Administer ArcGIS Notebook Server
ArcGIS Notebook Server provides administrative tools and settings to monitor, manage, and secure your site. All of these resources and operations use the ArcGIS REST API language and can be accessed in the ArcGIS Notebook Server Administrator Directory. Some of the most common settings and resources are made available in the ArcGIS Notebook Server Manager app in the ArcGIS Enterprise portal.
Administrative tasks and resources for ArcGIS Notebook Server sites are made available through the ArcGIS Notebook Server Administrator Directory, an ArcGIS REST API directory. As an administrator of an ArcGIS Notebook Server site, you can use the Administrator Directory to perform a range of administrative actions, from monitoring your site to customizing its settings.
As with other REST API directories in ArcGIS Enterprise, you can either access the HTML views of the Administrator Directory in a browser or make programmatic requests to it through a third-party client.
The URL of the directory is formatted https://<notebookserver.domain.com>:11443/arcgis/admin or https://<notebookserverwebadaptor.domain.com>/<context>/admin.
Refer to the API reference (available at the upper right of the directory window) for full documentation of each resource and operation in the directory.
The ArcGIS Notebook Server Manager app provides an intuitive graphical interface in the portal for many common administrative tasks and resources. Each resource and operation available in Manager serves as an interface for a certain REST endpoint in the Administrator Directory. You can use Manager to monitor key statistics about usage and performance, to maintain and adjust system settings, and to use system logs for troubleshooting.
Access the Manager app
The app is only accessible to portal members with administrative privileges. There are two ways of accessing ArcGIS Notebook Server Manager.
Access ArcGIS Notebook Server Manager from your ArcGIS Notebook Server home page
Complete the following steps to access ArcGIS Notebook Server Manager from your ArcGIS Notebook Server home page:
  1. Sign in to your ArcGIS Enterprise portal as an administrator.
  2. Click Notebooks at the top of the site.
  3. Click Manage > Notebook server.
You can bookmark Manager with the URL format https://portal.domain.com/portal/home/notebook/manager.html.
Access ArcGIS Notebook Server Manager from your organization
Complete the following steps to access ArcGIS Notebook Server Manager from your organization:
  2. Click Organization at the top of the site and click the Settings tab.
  3. Click Servers on the left side of the page.
  4. Under Federated server sites, locate your ArcGIS Notebook Server and click the Administrator URL.
    The link directs you to its ArcGIS Notebook Server Manager app in the portal website.
View site information in Manager
The Overview page in ArcGIS Notebook Server Manager provides a dashboard view of some helpful information and statistics regarding your site.
  • Site information—This box provides a link to your site's Administrator Directory and the current version number of your ArcGIS Notebook Server site. It also gives a count of containers and notebooks currently active across your site.
  • Health check—This table shows whether each machine in the site has passed its most recent health check and the number of containers active on each machine.
  • Recent errors—Logs created in the past 24 hours with the levels WARNING or SEVERE are shown in this table. You can use the Logs page in Manager to see more details about each log.
  • Machines—This table gives a list of each machine participating in the site. For each, the machine name, operating system version, number of physical processors, system memory, and disk usage are provided.
Available operations in Manager
ArcGIS Notebook Server Manager provides several tools to monitor and manage your site.
Logs tab
On the Logs page, you can query ArcGIS Notebook Server logs, with options to sort and filter by several parameters. To learn more, see Work with ArcGIS Notebook Server logs.
Settings tab
On the Settings page, the following operations and resources are available:
Reset the primary site administrator account password
You create the primary site administrator account when you create an ArcGIS Notebook Server site. If you need to change the username or password for this account, you can do so using the ArcGIS Notebook Server Administrator API.
If you use the primary site administrator account to register ArcGIS Web Adaptor with your site and you later change the primary site administrator username or password, there is no need to reconfigure the web adaptor. HTTPS communication is not disrupted between the web adaptor and the site after you edit the account.
Follow these steps to change the username or password of the primary site administrator account.
  1. Open the command prompt window on the ArcGIS Notebook Server machine.
  2. Open a terminal on the ArcGIS Notebook Server machine.
  3. Browse to <Notebook Server install directory>\tools\passwordreset.
  4. Browse to <Notebook Server install directory>/tools/passwordreset.
  5. Run the command PasswordReset.bat -p <newpassword>.
  6. Run the command ./passwordreset.sh -p <newpassword>.
The primary site administrator account password is reset.
