Configure member roles
Organization administrators can create and assign custom roles to confer a more focused set of privileges to members of the organization. This provides more flexibility than relying on the default roles, and allows for more control over what members can do. For example, you may have members who need access to maps and apps in the organization but do not need to create groups, and you may have other members who need to publish hosted feature layers but not hosted tile layers.
Your organization may have certain members who are responsible for creating content such as stories, maps, and scenes but who also need to join and share content with groups. To allow these members to perform these tasks, create a custom role with general privileges to create, update, and delete content and share with groups. Another common example is a member who needs to create and publish all layer types in addition to performing certain administrative tasks such as inviting users into an organization and assigning department members to the correct groups. This custom role requires all general privileges and the following administrative privileges:
  • All privileges in the Members category
  • The privilege to assign members to groups
To get started, you can use predefined templates or existing roles and further refine the privileges based on the workflows in your organization.
Some privileges are reserved for default administrators and cannot be assigned to a custom role.
Create a custom role
To create a custom role, complete the following steps:
  1. Verify that you are signed in to your organization.
    Your account must be assigned the default administrator role or a custom role that includes the set of privileges to manage the organization's member roles.
  2. At the top of the site, click Organization, and click the Settings tab.
  3. Click Member roles.
  4. Click Create role.
  5. In the Create role window, provide a name and description for the role.
    The name must be unique within your organization and cannot be the same as the name of a default role or template. Role names can contain up to 128 characters and are not case sensitive.
    The role description can contain up to 250 characters.
  6. Do any of the following as needed:
    • Change the privilege compatibility setting, and review the compatible user types and available privileges.
    • Choose Set from existing role, and import settings from an existing role or template on which to base the new custom role.
  7. Use the toggle buttons to enable privileges for the custom role.
    Caution:
    Most workflows require a combination of privileges. For example, to publish hosted tile layers, you also need the privilege to create, update, and delete content. To create apps from Map Viewer or group pages, you must have privileges to share items and create, update, and delete content.
    You may notice that enabling a role privilege will automatically enable additional role privileges. This is because certain privileges depend on each other to function properly. For example, if you want a member to be able to reassign content to another member, their role must allow them to reassign content and view the members in your organization. It is not recommended to disable these dependent privileges.
  8. Click Save.
The custom role is created.
You can assign it to members from the Members tab of the organization page. You can also select the custom role as the new member default for the organization.
Manage custom roles
You can view information about existing roles, edit custom roles, or delete custom roles if they are not assigned to any users.
To manage custom roles, complete the following steps:
  4. To get information about a member role, click the Role information button in the row of the role.
    A pop-up appears with a description and a list of privileges. The row also indicates whether the role is a custom role or default role, as well as the number of members assigned to each role.
  5. To edit a custom role, do the following:
    1. Click the More options button for the role you need to edit.
    2. Click Edit.
    3. Change the name, description, or privileges for the role.
    4. Click Save.
    Caution:
    Certain privileges depend on each other for the role to function properly. For example, if you want a member to be able to reassign their content to another member, their role must allow them to reassign content and view the members in your organization. It is not recommended to disable these dependent privileges.
  6. To delete a custom role, click the More options button for the role you need to delete, and click Delete.
    You cannot delete a default role, and you cannot delete a role that is currently assigned to a member.
Templates
Templates contain a set of predefined privileges for common workflows such as consuming content and curating data. You can use templates as they have been configured or further customize them by adding and removing the privileges that fit the needs of your organization. The following templates are currently available:
  • Analyst—Staff who create maps, view content and groups shared with the organization, share content across the organization or with groups, publish hosted feature layers, edit features, and use premium content.
  • Author—Content creators who, in addition to the privileges of the Analyst template, create groups and publish hosted tile layers.
  • Collaboration Coordinator—Users who, in addition to the privileges of the User role, can create and manage partnered collaboration groups, invite and add members across partnering organizations, and can modify group settings.
  • Data Curator—Data-focused staff who prepare or process data within your organization. This role can add, edit, and delete features in editable hosted feature layers and join organizational groups.
  • Student—Members of a school organization who have general privileges to create content, view content and groups shared with the organization, join groups, share content with groups and the organization, use premium content, and edit features.
  • Publisher—Default publisher role defined by Esri that, in addition to the Author template privileges, allows members to share content with the public, make groups visible inside and outside the organization (depending on the security settings of the organization), and use premium content.
  • User—Default user role defined by Esri that allows members to create content and groups, share them inside and outside the organization (depending on the security settings of the organization), and use premium content.
  • Data Editor—Default editor role defined by Esri that allows members to edit features, interact with maps, view content shared with them in groups, and use premium content.
  • Facilitator—Default facilitator role defined by Esri that, in addition to the Publisher role privileges, allows members to invite members of partnered collaborations and from other organizations to groups, create and manage partnered collaboration groups, and create shared update groups.
  • Viewer—Default viewer role defined by Esri that allows members to interact with maps, view content and groups shared with the organization, and view content shared with them in groups.
  • Partnered Data Editor—Editors who, in addition to the privileges of the Data Editor role, can join external groups.
  • Partnered Viewer—Viewers who, in addition to the privileges of the Viewer role, can join external groups.
Recommended workflow
Before you assign custom roles to members, test that the set of privileges in the role work as you intend. A recommended workflow is to define a custom role and assign it to an account where you can verify the privileges. You can edit the role, if necessary, and assign it to members of your organization. This workflow is outlined below.
Step 1 Step 2 Step 3 Step 4 Step 5
