ArcGIS Knowledge Server 12.2 system requirements
To create an ArcGIS Knowledge Server site, you install ArcGIS Server and authorize it with an ArcGIS Knowledge license. Therefore, the system requirements to run ArcGIS Knowledge Server are the same as the system requirements for ArcGIS Server.
All ArcGIS Knowledge Server sites that are federated with the ArcGIS Enterprise deployment must match the version of the ArcGIS Enterprise deployment.
ArcGIS Enterprise 10.9.1 knowledge graph services cannot be used with the currently supported versions of ArcGIS Pro.
The ArcGIS Enterprise deployment with which you federate the ArcGIS Knowledge Server site must have an ArcGIS Data Store graph store. See the following for information about configuring the graph store:
The only additional requirement for ArcGIS Knowledge Server is that the site must be able to communicate with the graph store. See Ports used by ArcGIS Data Store and the port diagram available from ArcGIS Enterprise system requirements for more information.
You can optionally register a NoSQL data store with your ArcGIS Knowledge Server site if you want to create a knowledge graph whose entities and relationships are stored in a NoSQL database instead of being stored in the ArcGIS Data Store graph store. Each NoSQL data store can be associated with one or more knowledge graphs depending on how the data in the NoSQL database is managed. If the NoSQL data store will contain ArcGIS-managed data, you must register one NoSQL data store with the ArcGIS Knowledge Server site for each knowledge graph you create. The ArcGIS Enterprise deployment must still include an ArcGIS Data Store graph store even if entities and relationships are stored in a NoSQL data store; it stores data model information.
Neo4j Enterprise Edition databases, Neo4j AuraDB Enterprise instances, and ArangoDB Enterprise Edition databases are the only currently supported NoSQL databases. The following database versions are supported:
  • The minimum supported version of Neo4j Enterprise Edition is 4.4.3. ArcGIS Knowledge has also been certified with Neo4j Enterprise Edition versions 5.10.0, 5.11.0, 5.12.0, 5.16.0, 5.23.0, 5.26.12, 2025.01.0, 2025.02.0, 2025.05.0, 2025.09.0, 2026.01.4, and 2026.05.0.
ArcGIS Enterprise version 11.5 does not support Neo4j Enterprise Edition versions 2025.05.0 or newer.
  • The minimum supported Neo4j version for a Neo4j AuraDB Enterprise instance is 4. Neo4j version 5 is also supported.
  • The minimum supported version of ArangoDB Enterprise Edition is 3.11.3. ArcGIS Knowledge has also been certified with ArangoDB Enterprise Edition versions 3.11.9, 3.11.12, 3.11.14, 3.11.14-3, and 3.12.11.
Neo4j Community Edition is not supported.
