Configure tasks
Tasks in Field Maps are highly customizable, allowing you to create task management workflows that support your specific field operations, enhancing accountability and improving overall project management.
You can configure tasks in the following ways:
Configure the form
Forms in feature layers provide a structured method to input and manage detailed information for features.
Tasks are features. When you create a new feature in your task-enabled layer, the form allows you to enter all the necessary information about that task. You define and configure the information for your tasks using the Forms tab in Field Maps Designer.
When you create a new task-enabled layer, the following form elements are added to the form by default:
  • Task type—Type of task.
  • Assignee—Person assigned to the task.
  • Status—Status of the task (for example, In progress, Complete, etc.).
  • Priority—Priority of the task (for example, Low, High, Critical, etc.).
  • Due date—Due date of the task.
  • Description—Description of the task.
  • Notes—Notes taken while completing the task.
  • General—Attachments for the task.
Task type, Assignee, and Status are required fields and control the display of to-do lists in the Field Maps mobile app.
You cannot remove required fields from your new task-enabled layer. You can change the display name of required fields but you cannot change the field name. If you choose to enable tasks on an existing layer, build the following required fields into your form with the correct field names:
You can remove or keep and configure any of the other default fields that are provided when you create a new task-enabled layer. Additionally, you can add and configure your own custom fields to the form to ensure your task layer accurately supports your project needs.
To configure the tasks form, you must have access to the web map and associated layers. See Data access and editing.
Task type field
The required Task type field allows you to define the types of tasks suitable for your specific field workflows in the map. You must configure at least one task type for task functionality to work in Field Maps.
To configure the Task type field values (coded value domain), complete the following steps:
  1. Select the tasks layer in your map in Field Maps Designer and click the Tasks tab.
  2. Click Task Settings.
  3. Click Edit next to Type in the Task Values section.
    The List of values window opens, where you can add the different types of tasks associated with the feature layer. A placeholder Task Type 1 is listed by default.
    The Label is the value displayed in the form, and the Code is the value stored in the layer.
  4. Add task types to the list and click Done.
    Task types can also be edited from the Forms tab. In the Forms tab, you can drag a CSV of values into the window to upload the coded value domain list.
Assignee field
The required Assignee field is essential for specifying which workers can be assigned tasks in the map. Configuring this field allows you to assign tasks to specific workers or let them view and pick up unassigned tasks. You can use the Assignee field to track who is working on specific tasks and who has completed them—promoting accountability, efficiency, and maintaining a historical record of task assignments in your field operations. You must add at least one worker into the Assignee field values for tasks to work.
To configure the Assignee field from the task settings, complete the following steps:
  3. Click Edit next to Assignees in the Task assignee section.
    The List of values: Assignee window appears, where you can add the workers on your team who can be assigned a task. There are two ways to add assignees:
    • Add the assignees into the fields by typing them in one at a time.
    • Click Select from organization to add users directly from your organization or from partnered organizations.
    The Label value can be any name and the Code value must be an ArcGIS username. This ensures that, when a task is assigned to a mobile worker, it appears on their personal to-do list in Field Maps.
  4. After you have added your workers, click Done.
You can also configure the Assignee field in the tasks form. However, the option to add users directly from your organization is not an option in the form area.
Tip:
Create a group in your organization for mobile workers that will be working on the project. You can quickly add all those associates into the Assignee field from the Select from organization option under Task Settings.
Status field
The required Status field records the progress of each task, such as whether it is unassigned, assigned, in progress, or completed. This field is important for tracking the current state of tasks, ensuring that mobile workers and managers can easily monitor task progress and manage workloads effectively.
You can immediately get started using tasks with the Status field default values, or you can add your own custom status values to better meet the specifics of your field workflows.
When you create a new task-enabled layer in Field Maps, the following default values are provided in the Status field:
Status Label
Status Code
Unassigned
Assigned
In Progress
Completed
Some examples of status customization in a utility inspection workflow scenario could include:
  • Unassigned—The task is created but not yet assigned to a worker.
  • Assigned—The task is assigned to a specific worker.
  • In Progress—The worker is actively performing the inspection.
  • Paused—The inspection is temporarily halted, perhaps due to weather conditions or waiting for additional resources.
  • Review—The inspection is completed, and the task is moved to a QA reviewer for approval.
  • Completed—The QA reviewer has approved the inspection, and the task is marked as finished.
You can configure the Status field in the form or on the Task tab in the Task Values section under Task Settings.
Status code values (in the esritask_status field) are used to configure the expressions that control:
  • The actions the mobile worker can perform as they work with a task.
  • The filters that determine which to-do lists a mobile worker can see.
If you change any status codes in the Status field, you must modify any Arcade expressions that reference the status field values and ensure they are referencing your updated codes for your workflows operate correctly.
For example, if you change the Completed status code from 3 to 4, update the Arcade expression used for the Finish action in the In Progress task action layout to reference the new value. This ensures that when a mobile worker taps the Finish button, the status updates to Completed. You will also want to review the to-do list Filters to ensure the correct status codes are used in your filter expressions. For the default task filter, you will want to update the Completed filter to reference this new completed status value of 4.
By understanding and configuring task actions and layouts, you can create flexible and efficient workflows customized for your field operations.
For more details on the required fields, see Understand the tasks information model.
Adding and configuring custom fields
You can add and configure custom fields in the tasks form in Field Maps, just like you do with data collection forms. This flexibility allows you to customize the tasks form to meet your specific workflow needs, ensuring all necessary information is captured when a new task is created.
For example, you might include fields like Estimated Time to Complete for scheduling and resource allocation, or Materials Needed to ensure workers have everything required to complete the task.
Forms vs. pop-ups in tasks
In the feature layer, pop-ups and forms serve distinct purposes. Understanding these differences will help you to design the task creation and task completion experiences for your projects.
  • Forms—The form is used for entering and managing data. Forms are editable and allow for data entry and updates.
  • Pop-ups—The pop-up displays read-only information about a feature in the map. Pop-ups are used to present data without allowing modifications.
Forms and pop-ups show up in tasks in the following ways:
  • Forms—In the tasks model, forms are used to create or update tasks. Task forms can be built and configured in Field Maps Designer or Map Viewer. You can customize the form for your specific workflow needs, adding and configuring fields to ensure all necessary information is captured when a task is created or updated.
    For more information about the tasks form and default fields, see Configure the form.
    You can create and update tasks for your mobile workers in multiple ways. To learn more, see Create and manage tasks.
  • Pop-ups—In the tasks model, the primary role of the pop-up is to display task information to the mobile worker. When a mobile worker opens a task in the Field Maps mobile app, the information presented to them about the task is the information that was provided and designed in the task layer’s pop-up.
    When you create a new task-enabled layer in Field Maps Designer, the following default configuration for your task pop-up is provided:
    • Pop-up title—Task type
    • Pop-up fields—Assignee, Status, Priority, Due Date, Description, and Notes
    Pop-ups are designed and managed in the web map using Map Viewer. You can customize the content and layout of the pop-up to ensure it provides all necessary task information to the mobile worker. For more information on designing pop-ups, see Configure pop-ups.
Customize task symbology
When you create a new task-enabled layer in Field Maps Designer, you start with a set of default fields, values, and symbology. This symbology includes visual indicators unique to each task status, helping you quickly identify the status of tasks on the map.
If you want to change or customize task symbology, you can do so in Map Viewer. For detailed instructions on how to create and manage symbology for features, see Use style options.
A feature template for the unassigned task type is included by default. If you want to create new tasks with other status types, you can create additional templates for any other statuses that your workflow may require.
To learn more about changes to consider when configuring feature templates, see Considerations for feature templates.
Configure task actions and layouts
Task actions and layouts are essential components within the tasks functionality which allow you to design the task completion process for mobile workers.
  • Task actions—Actions are interactive buttons or menu items that enable mobile workers to perform specific tasks, such as changing the task status, taking notes, getting directions, or attaching photos.
    When mobile workers open a task in the Field Maps mobile app, they see these actions as buttons or menu items in the pop-up. The app can display up to four action buttons at a time, with additional actions accessible through an overflow menu. Map authors can reorder actions within the layout to prioritize the most important ones. You can indicate which action is a primary action and it will be highlighted in blue for the mobile worker.
  • Task layouts—Layouts are groupings of task actions, organized based on the stages of your task workflows. Layouts determine how and when actions are displayed to mobile workers. Each layout can be customized to include different actions depending on the task's status or other factors.
Caution:
You must have at least one task layout defined in order for tasks to work.
Default actions and layouts
Default actions and layouts based on your default task statuses are shown when you create a new task-enabled layer in Field Maps Designer.
For example, in the default Unassigned task status layout, default actions are provided, including Pick up, Directions, and Compass. The default actions differ depending on the task's status.
You can get started by using the default configurations or you can customize task actions and layouts to meet your workflow needs.
Configuring task actions and layouts
Both task actions and layouts are configured in the Tasks tab in Field Maps Designer. Building task actions and layouts is similar to building forms. You drag and drop actions into the Task Layout canvas and configure each action to customize the task completion experience and ensure your mobile workers have all the tools they need to efficiently complete their tasks.
Work with task layouts
A layout is a grouping, or container, for actions available during each stage of the task workflow.
The following are questions to consider when building or editing layouts for tasks:
  • What actions are essential for each task status? Determine which actions are necessary for mobile workers to complete tasks efficiently at each stage (for example, Pick up, Directions, and Complete).
  • How should the layout change based on task status? Consider how the visibility and arrangement of actions should adapt as the task progresses through different statuses (for example, Unassigned, In Progress, and Completed).
  • What information do mobile workers need at each stage? Ensure that the layout provides all the necessary information and tools for mobile workers to perform their tasks effectively at each stage.
  • Are there any specific conditions that should control layout visibility? Identify any additional factors, beyond task status, that should influence when and how layouts are displayed (for example, task priority and location).
  • Are there any specific conditions that should control the visibility of a specific action beyond what’s already defined for the layout? Identify any additional factors that should influence when and where an action is displayed. For example, showing the Finish edit action only if the task feature has at least one attachment. See Create a conditional visibility expression for more information.
  • How can I streamline the task completion process? Look for ways to simplify the layout and reduce the number of steps required for mobile workers to complete tasks, enhancing overall efficiency.
To configure layouts, complete the following steps:
  1. On the Forms page, click the Tasks tab to see the All layouts view.
  2. To edit a layout, click on the layout to open it in the layout builder, where you can add, modify, or delete actions.
    The layout builder includes a center canvas showing how actions will appear in Field Maps and a Layout properties pane for renaming the layout and controlling its visibility with Arcade expressions.
    Each layout has a default visibility expression controlled by the task status field. For example, the Unassigned layout visibility expression makes it so the layout only appears if the task status field value is unassigned. The expression is DomainName($feature, “esritask_status”) == “Unassigned”.
    The same pattern is applied to the other default layouts. However, you can customize when layouts are visible by editing the Arcade expressions. This is helpful if you have other factors that should determine layout visibility aside from the status of the task.
To edit Arcade expressions, complete the following steps:
  1. Click the Expressions button next to the Visible check box.
  2. Click the overflow menu next to the selected expression and click Edit.
    The Expression builder window appears. The builder allows you to write an expression and preview it in Arcade before saving it.
  3. If you want to edit the Arcade syntax directly, click Launch Arcade editor.
  4. Once you’re finished editing, click Done.
Tip:
You can use the ArcGIS Arcade assistant (beta) to generate ArcGIS Arcade expressions from instructions typed in natural language.
Work with actions
Configuring task actions involves setting up interactive buttons or menu items that enable mobile workers to perform specific actions in their tasks in the Field Maps mobile app.
The actions mobile workers need are configured inside of the individual task layouts as follows:
  • Add new actions—Drag and drop new actions from the Layout elements pane onto the canvas. For example, you can add a Take photo action to allow mobile workers to capture images of tasks. The actions will display in the mobile experience hierarchically; four buttons and an overflow menu. You can drag an action to re-order it. You can also indicate which action is the primary action for the mobile worker, which will be highlighted in blue in Field Maps.
  • Duplicate or remove actions—When you hover over an action on the canvas, duplicate and delete options appear.
  • Configure actions—On the layout canvas area, click on an action (for example, Edit) to configure its properties, such as Display name, Icon, and Primary action. You can also manage which fields are updated automatically and manually when the action is used.
  • Add visibility expressions—You can conditionally display an action based on an Arcade expression. For example, if there is at least one attachment, you can choose to display an action to advance the task’s status to the next step. On the Layout canvas area, click on an action (for example, Finish) to configure its visibility expression. See Create a conditional visibility expression for more information.
Supported task actions
Field Maps includes the following task actions:
Name
Attach
A group of actions that includes Choose file, Choose media, Record audio, Take photo, and Take video.
Choose file *
Attach a document to the task feature.
Choose media *
Attach a photo, video, or audio file to the task feature.
Collect here *
Collect a new point feature at the location of the task.
Compass *
Get oriented toward the location of the task.
Delete *
Delete the task feature.
Directions *
Get directions to the location of the task using a navigation app on your device.
Divider
Add a visual separator between actions.
Edit field
Update fields automatically or prompt users to update fields manually. See Edit field action.
Edit form *
Edit the form associated with the task feature layer.
Favorite *
Add the task location to your favorites list.
Integration
Link to another app, such as Survey123, or initiate Field Maps workflows using custom links.
Menu
Group actions within a single menu.
Record audio *
Record audio and attach it to the task feature.
Related records *
If the task layer has a related table, view and modify related records.
Take photo *
Take a photo and attach it to the task feature.
Take video *
Take a video and attach it to the task feature.
Actions in the table marked with an asterisk * are system actions, meaning their name and icon properties cannot be changed.
Default edit actions
The default task configuration includes multiple edit actions. The action titles and field updates are pre-configured to allow a full task workflow. They are:
Name
Finish
Changes the status to Completed using an automatic update.
Pick up
Assigns the task to the current user. Includes two automatic updates with Arcade expressions that change the status to Assigned and the assignee to the current user.
The Arcade expression for esritask_assignee field uses CURRENT_USER to return the signed-in username. This is not supported by Arcade outside of the tasks configuration.
Start
Changes the status to In Progress using an automatic update.
Status
Presents the user with a prompt to manually update the status from a list.
Note
Presents the user with a prompt to enter text for the Notes field.
Task edit actions
There are two types of updates that can be configured for Edit actions—automatic or manual. Each edit action can initiate a single manual edit and multiple automatic edits. When configuring an edit action, you can choose from the following update types:
  • Manual—You can manually select a field you want mobile workers to edit. A prompt appears on the mobile device, allowing them to enter data or select a value. The type of prompt is determined by the field data type and any form element configured for that field. For example, a date field causes a calendar pop-up to appear, and a field with a combo box configured in the form shows the choice list that was configured in the form.
  • Manual and automatic—You can configure options for both manual and automatic updates. You can add additional automatic calculations and run multiple Arcade expressions, each writing to a different field.
  • Automatic—You can choose or create an Arcade expression and the feature action automatically runs the expression and writes the output to the field you selected. You can also add additional automatic calculations and run multiple Arcade expressions, each writing to a different field.
Caution:
Edit actions cannot be configured with manual edits for subtype fields or fields that are associated with a multiple choice form element.
When using edit actions, any expressions or validation present in the form will be used. If a field is required in the form, then it will also be required when using an edit action. It is not recommended to have form-based and task-based Arcade expressions writing to the same field because calculated expressions in the form will be executed when an edit action is used.
Task action examples
Edit field
The Edit field action allows mobile workers to update individual task fields. This can be applied to any field you want mobile workers to have access to edit, with the exception of subtype id fields or those that are part of a field group.
Add notes to a task
For example, if you want mobile workers to add their own notes to a task, you can configure a Notes action to edit the notes field in the task layout.
A Notes field is included by default when you create a new task-enabled layer. You can see how the Notes action is configured under the Action properties in the default In Progress layout.
Include a Notes action in the task layout by completing the following steps:
  1. Click the Tasks tab for the task layer and open the layout where you want to provide mobile workers a way to add a note.
  2. In the Layout builder panel, locate the Edit field element. Drag it onto the layout canvas.
  3. Change the field Display name to Notes, choose the update type Manual and select the corresponding field from the task layer.
Mobile workers are prompted to add or update their notes directly within the task in the Field Maps mobile app. Any formatting and expressions built in the form for that field will be honored while editing.
If a task feature has at least one attachment, you can choose to show the Finish edit action with the following conditional visibility Arcade expression: Count(Attachments($feature)) > 0. Add visibility expressions by completing the following steps:
  1. While configuring the layout, click an action to open it's properties.
  2. In the Logic section, click the Expressions button next to the Visible check box.
    The Expressions pop-up appears, displaying expressions previously created for the task's configuration.
  3. Click + New expression.
    The Expression builder window appears. The builder allows you to write an expression and preview it in Arcade before saving it to the selected action.
  4. In the Title text box, add a title for your expression.
  5. Define the expression.
    Each expression is defined by one or more conditions. A condition includes a field name, an operator, and potentially, a value. The list of available operators is determined by the type of field (string, number, or date).
    For example, if an Inspect action only needs to appear if the task type is Hydrant Inspection, the following conditions can be used to build the expression:
    • Field name—Task
    • Type Operator—is
    • Value—Hydrant Inspection
    If you use multiple conditions, you can choose whether all conditions must be true or if only one condition must be true for the action to be displayed.
    Here is what the expression looks like in Arcade syntax:
    DomainName($feature, "esritask_type") == "Hydrant Inspection"
    Field Maps Designer applies the Arcade Form Constraint profile to evaluate whether a feature meets the criteria defined in the expression. In the example above, if a value other than Hydrant Inspection is used, the Inspect action will not appear for a given task.
    To create more complex expressions, click Launch Arcade editor.
  6. Click Done.
    Now that you've saved your expression, you can apply it to any action. You can see which actions or layouts are using the expression by clicking the number next to the expression in the Expressions pop-up. See Reuse Arcade expressions to learn more.
Tip:
Integration
The Integration action is powerful in that it allows you to link to any app that supports deep links. This incudes apps like ArcGIS Survey123 or ArcGIS Navigator, and also includes Field Maps itself. This enables seamless transitions between a task and other aspects of your mobile workflows, even directly initiating Field Maps workflows (like adding related records or new features) in the Tasks map itself.
For example, mobile workers could tap on an integration action to open a specific form in ArcGIS Survey123, pre-populate information in a Microsoft Teams message to discuss a certain task, or access a work order in a customer relationship management (CRM) system.
You can also use integration actions to allow mobile workers to add and update features or add related features directly in the Field Maps mobile app.
Link to an app
You can use the Link property of the Integration action to add a link.
For example, you can link to a Survey123 survey by entering the link in the following format:
arcgis-survey123://?itemID=565e3b97e3a34215930
Tip:
You can rename an integration action to match the link destination, for example, Open survey.
Create dynamic links
You can link to other apps dynamically by creating calculated expressions. For example, you may want to add conditional logic so a different survey opens depending on the task type—or you may want to use multiple expressions to build the link itself.
To create a calculated expression, do the following:
  3. Drag an Integration action onto the canvas.
  4. Specify a display name for the action.
  5. In the Link section, type: arcgis-survey123://?itemID=
  6. Click the Expressions button next to the Links section.
    The Expressions pop-up appears, displaying expressions used elsewhere in the tasks configuration.
  7. Click + New expression.
  8. Write your expression in the Arcade editor.
    For example, you can create an expression that uses the task type to return a Survey123 item ID to link to a specific survey:
    if (DomainName($feature, "esritask_type")== "Inspect tree"){
                  return "565e3b97e3a342159303d14a9fefc783"
                  else if (DomainName($feature, "esritask_type")== "Remove tree"){
                  return "37627a597a7140d8bebdfa471039595b"
                  else {
                  return "e7ee0dd366024ba5a727df5a82bbacde"
  9. Click Done.
    You can now append the expression to the itemID parameter of the app link, for example:
    arcgis-survey123://?itemID={exp/survey-type}
    The expression is automatically added to the text in the Link property. When a mobile worker taps the action in Field Maps, the survey linked to the task type is opened.
Add and update features or add related features
When completing tasks, you can update or add features to a layer (in the same map or a different one) using the Integration action. For example, if you notice a hazard while completing an inspection task, you can use a configured integration action to capture the hazard in a separate layer. You can also use a configured integration action to record the inspection information in a related table.
Integration actions are powered by URLs. You can configure the integration action with an app link. By customizing the link, you can control what app and map the action links out to, the layer and feature that can be updated, the action that can be taken (either adding or updating a feature), and the attributes that are passed via the link.
App links use a consistent format, with a reference context followed by one or more parameters. The following examples show common app links that could be launched from a tasks integration action:
  • Add a feature
    https://fieldmaps.arcgis.app?referenceContext=<action>&itemID=<ID>&featureSourceURL=<URL>
  • Add a related features
    https://fieldmaps.arcgis.app?referenceContext=<action>&itemID=<ID>&featureSourceURL=<URL>&primaryKeyField=<fieldname>&relationshipID=<relationship index>
    The relationshipID is an optional parameter available in Field Maps 26.1 used to target specific related tables.
  • Update a feature
    https://fieldmaps.arcgis.app?referenceContext=<action>&itemID=<ID>&featureSourceURL=<URL>&featureID=<ID>
The following parameters are required for app links that add and update features:
  • referenceContext—The reference context parameter determines the action taken when the map and layer are open. For example, you can use addFeature, addRelatedFeature, or updateFeature depending on whether you want the action to initiate adding a new feature, update an existing feature, or adding a related record.
  • itemID—The item ID parameter determines the map that the link should open. This should be equal to the item ID for the map containing the layer you want to update. The item ID for the map is displayed in the URL of the map’s item details page and when the map is open in Field Maps Designer.
    If an app link is going to add or update data in an offline area, the itemID parameter should not be included in the link.
  • featureSourceURL—The feature source URL parameter should be equal to the URL of the layer being updated. This can be found on the item details page for the layer.
  • featureID (updateFeature and addRelatedFeature)—The feature ID parameter should match the GlobalD field of the feature being updated.
  • primaryKeyField (addRelatedFeature only) —The parent record field you want to pass through to the key in the related (child) record.
The following parameters are optional for app links that use the addRelatedFeature reference context:
  • relationshipID - The index of the relationship class linking the parent feature with the target related table. This is used when the target table is not the first table related to the parent feature class through the same primaryKeyField value.
There are additional parameters you can add to further customize the app link, such as defining the location where a new feature is added (if not defined, current location is used by default), high accuracy settings, adding to and updating related tables, and whether certain fields are automatically filled in when creating a new feature. To learn more about all the parameters you can use to create these links, see Initiate capturing a feature, Initiate updating a feature, and Add a related feature.
Build an app link with Arcade
You can use Arcade expressions to build a custom link with the Integration action.
For example, in a tree inspection workflow, you could use an Arcade expression to open a tree inspection form (related record) right from the task in the Field Maps mobile app.
Reuse Arcade Expressions
After you create an Arcade expression, you can reuse it across multiple task actions. For example, you can conditionally display one action based on the same expression used to require another action. Reuse expressions by completing the following steps:
Caution:
Layout expressions must be unique. Do not reuse the same expression for multiple layouts.
  1. While configuring task actions, click on an action to open the Properties pane.
    You can also click on a specific layout to open it's Properties pane.
  2. In the Logic section, click the Expressions button.
  3. Select the expression you want to apply.
  4. Click Save.
Manage filters for to-do lists
Filters in Field Maps allow mobile workers to view tasks based on specific criteria that you define. Each filter is defined by an expression that determines which tasks will appear in the Field Maps mobile app. You can create your own filters or use the default filters. There must be at least one task filter defined in the map or tasks to-do lists will not display in Field Maps.
Configure task filters
To configure task filters, navigate to the Tasks tab in Field Maps Designer and click on Task settings. The Task settings pane will display the default task filters.
Here, you can manage filters in the following ways:
  • Reorder filters—Click and drag to reorder filters. The first filter in the list will be automatically presented when the map is opened in the Field Maps mobile app.
  • Duplicate or remove filters—Click the Overflow button to duplicate or remove filters.
  • Edit filter expressions—Click the Filter button to manage the expression that define the filter.
  • Add new filters—Click + New filter to add a new task filter.
  • Define Sort by fields—Click Edit sort by to reorder and update the Sort by list. The field at the top of the list is the default sort option. If you include the Distance option, the mobile worker's task list can be sorted based on the geographic proximity of each task to the mobile worker's current real-time GPS location.
    The Sort by list cannot be empty. You must select at least one field or the Distance option under Edit sort by.
Field Maps uses filters to manage the display of the task to-do list. You cannot add separate filtering in the Layer Filters section under App Settings in Field Maps Designer.
Work with the default task filters
When you create a new task-enabled layer, the default filters Assigned to me, Unassigned, and Completed are available. You can customize or remove these filters.
Assigned to me
The Assigned to me default filter gives the mobile worker a list of the outstanding tasks that have been assigned to them. To do this, it uses the following conditions:
esritask_assignee = ‘CURRENT_USER’ AND NOT(esritask_status = 3), where:
  • esritask_assignee = 'CURRENT_USER' filters tasks assigned to the signed-in user.
  • NOT(esritask_status = 3) ensures that tasks with a status of Complete (default code value = 3) do not appear.
'CURRENT_USER' is unique syntax for task configuration and is replaced with the username of the signed-in user in the Field Maps mobile app.
Completed
The Completed default filter gives the mobile worker access to a list of the completed tasks that they have done. To do this, it uses a similar expression to the Assigned to me default filter above without the NOT condition, so only tasks with the Complete appear:
esritask_assignee = ‘CURRENT_USER’ AND esritask_status = 3
Unassigned
The Unassigned default filter gives the mobile worker access to a list of tasks that have not been assigned to anyone. This is helpful for workflows where mobile workers should be able to pick up unassigned work. This filter uses one condition to display tasks that have not been assigned:
esritask_status = 0
Create additional task filters
You can create your own task filters in Field Maps to customize which tasks appear in to-do lists in the mobile app, ensuring that the right tasks are visible to the right people at the right time.
To create a new task filter, do the following:
  1. Click + New filter.
  2. Enter a label and definition expression.
  3. Click Done.
  4. Click Save to save the map in Field Maps Designer.
  5. Reload the map in the Field Maps mobile app to see the new filter.
Tips for creating filters:
  • Include esritask_assignee = 'CURRENT_USER' to ensure tasks only appear if they are assigned to the signed-in user. Omit this condition to view tasks assigned to everyone in your organization.
  • Filter expressions are written in SQL. For more information on SQL syntax, see SQL reference for query expressions used in ArcGIS.
  • Always save the map after creating a new filter and reload it in Field Maps to apply the changes.
Example filter expressions:
  • High priority tasks
    esritask_assignee = 'CURRENT_USER' AND ((esritask_priority = 3) OR (esritask_priority = 4))
  • Unassigned tasks for a specific crew
    esritask_status = 0 AND crew = 'truck2'
  • Tasks due between specific dates
    esritask_duedate BETWEEN DATE '2024-04-03' AND DATE '2024-04-04'
  • High priority unassigned tasks
    esritask_status = 0 AND ((esritask_priority = 3) OR (esritask_priority = 4))
