.
The corresponding features are created on the map and a feature added pop-up appears.
Click Zoom to on the pop-up to zoom to the newly added feature on the map.
You can zoom to the point feature and also sync with ArcGIS.
Tip:
Optionally, you can batch copy and add multiple rows.
Optionally, when you add features to your ArcGIS layer, you can edit the location type properties by updating the fields in the Edit Geometry pane.
Caution:
When your feature layer contains location data, you cannot change the Location type field.
Add a feature layer with no location data to Excel
Add data from a feature layer to Excel that contains no location data (coordinates or address columns).
Sign in to ArcGIS.
The Add features to ArcGIS layer pane appears. The Location data in the spreadsheet check box is checked.
Location data from the spreadsheet automatically populates the Layers field, and longitude and latitude drop-down boxes with the corresponding fields from the spreadsheet.
Add a new feature by entering the longitude and latitude values.
Click Save.
Optionally, add another feature by typing in an empty row in your Excel worksheet.
The Add features to ArcGIS layer pane appears, and the corresponding features are created on the map and a feature added pop-up appears.
Tip:
Caution:
Read more in the Esri Community change log blog article
Remove a hosted feature layer
Complete the following steps to remove a hosted feature layer from the Layers list:
In the Layers list, click More options > Remove next to the layer you want removed.
The layer is removed from the map and the Excel worksheet.
Edit referenced feature layers
ArcGIS for Excel supports editing referenced feature layers in Excel, where the data remains in its original source such as a database and is referenced through ArcGIS Enterprise. Once the data is in Excel, any edits you make directly update the ArcGIS layer in ArcGIS Enterprise and its underlying database or enterprise geodatabase, provided you have the necessary read and write permissions. Currently, editing referenced layers using ArcGIS for Excel is supported for layers sourced from Microsoft SQL Server, Oracle, PostgreSQL, and enterprise geodatabases.
Format feature layer pop-ups and labels
You can format pop-ups and labels for hosted feature layers in ArcGIS for Excel. The formatting that is added to Excel is saved in the ArcGIS Online or ArcGIS Enterprise layer automatically in real time.
