Tools and features
ArcGIS Field Maps allows you to access your maps, collect data, share your location, annotate your maps, and complete tasks in one mobile app, even when disconnected. You can communicate your ideas and share information with others with maps enabled for editing or the included personal markup tool. Use Field Maps alone or in combination with other ArcGIS field apps for greater efficiency in your field activities. The maps and capabilities you can access in ArcGIS Field Maps depend on what licenses you have. See Requirements to learn more about what licenses and privileges are required for collecting data and location sharing.
When using ArcGIS Field Maps, you'll work with the following:
Maps list—Find and open the maps that matter to you, and turn location sharing on and off.
Map and panel—Visualize and interact with your data, including initiating data collection.
Data collection form and Location target—If you’re working with an editable map, you can use the form and Location target when capturing a new asset or observation or performing an inspection and updating an existing asset or observation.
Tasks—Easily access and manage your work from to-do lists when using a map with a task-enabled layer.
Floor-aware map and floor filter—If you're working with a floor-aware map, you can edit indoor features and use the floor filter to display information about floors and buildings.
If you're using the Field Maps mobile app on a Windows device, you may be using a mouse and keyboard. See Mouse and keyboard interaction (Windows) for tips on using a mouse and keyboard to interact with Field Maps.
The information provided on the Android version of Field Maps help topics also applies to Field Maps on Windows. To learn how to install Field Maps on a Windows device, see How to install Field Maps on Windows.
Maps list
Find the maps you want to work with through browsing and searching. The available maps include those you've made or that are shared with a group of which you are a member. If you don't have a data connection, only on-device maps are included.
Search—Enter text to find a map. Your search term is used to filter the maps in the list. You can tap Read-only, Editing, or Tasks to limit the list to maps with these capabilities.
The Search function searches the maps displayed in the categories shown, as well as all publicly accessible maps on your portal (ArcGIS Online or ArcGIS Enterprise). Your search term is used to filter the maps on your screen as well as one or two additional categories—one titled with your organization's name and another titled ArcGIS Online. If you are using an Enterprise portal without the ability to search ArcGIS Online for content, you won't see the ArcGIS Online category.
Profile—View your currently signed-in account and the data collection, location sharing, and general settings associated with it.
Current section—Shows the open map. Tap the map card to return to the map. This section displays if you have an open map.
Map card—Open the map or access map areas. If the map displays the text Offline areas, it has offline map areas.
Maps without offline map areas can be opened and used without downloading the map to your device. You can add an offline map area if the map supports offline use.
Maps with offline map areas must be downloaded before they can be used. Tap the map to view, download, and manage the available offline map areas, or to add your own.
A map area with a download icon
can be downloaded to your device. A map area with an Overflow menu
is already on your device and can be synced or removed. If it is a map area you defined on the device, you can also rename it.On device section—Shows mobile map packages (MMPKs), geospatial PDFs, and maps with map areas downloaded to your device. If location sharing is enabled for your organization, the first map under On device is titled My tracks. You can turn location sharing on or off to set the duration and tap the map card to view the map of tracks collected on your device. See Share location to learn more about location sharing.
The On device section only displays if MMPKs, geospatial PDFs, or map areas are downloaded to your device, or if location sharing is enabled for your organization.
The My tracks map card will move to the Current section when it's the currently open map.
My maps section—Shows maps you own.
Groups section—Shows groups of which you are a member that have shared maps. This only displays if you are a member of any such groups. Tap a group card to view the maps in a group.
Search—Enter text to find a map. You can tap Read-only, Editing, or Tasks to limit the list to maps with these capabilities. Your search term is used to filter the maps in the list.
The search function searches the maps displayed in the categories shown, as well as all publicly accessible maps on your portal (ArcGIS Online or ArcGIS Enterprise). Your search term is used to filter the maps on your screen as well as one or two additional categories—one titled with your organization's name and another titled ArcGIS Online. If you are using an Enterprise portal without the ability to search ArcGIS Online for content, you won't see the ArcGIS Online category.
Tip:
If search isn't visible, pull down to display it.
is already on your device and can be synced or removed. If it is a map area you defined on the device, you can also rename it.On Device section—Shows mobile map packages (MMPKs or geospatial PDFs) and maps with map areas downloaded to your device. If location sharing is enabled for your organization, the first map under On Device is titled My Tracks. You can turn location sharing on or off to set the duration and tap the map card to view the map of tracks collected on your device. See Share location to learn more about location sharing.
The On Device section only displays if MMPKs, geospatial PDFs, or map areas are downloaded to your device, or if location sharing is enabled for your organization.
The My Tracks map card will move to the Current section when it's the currently open map.
My Maps section—Shows maps you own.
If you are using the app without signing in, your screen appears slightly different. You'll see the Sample Maps category, and the search function will search Sample Maps and ArcGIS Online. You can tap Profile
to sign in.
Map
Use the Maps list to open a map. When you open a map you can find, view, and capture assets or observations, mark up the map, and share notes with others.
The capabilities available in a map depend on the licenses you have and how the map is configured.
Back—Go back to the Maps list. If you opened the map from a group or list of map areas, the arrow takes you to the group or list of map areas in the Maps list.
Sync—The Sync icon
appears if you are working in an offline map area that’s part of a map that has been enabled for editing. Tap Sync
to send your changes. When the sync icon has a dot
, you have pending edits. See Sync your work.Depending on the configuration of the map you are using, sync may get changes that were made since your download and copy them to your device. See Optimize download and sync.
Layers—View the layers in the map, change their visibility, and see any errors. If layer filters were configured, a Filter button
appears next to the layer and can be used to filter features on the map based on attribute values. Filters can be defined on multiple fields within the layer, and features must meet all filtered values to display on the map. If the map contains branch versioned services, and the option to allow mobile workers to change versions is enabled, a Versions button appears. Tapping Versions displays the current named version in use and a list of versions that mobile workers can switch to.Search—Find addresses, places, assets, and observations. Search honors what is configured in the map. See Configure feature search in ArcGIS Online or Configure feature search in ArcGIS Enterprise. Finding addresses and places requires an internet connection. You can search for assets, observations, and coordinates without a connection.
Tip:
You can search by scanning a barcode or QR code. Start a search and tap Scan Barcode or QR code
.Overflow—Change the basemap, view and use bookmarks, view the legend, measure on the map, add personal markup to the map, or share a link to the map. If the map is enabled for editing, the option to edit multiple features appears.
When using personal markup, different tools are available. For more information, see Personal Markup.
Location banner—See information about your location. Tap the banner to see additional details, including the accuracy, time the position was received, and location provider. If location sharing is enabled for your organization, you can turn Share my location on and off and set the duration.
Map—View and interact with your assets and observations. Tap an asset or observation to view its form. You can pan, zoom in and out, and rotate the map. Long press to use a magnifier and drop a pin at a location of interest or search to get result pins on the map. Tap a pin to view its details.
Tip:
If you rotate the map, the rotation angle is shown by a compass
in the upper right corner of the map. Tap the compass to remove the rotation and orient the map north.Location button—Display where you are. It has three modes:
Your location displayed on the map (
)The map automatically centering on your location while oriented north (
)The map automatically centering on your location and oriented the direction you are facing (
Tap the Location button to switch between the centered modes. Pan the map to stop centering on your location. If your current location is unavailable, the icon is gray (
).Your location—Where you are. Recenter it on the screen by tapping the Location button. This displays while your location is in the current extent and ArcGIS Field Maps can access your location.
Features—View your assets as features on the map. Tap a feature on the map to see its details in the panel, including any attachments, related records, or media (including charts and images).
Add—The Add button
appears on maps that are enabled for editing. Start capturing an asset or observation at your location. This shows the data collection form and tools. See Capture.Panel—Tap an asset, observation, or personal markup to view additional information. Swipe the panel up to view more information at once. Here, the panel shows the form for the selected asset and the actions that can be taken with it. The panel can also show details of other items, such as search results and dropped pins, or it can show a list of results, such as the assets and observations selected on the map or search results. The panel is also used to display some specialized content, such as available basemaps or outstanding edits that can be synced.
When the panel displays a list, tap an item of interest to view its form (for assets and observations) or details (for pins). When displaying a single item (not a list or specialized content), the panel provides access to actions. Depending on the amount of information displayed, actions are available either in-line or on a toolbar.
Actions include Directions
, Compass
(to get distance and bearing to the location), and Favorite
.Note:
The Directions action is not supported on Windows.
If you tap on a polyline that contains measure values (m-values), the Measure action action
appears. Tapping Measure opens a dialog box displaying the m-value nearest to your location and the range of m-values within the polyline. From the Measure dialog box, you can enter the m-value you want to find. After tapping OK, a pin is dropped on the m-value's location. From here, you can use the Compass or Directions actions to navigate to the value. You can also add the value to your favorites list and collect a feature at the m-value's location. To learn more about m-values in the context of linear referencing, see Introduction to linear referencing.Note:
If the data in the polyline is invalid, an Unable to find measure dialog box appears and the error is written in the troubleshooting log. You can access the troubleshooting log by browsing to your Profile
and tapping Troubleshooting.Forms include the details about the asset or observation and access to any attachments. In addition to photos and videos, you can view attached audio clips, PDFs, Microsoft Word documents, and Excel spreadsheets if you have apps for them on your device. From the form, you can save attachments to your device. Tap the asset or observation's symbol to zoom to it. Depending on the editing permissions, you may also see actions for Edit
, Copy
, Delete
, and Collect Here
. If there are related assets, observations, or reports, you can jump to the Related items
. See Capture and Inspect.
Panel
Tapping an asset, observation, or markup and swiping the panel up allows you to view additional information at once. The panel shows the form for the selected asset and the actions that can be taken with it. The panel can also show details of other items, such as search results and dropped pins, or it can show a list of results, such as the assets and observations selected on the map or search results. The panel is also used to display some specialized content, such as available basemaps or outstanding edits that can be synced. When the panel displays a list, tap an item of interest to view its form (for assets and observations) or details (for pins). When displaying a single item (not a list or specialized content), the panel provides access to actions. Depending on the amount of information displayed, actions are available either in-line or on a toolbar.
Edit
-Edit the data collection form.Copy
-Copy the data collection form.Collect Here
-Collect data at the current location.Directions
-Get directions to a location.Compass
-Get distance and bearing to a location.Favorite
-Add a location to your favorites list.Delete
-Delete the asset, observation, or markup.Attachments -Forms include the details about the asset or observation and access to any attachments. In addition to photos and videos, you can view attached audio clips, PDFs, Microsoft Word documents, and Excel spreadsheets if you have apps for them on your device. From the form, you can save attachments to your device.
Find Measure
-If you tap on a polyline that contains measure values (m-values), the Find measure action appears. Tapping Find measure opens a dialog box displaying the m-value nearest to your location and the range of m-values within the polyline. From the Find measure dialog box, you can enter the m-value you want to find. After tapping OK, a pin is dropped on the m-value's location. To learn more about m-values in the context of linear referencing, see Introduction to linear referencing.
Tip:
A related asset, observation, or inspection (report) is accessed through the form of the asset or observation to which it is related. Use the Related section of the form to select a related asset, observation, or inspection. Depending on what is supported by your relationship, you can add new related items, view read-only forms, and start editing. See Capture an asset or observation related to another and Add a related report.
Data collection form and location target
If the currently open map has been enabled for editing, you can collect data using the data collection form. The data collection form opens when you start capturing a new asset or observation or inspect an existing one. When filling out a form, use the Location target to update the asset or observation's location. To start filling out a form and providing location, use the map and read-only form.
Cancel—Stop capturing a new asset or observation, or discard edits made to an existing one during an inspection.
Submit—Save the new asset or observation, or save the changes made to an existing one. If you're working online, others immediately see your edits. If you're working offline, your edits are available to others once you sync
them.Location banner—See information about your location. Tap the banner to see additional details, including the accuracy, time the position was received, and location provider. If location sharing is enabled for your organization, you can turn Share my location on and off.
Location button—Recenter the Location target on your location.
Location target—Where an asset or observation (or a point in the location of a length or area) will be placed on the map. It is composed of a circle and crosshairs. It displays if your layer allows updates to the location. See Capture, including the Edit location section.
- If the location meets the required accuracy, the circle of the Location target is blue, as is the text in the Location banner. Otherwise, the circle and text are red.
The circle isn't an accuracy indicator. Use the Location banner for accuracy information.
Form—Fill out entries to provide information. You can expand the panel to see more of the form while filling out entries. See Fill out forms.
Overflow—Edit the location, such as undoing changes, updating and deleting points, and streaming.
Update Point (single places)—Move the asset or observation under the Location target. This displays if your layer allows updates to the location.
It is replaced by Add Point for lengths and areas, which adds a point to the asset or observation under the Location target.
Take Photo and Attach—Add photos and videos. This displays if your layer supports attachments.
Form entry—An entry in the form where information can be provided.
When working with the map outside of data collection, a blue dot on the map shows your location. This is intentionally hidden during data collection when the map is centered over your location—the dot obscures the area around you, which is often your area of interest.
Tasks
View tasks
When a map with task layers is created in Field Maps Designer, Field Maps includes a digital task list that helps you find and manage your tasks throughout the day. When you tap and open a map from the Maps list, tasks you have been assigned to will appear in the map’s task list. You can search, filter, and customize your view of the tasks lists.
Search—Search in the task list to find relevant tasks or configure what tasks appear in the list. In the task list search bar, enter keywords to dynamically filter the list based on the details included in individual tasks.
Task list—Pull up on the panel to see all the tasks in the list. If no tasks have been created, the task list will be empty.
Filter—You can filter, sort, and select what information to show in the task list in the following ways:
Filter—Task filters enable you to switch between different to-do lists. If you have more than one to-do list, tap on the display options filter icon to the right of the search bar to access other to-do list filters. These to-do list filters are managed by the map author. By default, Field Maps includes the following to-do list filters, but if they have been modified, your options may be different:
Assigned to me
Unassigned
Completed
Sort—Tap Filter next to the search bar to select the Sort by criteria and order for the display of your task to-do list. Tap once on a Sort by option to select that field. Tap a second time to reverse the sort order. Sort options include:
Distance
Type
Priority
Due Date
Status
The Sort by list may be different if the author has changed or configured the list of fields that you can sort by. See Configure task filters for more information.
Show Info—Tap Filter next to the search bar and tap Show Info to select which subtitle information is displayed for each task in the to-do list. The default subtitle is location.
If new fields are added to the task details, those fields will become options to select from in the Show Info settings.
Work with tasks
Working with tasks in Field Maps involves a series of straightforward steps that guide you from starting the task to marking it as finished. Field Maps comes with a default set of statuses, layouts, and actions to provide a guided work experience. Map authors can modify these statuses, add new ones, and customize layouts and actions. This means that the task workflows you see may vary based on the specific configuration set by the map author.
Action buttons—Action buttons provide ways to manage tasks in Field Maps. Actions include things like Start or Finish to progress a task through various stages. Actions can also connect you to other apps to complete task workflows. To learn more, see Supported task actions and Integration. Field Maps can display up to four action buttons at a time in an open task. When there are more than four action items, the fourth button becomes an overflow menu, providing you with access to all the additional action items that have been configured for you.
Task information—Swipe up on the panel to view all the information provided about your task in the pop-up (e.g. due date, notes, etc.).
Close—Close the task and go back to the task to-do list.
Task notifications
Task notifications are designed to keep mobile workers informed about new assignments in their default list. When a new task is assigned to you, you will receive a notification on your mobile device. Notifications are dependent on connectivity. If you are offline, notifications will not come through until you have restored connectivity. Notifications are available for the first Tasks filter only. With the default configuration of tasks, you’ll see notifications for the Assigned to me filter. You can also add additional notifications by using geofences. When you tap on a notification, it will automatically launch Field Maps, load the appropriate map, and open the specific task. When more than 10 new tasks are added at once, the notification message is grouped and tapping the notification will open the map and display the open task to-do list.
To receive task notifications, you must give your system permission to send notifications. The system permission prompt for notifications appears the first time a map with tasks is opened. If you deny the system permission, you won’t receive notifications, but you can still use the map and the task list will update automatically. If you accept the permission, notifications will start to work once the Field Maps app is relaunched. Notifications appear when the app is open. You will not receive notifications for tasks that you create and assign to yourself.
Notifications are only sent if the person assigning the task and the assignee have different usernames. If a worker assigns a task to themselves, they will not receive a notification.
When you open a floor-aware map in Field Maps, you can use the Floor filter to display floor information based on the building in the visible map extent. The Floor filter appears if the following requirements are met:
The map must be floor-aware.
A facility must be in the visible map extent.
You can view floor-aware maps and edit floor-aware layers in Field Maps.
View floor-aware maps
Filter indoor assets by floor and view information about floors and buildings.
appears next to the layer and can be used to filter features on the map based on attribute values. Filters can be defined on multiple fields within the layer, and features must meet all filtered values to display on the map. If the map contains branch versioned services, and the option to allow mobile workers to change versions is enabled, a Versions button will display in the layers tool. Selecting the Versions button will display a list of versions that mobile workers can change to.Search—Find addresses, places, assets, and observations. Search honors what is configured in the map. See Configure feature search in ArcGIS Online or Configure feature search in ArcGIS Enterprise. Finding addresses and places requires an internet connection. You can search for assets, observations, and coordinates without a connection.
Tip:
Overflow—Change the basemap, view and use bookmarks, view the legend, measure on the map, add personal markup to the map, or share a link to the map. If the map is enabled for editing, the Edit Multiple features option appears.
When using personal markup, different tools are available. For more information, see Use personal markup.
Location button—Display where you are. It has three modes: your location displayed on the map (
), the map automatically centering on your location while oriented north (
), and the map automatically centering on your location and oriented the direction you are facing (
). Tap it to switch between the centered modes. Pan the map to stop centering on your location. If your current location is unavailable, the icon is gray (
).Floor filter—Display floor information for the building in the center of the visible map extent. Tap the Floor filter to expand the list of available floors. Choosing a floor filters the features in that facility based on the Floor Field parameter. The Floor filter disappears if no facilities are present in the visible map extent.
Floor panel—View additional details about the selected floor. Collapsing the Floor filter closes the panel.
Edit floor-aware layers
When editing floor-aware layers, the floor value is automatically generated from the floor filter, as shown in the image below. You can tap on the floor value to change it while filling out the form.
To learn more about indoor data collection, see Capture at an indoor location.
If you're using the Field Maps mobile app on a Windows device, you may be using a mouse and keyboard. For tips on using a mouse and keyboard to interact with Field Maps, see the following table:
Map action |
Mouse and keyboard interaction |
Zoom in and out |
Ctrl +mouse wheel |
Zoom in |
Double-click |
Zoom out |
Alt +double-click |
Drop a pin |
Right-click |
