Set up ArcGIS Image Server
ArcGIS Image Server provides a distributed computing and storage system that powers the analytical processing and serving of large collections of imagery, elevation data, rasters, and other remotely sensed data.
Getting ArcGIS Image Server up and running involves four primary steps:
  • Install an ArcGIS Server site to function as ArcGIS Image Server.
  • Authorize ArcGIS Server with an ArcGIS Image Server license.
  • Federate your ArcGIS Image Server site with your ArcGIS Enterprise portal.
The complete steps for this workflow are as follows.
  1. Verify that your site meets the system requirements.
  2. Plan your ArcGIS Image Server site configuration.
  3. Modify your firewall to allow communication on the ports used by ArcGIS Image Server.
  4. Install ArcGIS Server.
  5. Authorize the ArcGIS Server with an ArcGIS Image Server license. Your authorization file will automatically assign ArcGIS Server the role of ArcGIS Image Server.
  6. Log in to ArcGIS Server Manager on the machine and create a new site.
  7. Install and configure ArcGIS Web Adaptor with the ArcGIS Image Server site.
  8. Federate your ArcGIS Image Server site with your portal
  9. Connect to ArcGIS Image Server from ArcGIS Pro.
  10. Grant your ArcGIS Image Server site the necessary permissions to your data directories.
You can also configure and deploy ArcGIS Enterprise for image hosting or for raster analytics.
License:
When ArcGIS Server is installed, it creates a ArcGIS Server site. Then when an ArcGIS Image Server license is added, image server capabilities are enabled for ArcGIS Server. So the site becomes ArcGIS Server site with image server capabilities. There is no dedicated image server site created, so we don't refer to it differently and there is no requirement of assigning a server role to this ArcGIS Server site.
