Add a data store item
There are several types of user-managed data stores you can connect to from your organization by adding a data store item. Each one requires you to provide different information and each is used for a different purpose.
When adding a data store item, the data store is registered with selected federated server sites. Therefore, every machine in those server sites must be configured to access the database, folder, or cloud storage location. If the user-managed data store is already registered with one or more of the federated server sites, do not use these steps to add the data store item. Instead, talk to your organization administrator about creating a data store item from an existing registered data store.
The following sections describe how to add connections to each type of data store. Use the links below to access instructions to add the user-managed data store type you need.
Add a folder data store item
Add a folder data store item that connects to an existing network file share (NFS) location. If you are an administrator, you can also use the steps below to connect to a new NFS location.
  1. Ensure the folder functions as a network file share location.
    For more information on making data sources accessible, see Controlling access to data published from data store items.
  2. Sign in to your organization as a member who has privileges to register data stores and create, update, and delete content.
  3. On the My content tab of the Content page, click New item, and click Data store.
  4. Choose Folder for the type of data store item to create and click Next.
  5. Type or paste the path to the folder in the Publisher folder path field.
  6. Provide information for your data sources.
    If the ArcGIS clients used to publish the data will access data in one folder but the federated server sites need to access a copy of the data in a second folder, you must provide information for both data sources.
    • If the publishing clients and the federated servers will access data in the same shared folder, leave the default setting, Same as publisher folder path.
    • If you have duplicated the data in two different file shares and want clients and server sites to reference different file shares, choose New path under Server folder path, and type the path to the second file share.
  7. Click Next to choose the server sites with which this data store will be registered.
  8. Choose the server sites with which to register this data store.
    If you are unsure which sites fill these roles, contact your administrator.
    You can only select a site if the status is normal and if the site has access to the file location you specified in step 6.
    If this data store is already registered with a federated server, you cannot select that server from the list. If you do, you'll receive an error.
  9. Click Next.
  10. Provide a title for the data store item.
    This is the name of the item that will appear in the organization and ArcGIS Pro.
  11. Optionally, provide tags that describe the item.
    Separate the terms with commas (for example, Federal land is considered one tag, and Federal, land is considered two tags).
    As you type, you can choose any of the suggested tags that appear; suggestions are generated from tags you previously added.
  12. Choose the folder in My content where you want to store the data store item.
  13. If your administrator has configured a classification schema, classify the item in one of the following ways under Classification:
    1. If you do not have a list of favorite classifications, classify the item from scratch. Optionally, to save the classification as a favorite, click Save new Classification Favorite, provide a name for it, and click Done.
    2. If you have a list of classification favorites, choose a classification to apply to the item from the Apply Classification Favorite drop-down menu. Optionally, do any of the following:
      • To update the classification, choose new classification options and click Update Favorite. Alternatively, click Save new Favorite, provide a name, and click Done to save the updated classification as a new favorite.
      • To delete the classification, click Manage, click Delete next to the classification name, and click Done.
    If your administrator has defined a schema help document, you can access it by clicking Information at the top of the classification form. Refer to this document for details about the classification options.
    Classifying a data store item does not restrict access to it. The classification you assign to the item, which appears on the item page, provides a visual indication of the extent of security and safeguarding it warrants and can help organization members identify the correct way to interact with it. You need to set the appropriate sharing level to restrict access to the item.
  14. Click Create connection.
Share the data store item with groups whose members need to create imagery layers or those who need to publish layers that reference files in the folder.
Add a database data store item
You can add a database connection file (.sde) that accesses content in a relational database, enterprise geodatabase, or cloud data warehouse to create a database data store item. If your organization has a Knowledge Server configured, you can provide connection information to a graph (NoSQL) database to store knowledge graphs.
Use a database connection file
To create a database data store item that accesses data in a cloud data warehouse or a relational database (which can contain an enterprise geodatabase but does not have to), you will upload an existing database connection file (.sde file).
  1. Create a database connection file that connects to a supported relational database or cloud data warehouse.
    Connect using credentials for an account or user that has access to the data you need and the required permissions on the data. You must save the credentials with the connection file. You cannot use an .odc file or .dbconn file.
  4. Choose the Database data store type and click Next.
  5. Choose Browse to a connection file and click Next.
  6. Click Select File and browse to the database connection file (.sde) that accesses the database, enterprise geodatabase, or cloud data warehouse content you require.
  7. Provide information for the data sources.
    If you connect to a database or cloud data warehouse, leave the default setting enabled—Same as publisher database connection. If you connect to an enterprise geodatabase and the clients used to publish layers from this data store will use the same enterprise geodatabase, also leave the Same as publisher database connection option enabled.
    However, if your ArcGIS clients will access data in one enterprise geodatabase but the federated server sites need to access a copy of the data in a second enterprise geodatabase, you must provide information for both data sources. In this case, choose New connection under Server database connection (.sde file), and choose the database connection file that the federated server sites will use to connect to the data in the other geodatabase. This option is only supported when the data sources are enterprise geodatabases.
  8. Click Next to choose the server sites with which this data store will be registered.
  9. Select the server sites with which you want to register this data store.
    You can only select a site if the status is normal and if the server site has access to the data source location.
  10. Click Next.
  11. Provide a title for the data store item.
  12. Optionally, provide tags that describe the item.
  13. Choose the folder in My content where you want to store the data store item.
  14. If your administrator has configured a classification schema, classify the item in one of the following ways under Classification:
  15. Click Create connection.
If you chose a federated server site with which to register a connection to a relational database, you, as the owner of the database data store item, can publish map image and feature layers in bulk from the data store item in the organization.
If members of your organization will publish data from this database connection in ArcGIS Pro, share the data store item with a group to which those members belong. This allows these members to publish data using the same database credentials to any of the federated servers you specified in step 10.
Specify connection information
You can provide connection information to create a database data store item instead of using an existing database connection file for the following database platforms:
  • BigQuery
  • Elasticsearch
  • OpenSearch
  • Oracle
  • PostgreSQL
  • Redshift
  • Snowflake
  • SQL Server
To create a database data store item that connects to a database supported with ArcGIS Knowledge Server, you must always provide connection information.
To create a data store item by providing connection information, complete the following steps:
  1. Sign in to your organization as a member who has privileges to register data stores and create, update, and delete content.
  2. On the My content tab of the Content page, click New item, and click Data store.
  3. Choose Database and click Next.
  4. Choose Create a connection by specifying information.
  5. Choose the database or cloud data warehouse type from the Database platform drop-down menu and click Next.
  6. If you connect to a database type that supports enterprise geodatabases, choose one of the following server connection policies and click Next to proceed:
    • Same database connection for publisher and server—Always choose this option if you connect to a cloud data warehouse or a database. If you connect to an enterprise geodatabase, and the clients used to publish layers from this data store will use the same enterprise geodatabase, also choose the Same database connection for publisher and server option.
    • Different database connection for publisher and server—If you connect to an enterprise geodatabase and ArcGIS clients will access data in one enterprise geodatabase but the federated server sites need to access a copy of the data in a second enterprise geodatabase, choose this option and then choose the database platform of the federated server's database from the Server database platform drop-down menu. This option is only supported when both data sources are enterprise geodatabases.
  7. Provide the connection and authentication information specific to your database or data warehouse. Click Next when you finish providing the connection information.
    The information you must specify varies by database or data warehouse type.
    For details about the information required for graph (NoSQL) databases, see the Graph database information section below.
    If you need a description of the values required for databases or cloud data warehouses, see the Database and cloud data warehouse connection information appropriate for the type you are using.
    If you chose the Different database connection for publisher and server option in the previous step, you must provide separate connection information for the enterprise geodatabase used by the publisher and the enterprise geodatabase used by the federated servers.
  8. Select the server sites with which you want to register this data store.
    If you are unsure which site or sites to use, contact your administrator.
    Graph databases can only be registered with the ArcGIS Knowledge Server site.
    If this data store is already registered with a federated server, you cannot select that server from the list. If you do, you'll receive an error.You can only select a site if the status is normal and the ArcGIS Server site can access the data source.
  9. Provide a title for the data store item.
  10. Optionally, provide tags that describe the item.
  11. If the organization administrator has configured content categories, click Assign Category and choose up to 20 categories to help people find the item.
    You can also use the Filter categories box to narrow the list of categories.
A data store item is created in your content.
If members of your organization will publish data from this database connection in ArcGIS Pro, share the data store item with a group to which those members belong. This allows these members to publish data using the same database credentials to any of the federated servers you specified in step 8.
If the item accesses a graph database, share the data store item with groups whose members will create a knowledge graph in ArcGIS Pro.
To connect to Neo4j, provide the connection URI, credentials to authenticate, and database name. See Neo4j Java driver documentation for connection requirements.
To connect to ArangoDB, provide the host name or TCP address and port for all coordinator machines, credentials to authenticate, and the ArangoDB database name. If ArangoDB is configured to use SSL for communication, check the Use SSL check box.
Database and cloud data warehouse connections
Connection information required to create a connection in the portal are the same as those you provide in ArcGIS Pro. Use the following links to access descriptions in the ArcGIS Pro help of the connection information for each supported source type:
Add a cloud storage data store item
Add a cloud storage data store item to publish imagery layers from image files in a cloud storage location and to publish 3D, tile, or vector tile layers that reference pre-created caches in a cloud storage location.
  1. To add a cloud storage data store, ensure that you have an account with a supported cloud storage provider, and the cloud storage location exists.
  4. Choose Cloud Storage for the type of data store item to add and click Next.
  5. Choose one of the cloud storage providers, click Next, and specify the credentials to connect to the cloud storage location.
    The information you must specify varies by provider type.
    • Amazon S3
      Provide the following to connect to an Amazon S3 bucket:
      • Choose one of the following credential types:
        • Anonymous—You can use this to access a public Amazon S3 bucket.
        • IAM role—You can use this to access an Amazon S3 bucket that has an IAM role configured for it.
        • Access key—Provide the access key ID and corresponding secret access key you obtained from your Amazon Web Services (AWS) account.
          • Requester Payee- Enable this mode when using Access Key authentication to access an Amazon S3 bucket owned by another account. In this configuration, the account associated with the access key is billed for all request and data retrieval charges incurred when accessing the bucket.
      • Choose the region where the bucket exists and type the name of the bucket.
        To connect to a custom Amazon S3 endpoint, choose Custom from the Region drop-down menu and type or paste the URL to access the private cloud in the Private URL field.
      • To register a subfolder in the bucket, type the path to the folder.
    • Google Cloud Storage
      Provide the following to connect to a Google Cloud bucket:
      • Provide the access key ID and corresponding secret access key you obtained from your Google Cloud account.
    • Microsoft Azure Storage
      Provide the following to connect to a Microsoft Azure storage location:
      • Choose one of the following service types:
        • Storage Account—Use your Microsoft Azure storage account credentials to access an Azure Blob Storage container.
        • Planetary Computer—Provides access to Microsoft Planetary Computer. Anonymous authentication is always used because this is a public platform.
        • Planetary Computer Pro—Provides access to Microsoft Planetary Computer Pro. It is only accessible using Microsoft Entra ID authentication and service principal identity.
      • If you chose Storage Account for the service type in the previous step, you must choose one of the following authentication types. Each type requires different information to authenticate.
        • Microsoft Entra ID—Choose the identity type, either Service principal or User-assigned managed identity. Provide the credentials necessary for the identity type that you choose.
          Ensure that the user-assigned managed identity is assigned to the instances on which the hosting and federated server sites are running. Also ensure that the user-assigned managed identity has at least read-only access to the storage account container. If more than one user-assigned managed identity is assigned to an instance or storage container, you must specify a client ID.
          If you use the service principal identity type, you must have Storage Blob Data Contributor access to the service principal account.
          See the Microsoft Azure documentation for information about Azure Active Directory authentication.
        • Shared Key—Provide the name of your Microsoft Azure storage account and the account key.
          See the Microsoft Azure documentation for information about shared key authentication.
        • Shared Access Signature—Provide a shared access signature (SAS) token and the name of your Microsoft Azure storage account.
          Generate the SAS token from the container level.
          See the Microsoft Azure documentation for information about shared access signature authentication.
        • Anonymous—Use this to access public containers for imagery layer workflows. This authentication method is not supported with any other workflows.
      • If you chose Planetary Computer Pro for the service type, provide information for all of the following:
        • Tenant Id—The unique identifier assigned by Microsoft Azure for your Microsoft Entra ID.
        • Client Id—The application ID that identifies the client registered with your tenant.
        • Client secret—The secret associated with your client ID.
        • Scope—Must be set to https://geocatalog.spatio.azure.com/.default.
        • Account name—Your Planetary Computer Pro collection account name.
      • If you chose Storage Account or Planetary Computer Pro for the service type, choose the Azure storage domain where the Blob Storage container exists.
      • If you chose Planetary Computer for the service type, provide the URL or the data name system of the storage account private endpoint in the Endpoint field.
      • In the Container name field, provide the name of the Blob Storage container.
      • If you chose Planetary Computer for the service type, provide the data authentication API in the Token Generation URL field.
      • To register a subfolder in the storage container, provide the path to the folder.
    • Microsoft Azure Data Lake Storage Gen2
      Provide the following to connect to a Microsoft Azure Data Lake Storage Gen2 location:
      • Choose one of the following authentication types. Each type requires different information to authenticate.
    • Alibaba Cloud Storage
      Provide the following to connect to an Alibaba Cloud Object Storage Service (OSS) bucket:
      • Provide the access key ID and corresponding secret access key you obtained from your Alibaba account.
  6. Click Next to choose the server sites with which this data store will be registered.
  7. Select the server sites with which you want to register this data store. If you are unsure which sites fill these roles, contact your server administrator.
    You can only select a site if the status is normal, which means the site can connect to the data source.
  8. Click Next.
  11. Choose the folder in My content where you want to store the data store item.
  12. If your administrator has configured a classification schema, classify the item in one of the following ways under Classification:
  13. Click Create connection.
Share the data store item with groups whose members need to create imagery layers.
