Configure a organization for Indoors
Available with the ArcGIS Indoors Maps extension.
An ArcGIS Enterprise organization administrator must import the license file for Indoors into your organization. You can then set permissions for members of your organization and certain functionality in ArcGIS Pro. Once you set permission levels for members and enable access to ArcGIS Pro functionality, they can access the Indoors geoprocessing tools in ArcGIS Pro after they successfully connect and sign in to your ArcGIS Enterprise organization.
ArcGIS Online organizations are provisioned for ArcGIS Indoors with the Indoors extensions. These extensions include ArcGIS Indoors Maps and, optionally, ArcGIS Indoors Spaces. ArcGIS Indoors Spaces is an add-on extension to ArcGIS Indoors Maps that enables workspace reservation functionality.
If you licensed Indoors using the earlier Indoors organization extension, it will be supported until expiration.
Import the license for Indoors
Indoors Space Planner checks for the ArcGIS Indoors Maps and ArcGIS Indoors Spaces organization extensions when trying to connect to an ArcGIS Enterprise organization. You or a organization administrator must import the license files into the organization for the app to be able to successfully connect to it.
ArcGIS Indoors Maps allows you to author and share floor-aware maps that can be used for indoor wayfinding in Indoors Viewer, Indoors mobile, and Indoors Kiosk.
ArcGIS Indoors Spaces allows you to share a web map for use in Indoors Space Planner for space management and enables the workspace reservation capabilities of Indoors Viewer and Indoors Mobile. ArcGIS Indoors Spaces is an add-on to the ArcGIS Indoors Maps license; you cannot have ArcGIS Indoors Spaces without ArcGIS Indoors Maps.
To import the Indoors license file, complete the following steps:
Import the license file through your ArcGIS Enterprise organization.
Ensure that Indoors license files are listed as organizational extensions.
Click the Organization tab and click Licenses.
Click Organization extensions.
Verify that the correct licenses are listed.
Set up access for ArcGIS Pro
To set permissions for the members of your organization who need to use ArcGIS Pro, complete the following steps:
Assign the Professional Plus user type to the named users in your organization who need access to ArcGIS Pro.
Grant these named users access to the following extensions:
3D Analyst
Network Analyst
Assign these named users the Publisher role.
Members of your organization who need to use ArcGIS Pro must connect to this portal before using the ArcGIS Indoors geoprocessing tools.
Members of your organization who need to use ArcGIS Pro must connect to this ArcGIS Online organization before using the Indoors tools.
Configure the security certificate
The ArcGIS Enterprise organization must have a valid Secure Sockets Layer (SSL) certificate from a trusted entity for Space Planner to run without warnings. Web browsers have built-in security features that prevent connection to servers that do not have a valid certificate.
If the organization uses self-signed or Enterprise CA certificates for Space Planner, exceptions must be added in some browsers to be able to access the Space Planner URL. This can be disruptive, so it is recommended that you use a trusted certificate signed by a certificate authority.
Configure the identity store
ArcGIS Enterprise allows you to use enterprise accounts and groups to control access to your ArcGIS organization. Use an organization-specific identity store to set policies for password expiration and complexity; control access using existing Active Directory, LDAP, or SAML groups; or use authentication.
Indoors supports built-in authentication and SAML.
Invite and add members
ArcGIS Online allows you to manage members in your organization, as well as their roles and associated privileges.
Create users and assign roles and types
When you create users, review the available user types for details about assigning roles and access.
You can change the user type for multiple members of your ArcGIS organization at the same time. For example, you can change the user type for many users to Contributor.
To access the Indoors Space Planner app, a user must be assigned the Contributor user type or higher.
To create the Space Planner app, a user must have the privileges associated with the default role of Publisher or higher.
To create a Space Planner app or create a plan, a user must have the privileges associated with the default role of Publisher or higher.
To open, edit, and merge changes in plans, a user must have the privileges associated with the default role of Data Editor or higher.
If you are using Space Planner to manage indoor spaces and want to implement further control over who can merge plans, you can create a group of users or choose an existing group that will have permissions to merge updated plans. These permissions are set during the Space Planner app configuration process.
