Prepare for high-accuracy data collection
The accuracy required when collecting location data depends on the project you are working on. For some projects, such as damage assessments, points within 10 feet of the damage may provide enough information. For other projects, such as managing underground pipelines, the location collected must be within a few centimeters of the actual location. When collecting location information using a device's location service, position information can be determined from various sources, such as GPS, cellular, Wi-Fi, or Bluetooth networks. The accuracy of these sources varies, and the device's location service is not always reliable. For those who perform data collection that requires higher accuracy and reliable quality control, using a professional-grade or high-accuracy GPS receiver is usually the best option.
You can also learn about the basics of high-accuracy data collection by listening to the following episode of the Field Notes podcast: Covering the basics of high-accuracy data collection (12 minutes).
Global Navigation Satellite System (GNSS) is the standard generic term for navigation satellite systems. GNSS receivers are capable of using various navigation satellite systems, while GPS receivers can only use the navigation satellite system called the Global Positioning System. Due to the widespread use of the term GPS to refer to both types of receivers, the term GPS is used as the generic term in this help documentation.
A high-accuracy GPS receiver precisely calculates geographic locations using information from GPS satellites. The accuracy of these receivers ranges from submeter to centimeter, depending on their ability to track and process satellite signals. GPS satellite signals are transmitted on different frequencies. The more frequencies the GPS receiver uses—and, consequently, the more signals it receives—the more accurate it is. This is also true for GNSS—the more systems the receiver uses (and the more signals it receives), the more accurate it is. Today, multiple navigation satellite systems are available. However, in most cases, the more accurate a GPS receiver is, the more expensive it is and the more difficult it is to carry in the field. You can also improve the accuracy of your position information through differential corrections of the data, supported by some receivers and covered later in this topic.
See the following sections to use a high-accuracy receiver with ArcGIS Field Maps:
Prepare your data to record GPS metadata
In addition to geographic coordinates, you can also save other GPS metadata associated with a feature, such as its accuracy and fix type. Storing this metadata can be valuable to assess data quality and ensure data collection standards have been met. If you include GPS metadata fields in your feature layer, Field Maps can write GPS metadata to the respective fields when editing features.
While this topic is focused on high-accuracy receivers, these steps enable recording the metadata from any GPS, including the internal GPS of a device. Not all metadata fields are populated by all GPS receivers.
Keep the following in mind before configuring GPS metadata storage:
  • GPS metadata is populated on point, line, and polygon layers.
  • GPS metadata is cleared for a point feature if the point's location is provided or updated without using the GPS or while metadata is not available.
  • To capture GPS metadata for line and polygon features, attachments must be enabled for the feature layer.
  • When configuring the feature and attachment delivery setting for line and polygon feature layers, you must select an option that includes attachment delivery.
The recommended way to add the fields depends on how you prepare your layers:
  • In Field Maps Designer or the Home app, enable the Will high-accuracy receivers be used to collect data? setting and, optionally, the Will GNSS receivers that support tilt-compensation be used to collect data? and, the Will laser rangefinders be used to collect data? setting while creating a new feature layer.
    • If you have ArcGIS Enterprise 11.5 or earlier, you can use the Add GPS Metadata Fields Python notebook to add offset metadata.
    • If you have ArcGIS Enterprise 12.0 or earlier, you can use the Add GPS Metadata Fields Python notebook to add offset metadata.
  • Use the Add GPS Metadata Fields tool after creating your point, line, and polygon feature class.
    • ArcGIS Pro 3.5 or later supports configuring offset metadata fields.
    • ArcGIS Pro 3.8 or later supports configuring tilt-compensation fields.
    • If you have ArcGIS Pro 3.4 or earlier, you can use the Add Offset Metadata Fields (Pro) notebook.
    • If you have ArcGIS Pro 3.7 or earlier, you can use the Add Offset Metadata Fields (Pro) notebook to add tilt-compensation metadata.
  • Follow these tips to ensure all GPS metadata fields are included on your layers:
    • Use the GPS metadata actions on an existing hosted feature layer that has already been published. This can also add any missing GPS metadata fields that may not be present in an existing hosted feature layers that are published. This is not supported on ArcGIS Enterprise feature services.
    • If you have ArcGIS Enterprise, you can use the Add GPS metadata fields-feature layer notebook you want, to add GPS metadata fields to an existing hosted feature layer that has already been published. This is not supported on ArcGIS Enterprise referenced feature services.
Supported GPS metadata
If using a single GPS location to set a point's location, the following GPS metadata values are recorded:
  • Receiver name
  • Position source—Source used to collect the point or vertex, including the following possible values: User defined, Integrated (System) Location Provider, External GNSS Receiver, or Network Location Provider, Snapped
  • Latitude—Position received from the GPS receiver before applying data transformations in the location profile in degrees
  • Longitude—Position received from the GPS receiver before applying data transformations in the location profile in degrees
  • Altitude—Ellipsoidal height (HAE) in meters received from the GPS receiver (not orthometric height, as used for z-values)
  • Orthometric height—Elevation in meters received from the GPS receiver, typically defined as mean sea level (MSL)
  • Horizontal accuracy—Stored in meters in RMS
  • Vertical accuracy—Stored in meters in RMS
  • Fix time
  • Fix type—Position solution status, including the possible values: 0—Fix not valid, 1—GPS, 2—Differential GPS, 4—RTK Fixed, 5—RTK Float
  • Number of satellites—Number of satellites used when the position is computed
  • Correction source type—Correction service type, including the following possible values: Unknown, Direct IP, NTRIP, PPP, Radio, SBAS
  • Correction source name—Name of correction service
  • Correction age—Age of correction data in seconds
  • NTRIP mount point—Name of mount point
  • Station ID—Reference station ID
  • PDOP
  • HDOP
  • VDOP
  • Direction of travel (degrees)
  • Speed (km/h)
  • Azimuth (degrees)
  • GNSS antenna height—Ground to Antenna Reference Point (ARP) in meters
  • Geographic coordinate system—Name of geographic coordinate system (GCS) from GPS receiver
  • Geographic coordinate system WKID—Authority code of GNSS position from GPS receiver
  • Reference epoch—Epoch of the position coordinates in the coordinate reference system in decimal years
  • Location profile horizontal datum transformation applied—Indicates if a horizontal transformation was applied by the location profile, including the following possible values: 0—No, 1—Yes
  • Location profile horizontal datum transformation—Location profile’s horizontal transformation name if one is applied
  • Receiver geoid model—Geoid name, typically including area of use
  • 95% accuracy applied—Whether 95% accuracy was applied, including the following possible values: 0—No, 1—Yes
  • GNSS custom attributes
If using a single GPS position by a GPS receiver that supports tilt-compensation, the following GPS metadata values are recorded:
  • Tilt compensation—Indicates if the position was tilt-compensated. Possible values: 0—No, 1—Yes
  • Tilt angle—Direction of pole tip to antenna reference point in degrees
  • Tilt angle accuracy—Standard deviation of tilt angle in degrees
  • Tilt azimuth—Tilt angle in relation to z-axis in degrees
  • Tilt azimuth accuracy—Standard deviation of tilt direction in degrees
If performing GPS averaging to set a point's location, the following GPS metadata values are recorded:
  • Receiver name
  • Latitude—Averaged latitude values of positions received from the GPS receiver before applying data transformations in the location profile
  • Longitude—Averaged longitude values of positions received from the GPS receiver before applying data transformations in the location profile
  • Altitude—Averaged ellipsoidal height values of positions received from the GPS receiver
  • Fix time
  • Position source
  • Average horizontal accuracy—Averaged horizontal accuracy values of positions received from the GPS receiver, stored in meters (RMS)
  • Average vertical accuracy—Averaged vertical accuracy values of positions received from the GPS receiver, stored in meters (RMS)
  • Number of positions averaged
  • Standard deviation (mean)—An indication of the variation in meters between your final, averaged location and each individual location recorded during averaging. A high value indicates that your position was influenced by outliers.
The following GPS metadata values are recorded by Field Maps when using a line or polygon layer:
  • Worst horizontal accuracy
  • Worst vertical accuracy
  • Worst fix type
  • Number of manual locations (for example, snapping, using a location by defining on the map)
You can choose which of these you record with your data: the values are ignored for any fields you don't add to your feature layer. Similarly, you can set up your data for single GPS locations, averaged locations, or both: when averaging is enabled, the associated fields are populated and those for single-location collection are left blank, and vice versa.
If you enable a 95 percent confidence level for accuracy in the Field Maps settings, a 95 percent confidence level is used to determine whether your accuracy is acceptable for data collection. The recorded accuracies are still calculated using root mean square (RMS). As such, the level of confidence in the recorded accuracies is 63 percent to 68 percent for horizontal accuracy and 68 percent for vertical accuracy.
Choose a receiver
Field Maps can make use of the GPS built into your device or you can add an external GPS receiver to obtain high-accuracy data. There are many GPS receivers available on the market; however, not all of them work directly with Field Maps.
To improve the accuracy of your positions, consider using a GPS receiver that supports differential corrections. If you are using an iOS device, you must also choose one of the GPS receivers supported on iOS. While Esri doesn't publish a list of supported GPS receivers for Android, a list of receivers used in testing Field Maps on Android is provided.
Field Maps supports two methods of connecting to a receiver: via the device manufacturer’s companion app, or directly via Bluetooth.
If you are using real-time kinematic (RTK) positioning, you must provide access information for the correction source being used. Use your GPS device's companion app and reference the device's user manual for details.
Connection options vary between GPS manufacturers and devices. For devices that support both methods, refer to your GPS manufacturer's documentation for recommendations on which connection method to use.
The following receivers can be used with Field Maps on supported iOS devices via Bluetooth only:
  • Asteri X1i
  • Bad Elf GNSS Surveyor, GPS Pro+, GPS Pro, and GPS for Lightning Connector
  • Dual XGPS160
  • Emlid Reach RX MFi, RX2, RS4, RS4 Pro
  • Garmin GLO and GLO 2
  • Geneq SxBlue II and SxBlue III
  • Juniper Systems Geode GNS3H, GNS3M, GNS3S
  • SparkPNT TX2, SparkPNT Facet FP
The following receivers can be used with Field Maps on supported iOS devices using the manufacturer's companion app or via Bluetooth:
  • Bad Elf Flex, Bad Elf Flex Mini
  • Eos Arrow Lite, Arrow 100, Arrow 100+, Arrow 200, Arrow Gold, Arrow Gold+, and Skadi
  • Leica Zeno GG04 plus and FLX100 plus
The following receivers can be used with Field Maps on supported iOS devices using the manufacturer's companion app only:
  • Leica GS05
  • Radiodetection RD8200SG, RD8200MRX
  • Subsite Utiliguard2-RTK
  • Trimble R1, R2, R580, R780, R780-2, R980, R10 Model 2, R12, R12i, and Catalyst DA2
To directly connect a Bluetooth receiver with an iOS device, the receiver must be part of the MFi program as well as support the output of NMEA sentences.
Check the documentation provided by the receiver manufacturer for the recommended firmware version.
To determine the current firmware version of your GPS receiver, pair your receiver with your device, open your device's General settings, tap the About tab, and tap the name of your paired receiver. If your receiver has separate versions for the receiver and Bluetooth firmware, use the app provided by your receiver manufacturer to see all of the current firmware versions.
GPS receivers tested on Android
Caution:
The development team doesn't certify any devices and does not provide a comprehensive list of all devices that work with Field Maps.
The following receivers can be used via Bluetooth only:
  • Carlson BRx6+
  • Dual XGPS150A and XGPS160
  • Emlid Reach RX, RS2+, RX2, RS4, RS4 Pro
  • Garmin GLO
  • Sokkia GCX3
The following receivers can be used with the manufacturer's companion app or via Bluetooth:
  • Eos Arrow Lite, Arrow 100, Arrow 100+, Arrow Gold, Arrow Gold+, and Skadi
  • Leica GG03, GG04, GG04 plus, FLX100, and FLX100 plus
The following receivers can be used with the manufacturer's companion app only:
  • Leica GS05
  • Spectra Precision SP30, SP60, SP80, SP85, and SP100
  • Trimble R1, R2, R580, R780, R780-2, R8s, R980, R10, R10 Model 2, R12, R12i, Catalyst DA2, TDC600, and TDC650
To directly connect a Bluetooth receiver with an Android device it must output NMEA0183 sentences.
Connect using a companion app
Some GPS receiver manufacturers support connecting via their companion app if installed on your device. This method relies on the manufacturer’s app to communicate with the GPS receiver, which offers several benefits over the traditional method of connecting to the GPS receiver in Field Maps directly. This connection method supports a broader set of GPS metadata such as tilt-compensation information, coordinate system information, and correction service information such as mountpoint when using Ntrip as well as unified management of receiver configurations such as antenna height.
The following manufacturers support connecting to GPS receivers via their respective companion app: Bad Elf, Leica Geosystems, Radiodetection, Subsite, and Trimble.
Connect your receiver using a companion app
Field Maps supports receivers integrated into devices as well as external receivers connected using Bluetooth.
  1. Verify that your GPS receiver is compatible with Field Maps.
  2. Turn on your receiver and place it near your device.
  3. Connect to your receiver using the manufacturer's companion app.
Set your receiver as the location provider via companion app
Once your GPS receiver is connected to your device, specify that you want the manufacturer’s companion app to provide GPS locations in Field Maps. Once chosen, this is the only source of positions that is used until a new location provider is chosen.
  1. While viewing the Maps list, tap Profile .
  2. In the Location section of the profile, tap Provider.
  3. If your receiver isn't listed, tap Add Provider.
    Select your GPS manufacturer’s companion app to connect and retrieve the current receiver.
    Make sure the GPS receiver’s companion app is installed and the GPS receiver is configured and connected in the GPS manufacturer’s companion app. If the companion app is installed but not displayed, ensure you have the latest version available.
    The currently connected device and antenna height in the GPS manufacturer’s companion app are displayed.
    The antenna height is set in GPS manufacturer’s companion app.
    You are returned to the Location providers list and your receiver is listed.
  4. Tap your receiver in the Location providers list to set it as the current provider.
  5. Return to your profile, and return to the Maps list.
Connect directly to the device
Many GPS receivers support connecting to a GPS receiver directly with Field Maps, the receiver must support the output of of NMEA sentences to connect directly to Field Maps.
Tip:
Most high-accuracy GPS receivers support the NMEA sentences that Field Maps uses; however, it's recommended that you check whether your receiver supports these NMEA sentences in the receiver's user manual before you try to connect it to Field Maps.
NMEA support
NMEA 0183 is the data specification standard that Field Maps uses to communicate with GPS receivers. NMEA messages contain lines of data called sentences. Field Maps derives GPS information such as latitude, longitude, height, and fix type by reading specific sentences in NMEA messages.
Field Maps supports NMEA 4.00, 4.10, and 4.11. It can read the following NMEA sentences:
  • GGA—Time, position, and fix-related data
  • GSA—GNSS DOP and active satellites
  • GSV—GNSS satellites in view
  • RMC—Recommended minimum specific GNSS data
  • VTG—Course over ground and ground speed
  • GST—GNSS pseudorange error statistics
If Field Maps receives GST sentences, which contain accuracy information for a particular coordinate, it uses them to determine accuracy. By default, the horizontal and vertical accuracy numbers are specified in root mean square (RMS). The level of confidence using RMS is 63 percent to 68 percent for horizontal accuracy, and 68 percent for vertical accuracy. If the 95% confidence accuracy setting is enabled, Field Maps applies a conversion factor to the RMS calculation and reports horizontal and vertical accuracy with a 95 percent confidence level.
The internal GPS of some Android devices outputs NMEA. If a device outputs invalid NMEA, Field Maps uses the accuracy reported by the device's location service.
Not all receivers that support the output of NMEA sentences are configured to do so out of the box. The device's user manual should have instructions on how to configure it to output NMEA.
Estimated accuracy
If Field Maps doesn't receive a GST sentence from a GPS receiver, but does receive a GSA sentence, Field Maps estimates accuracy using horizontal dilution of precision (HDOP) and vertical dilution of precision (VDOP). The estimated horizontal accuracy is calculated by multiplying HDOP by 4.7, and the estimated vertical accuracy is calculated by multiplying VDOP by 4.7.
Connect your receiver to your device
Field Maps supports receivers integrated into devices as well as external receivers connected using Bluetooth. If your receiver is integrated into the device, see Set your receiver as the location provider using Bluetooth connection. If you are using an external receiver, follow these steps to connect it to your device:
    Go to your device's Bluetooth settings and view the available devices. Wait for your receiver's name to appear in the list.
    Tip:
    If your Bluetooth receiver doesn't appear in the list, ensure that it isn't connected to another device.
    • To disconnect a receiver from an Android device, in the device's Bluetooth settings, tap the settings button next to the receiver, and tap Unpair or Forget.
    • To disconnect a receiver from an iOS device, in the device's Bluetooth settings, tap the information button next to the receiver, tap Forget This Device, and tap Forget Device.
  3. Tap the receiver's name to pair it with your device.
Once your GPS receiver is connected to your device, specify that you want the receiver to provide GPS locations in Field Maps. Once a receiver is chosen, this is the only source of positions that is used until a new receiver is chosen.
  3. If your receiver isn't listed, tap Add Provider, and complete the following steps:
    1. Select the receiver.
    2. Enter the antenna height if you are mounting the receiver to a pole or vehicle.
      Important:
      Enter the height if you use the altitude of your positions.
    3. Tap Done.
    1. Tap your receiver in the Location providers list to set it as the current provider.
    2. Return to your profile, and return to the Maps list.
Differential corrections
To improve the accuracy of your positions, consider using a GPS receiver that supports differential corrections. Differential correction technology further improves accuracy by using reference stations, which are also known as base stations. A reference station is another GPS receiver that is established at a known location. The reference station estimates its location based on satellite signals and compares this estimated position to the known position. The difference between these positions is applied to the estimated GPS position calculated by the user's GPS receiver, also called the rover, to get a more accurate position. The user's receiver must be located within a certain distance of the reference station for differential corrections to occur. Differential corrections can be applied in real time in the field or when postprocessing data in the office.
Field Maps does not support postprocessing.
Differential corrections can be provided by public or commercial sources. One of the most widely used and publicly accessible real-time correction sources is the Satellite-Based Augmentation System (SBAS), which is also commonly referred to as the Wide Area Augmentation System (WAAS) in the United States. It is free to use SBAS, but your GPS receiver must support it. Using commercial correction services typically requires a subscription and may also require purchasing a particular type of GPS receiver that can receive these correction signals.
Set up a location profile (optional)
Once you have connected your receiver, your mobile workers need to use a location profile to define the coordinate system of the data from the receiver and apply a datum transformation to the data if one is required. If you are using corrections and the location provided to you is based on a different geographic coordinate system than that of your map, you must provide datum transformation information. See Datum transformations for details.
The location profile applies to both internal and external receivers. It's recommended that you use a location profile when you're using a correction service. If you don't set up a location profile, the default profile is used. The default profile assumes that provided locations are in the WGS 1984 coordinate system.
When using a location profile other than the default, basemaps that don't match the spatial reference of the location profile are unavailable.
  2. In the Location section of the profile, tap Profile.
  3. If your profile isn't listed, add it by completing the following steps:
    1. In the GNSS coordinate system list, tap the coordinate system used by your receiver's correction service. Optionally, search by the name or ID of the coordinate system to filter the results in the list. If using an Android device, tap Next.
    Ensure that the GNSS coordinate system matches the output coordinate system specified in the companion app if defined.
    1. In the Map coordinate system list, tap the coordinate system used by your map (determined by the basemap it uses). Optionally, search by the name or ID of the coordinate system to filter the results in the list. If using an Android device, tap Next.
      Caution:
      Some projected and geographic coordinate systems have the same name. Ensure that you choose your coordinate system from the correct category.
    2. If a datum transformation between the coordinate systems of your receiver's correction service and your map is not required, tap Next (Android) or Done (iOS) and skip to step g (naming the profile).
    3. If a datum transformation between the coordinate systems of your receiver's correction service and your map is required, set the map extent to the area where data is going to be collected and tap Next.
      You can only specify the data collection area when your device has access to online data via Wi-Fi or a cellular network. When offline, specifying a data collection area is skipped.
    4. Tap the datum transformation you want to use in the list of available transformations and tap Next (Android) or Done (iOS).
      If the datum transformation is grid based and needs to be downloaded, Download displays next to it. Tapping the transformation downloads the required files before you can continue making your location profile. If you'd rather copy the files directly to the device (sideload them), you must do so before creating the profile.
      The datum transformation list is sorted by relevance, with the most relevant transformation listed first. Field Maps uses the GNSS coordinate system, map coordinate system, and (if provided) the extent where data is going to be collected to provide and sort this list of applicable datum transformations.
    5. Provide a name for your profile and tap Add (Android) or Save (iOS).
    You are returned to the Location profiles list and your profile is listed.
  4. Tap your profile in the Location profiles list.
    Tip:
    To verify the profile's coordinate systems and transformation, view the details of the profile. On Android, access the details through the Overflow menu . On iOS, tap Info .
The locations provided by your receiver may be based on a different geographic coordinate system than the map you are using in Field Maps. If this is the case, use a datum transformation to maintain the accuracy of your data.
When you receive a location from a GPS and use it to add or update a feature, that location is in geographic coordinates that are referenced to a geographic coordinate system (GCS). Your map also has a coordinate system, determined by the basemap it uses, which may be a GCS or a projected coordinate system (PCS). If the location and map are based on different geographic coordinate systems, the location being added or updated must be transformed to match the map's coordinate system. This conversion process is called a datum transformation. While there are both horizontal and vertical datum transformations, Field Maps only supports horizontal transformations.
Since coordinates, maps, feature layers, and databases all have coordinate systems, a datum transformation (or transformations) should occur anytime your coordinate system doesn't match that of where the data is being used: between the GPS and the map, the map and the feature layer, or the feature layer and the geodatabase. Whenever a datum transformation is used, error is introduced into your locations. By choosing the right coordinate systems for your map, feature layers, and databases, you can limit the number of transformations, as well as the error introduced each time. See ArcGIS Geographic and Vertical Transformation Tables for details on the error introduced through various transformations.
If the coordinate systems don't match and no datum transformation is provided, the data is used as it is provided. As a result, its location won't align with the locations of other data already in place. Similarly, you'll see incorrect positions if you provide the wrong datum transformation.
In Field Maps, you can set up a location profile prior to collection and specify the specific datum transformation to use. While creating a location profile, the coordinate systems of both the GPS data and the map are specified. Based on this information, you are presented with only relevant transformation methods, with the recommended method listed first. As the map author, you should either set up the location provider and profile in Field Maps or provide to your mobile workers the coordinate systems of the GPS and the map, as well as the transformation method they should use when they configure Field Maps.
If you are using one of the basemaps provided by Esri in ArcGIS Online, it is in the WGS84 coordinate system. Similarly, WGS84 is the default coordinate system for GPS data received in Field Maps. If you are using an ArcGIS Online basemap and the default location provider, no datum transformations are necessary in Field Maps.
Grid-based transformations
Grid-based transformations are supported in Field Maps. These transformations use files to calculate positions and require the files to be on your device. To use a grid-based transformation, the files must be downloaded or copied (sideloaded) onto your device. If your datum transformation is grid based and requires files, you'll be prompted to download it when setting up your location profile.
If you'd rather copy the files directly to your device, you can get them from an installation of ArcGIS Pro (you may need to install the Coordinate Systems Data setup in addition to the main product setup to get specific grid-based transformation files). Copy them to your device in one of the following ways:
  • On Android—Plug your device or SD card into your computer. Using a file explorer on your computer, browse to \Android\data\com.esri.fieldmaps\files\PEData (if that folder doesn't exist, create it). Copy the files for the grid-based transformation to that PEData folder.
  • On iOS—Use the Files app or iTunes to copy the files for your grid-based transformation to the documents for Field Maps, placing them in a PEData folder.
    Tip:
    To update a folder in the app's documents using iTunes, first save the folder from the device, make your changes to it, and upload it. The new folder replaces the previous one.
You must maintain the folder structure in the PEData folder the same as it is structured for ArcGIS Pro or ArcMap. For example, to copy the files for the Old_Hawaiian_To_NAD_1983_HARN_Hawaii + ~NAD_1983_To_HARN_Hawaii transformation, add to the PEData folder on your device a folder named harn, containing the files ohdhihpgn.las, ohdhihpgn.los, hihpgn.las, and hihpgn.los.
You must maintain the folder structure in the PEData folder the same as it is structured for ArcGIS Pro. For example, to copy the files for the Old_Hawaiian_To_NAD_1983_HARN_Hawaii + ~NAD_1983_To_HARN_Hawaii transformation, add to the PEData folder on your device a folder named harn, containing the files ohdhihpgn.las, ohdhihpgn.los, hihpgn.las, and hihpgn.los.
Specify the required accuracy and confidence
Your organization may require that all data collected meet a specific minimum accuracy and confidence interval. In Field Maps, you can set the required accuracy of GPS positions and whether the positions must meet a 95 percent confidence level. This ensures that data you collect meets your organization's data collection standards.
For detailed steps, see Configure Field Maps—Specify the required accuracy and confidence.
This topic assumes you'll set up the devices for your mobile workers. If this is not the case, ensure that you communicate to them what accuracy to require and whether they need a 95 percent confidence level.
If your mobile workers use decimal degrees, by default, coordinates are displayed with six decimal places of precision. This can be configured as part of the units setting in Field Maps.
Enable GPS averaging (optional)
Your organization may require that you collect a number of points for a single location and average their information to get a final location and accuracy. In Field Maps, you can set the required number of points to be averaged to get a single location. Any time you use GPS location when collecting data, the required number of points is collected and averaged. When enabled, averaging is done for point features as well as for the individual vertices of lines and polygons.
For detailed steps, see Configure Field Maps—Enable GPS averaging.
This topic assumes you'll set up the devices for your mobile workers. If this is not the case, ensure that you communicate to them whether they should enable GPS averaging and if so, how many points to average.
Postprocess recorded altitudes (z-values)
When recording altitude, Field Maps records orthometric height based on the geoid model of your receiver (often EGM96, but see your device's user manual). If you require a different geoid model, postprocess the values to use the required geoid model.
Your receiver is now providing locations to Field Maps. As you collect data, you will provide your organization with high-accuracy data that meets its standards.
