Create analysis views
You can create custom analysis views that use data collected by ArcGIS Monitor to observe, identify, and troubleshoot issues that are unique to your system architecture and environments. You must be assigned the Administrator or Manager role to create analysis views.
Tip:
You can also create analysis views from exported analysis view .json files.
To create an analysis view, complete the following steps:
Access ArcGIS Monitor if necessary.
The Home page appears.
Click Analysis.
The Analysis page appears with a list of analysis views.
Click Create analysis.
The Create analysis dialog box appears.
Provide a name for the view in the Name text box.
Optionally, provide a description for the view in the Description text box.
The analysis is created and appears in the list.
Click the name of the analysis view.
The analysis view's Overview page appears.
Click Edit.
The Overview page changes to edit mode.
Click Add element to add the following elements to the analysis view as necessary:
Click Save when you finish adding elements to the view.
Tip:
You can also click the Save drop-down arrow and click Save as to save the view with a new name and description.
