Uninstall the ArcGIS Maritime server extension
Available with Advanced license.
Available with ArcGIS Maritime license.
The following steps guide you through uninstalling the ArcGIS Maritime server extension using the Windows Control Panel:
If Maritime Chart Service is enabled for any map services, the Maritime server object extension (SOE) must be deleted first.
Remove the Maritime server object extension
To delete the SOE, complete the following steps:
Before uninstalling the ArcGIS Maritime server extension for Linux, the Maritime server object extension (SOE) must be removed from your ArcGIS GIS Server site and all associated files must be deleted. The following steps guide you through removing the SOE and uninstalling Maritime server:
  1. Sign in to ArcGIS Server Manager.
    The manager URL is https://<server name>:6080/arcgis/manager.
  2. Click Site.
  3. Click Extensions.
  4. Click Delete next to MaritimeServer.soe to remove the extension.
    The Maritime Chart Service capability is removed from all map services where it was enabled.
  5. Browse to the maritimechartservice folder location and delete the system folders created when Maritime Chart Service was enabled.
    Refer to Set Maritime Chart Service properties for more information about folders that contain relevant files.
  6. Browse to the ArcGIS GIS Server installation location and run the uninstall command:
    $ ./uninstall_MaritimeServer.sh
    The MaritimeServer folder is removed.
Uninstall Maritime server
Complete the following steps to uninstall Maritime server:
  1. Access the Windows Control Panel from the Start menu or search box.
  2. Under Programs, click Uninstall a program.
  3. Click ArcGIS Maritime<version>server extension in the Programs list.
  4. Click Uninstall.
