Work with the oriented imagery viewer
The oriented imagery viewer allows you to explore the oriented images depicting a location on the map. It supports multiple search modes, navigation between related images, and visualization of camera footprints, frustum, and locations. You can view assets from multiple directions, overlay map features, and identify corresponding positions between the map and imagery. When suitable metadata and accuracies are available, asset sizes and positions can be measured directly from the imagery. Oriented imagery also supports the use of depth images, referenced through the DepthImage field, to enhance measurement accuracy and image-to-ground calculations. Image enhancements are also available to adjust contrast, brightness, and sharpening to enhance image clarity.
View oriented imagery layers
The oriented imagery viewer includes tools that support exploring and managing images in an oriented imagery layer. When you click a map location, the selected location is seen as a red cross
, and the oriented imagery viewer displays the best image available for the selected location. As you pan and zoom in on an image, you will see the camera's field of view dynamically update on the map. This allows you to see how the oriented imagery data relates to vector data displayed on the map.
You do not need to select a camera location on the map. The image displayed is the best available for the selected location and may not correspond to the selected camera location.
The oriented imagery viewer supports JPG, JPEG, COG, and MRF image formats. The images must be available in publicly accessible cloud storage or as feature attachments.
To view and manage oriented imagery, complete the following steps:
Confirm that you are signed in and, if you want to save your changes, that you have privileges to create, update, and delete content.
You can explore maps, add and configure layers, and more without signing in. To save your work, sign in before creating a map.
Open the map containing an oriented imagery layer, or add the layer to a new map.
On the Settings (light) toolbar (Map Viewer), click Layers
if the Layers pane is not open.In the Layers pane, click Options
next to the oriented imagery layer to open the oriented imagery viewer.Click Show Oriented Imagery
.Note:
If the feature layer includes both oriented imagery and footprint layers, expand the group layer, and click Options
on the oriented imagery layer to open the oriented imagery viewer.The oriented imagery viewer opens in the center of the map.
Click anywhere on the area covered by the oriented imagery layer to view the best image of the location.
Use the footprint layer as a reference if available.
Pan and zoom to navigate the image.
This dynamically updates the image footprint on the map.
The oriented imagery viewer opens in the center of the map. The viewer presents a dedicated parent menu panel that organizes its capabilities into five main menu groups: Search, Overlays, Image Navigation, Image Measurement, and Utilities. The parent menu panel displays the available groups. Clicking a group button expands its child menus, which provide access to the related actions and tools. At any time, click the Previous button
from the child menu to return to the main menu groups.
Search tools
In the oriented imagery viewer, the Search tools
options allow you to perform different types of image searches in the map. Select Search tools
to access the following:
Explore images
Explore images 3D
Display images
Explore images
Explore images is the default workflow. It is enabled when the viewer opens. When enabled, it overrides the standard map click behavior with oriented imagery click events. The tool uses the Maximum Distance Range property to create a 2D bounding box. This bounding box is used to filter features when you click the map.
To explore images, complete the following steps:
Turn on the Explore images toggle button
.Click a location on the map.
The best image for the location is retrieved.
Explore images 3D
Explore images 3D extends the Explore images workflow by adding a height and frustum filter to 3D searches. This option is available only in a scene and disabled in a map. The tool uses the
Vertical Search Rangeproperty to filter 3D features, returning only those within the specified vertical range of the selected point. If no value is provided forVertical Search Range, the Explore images 3D tool will be disabled. When Explore images 3D is enabled, Configuration search option drop-down menu options are available.Enable Vertical Search Range - Filters 3D features by height, returning only those within the specified vertical range of the selected point.
Enable Frustum Search - Filters the best image search using the image frustums instead of regular 2D footprint polygons when evaluating candidate images.
To explore 3D images, complete the following steps:
Turn on the Explore images 3D toggle button
.Enable one or both of the configuration search options.
The best 3D image matching the search criteria is retrieved and displayed.
Display images
When the Display images toggle button is turned on, users can click an oriented imagery feature directly on the map and open the associated image. No filters are applied in this workflow to identify the best image; the selected feature is displayed in the viewer.
To display images, complete the following steps:
Turn on the Display images toggle button
.Click an oriented imagery feature directly on the map.
The associated best image opens in the oriented imagery viewer.
Overlays
In the oriented imagery viewer, the Overlays group provides access to tools such as Current footprint, Additional footprints, Additional camera locations, the Map‑image location tool, and Image overlays. Select Overlays
to access the these options.
The Current footprint, Additional footprints, and Additional camera locations layers are graphic layers available to help you better understand how images in an oriented imagery viewer relate to the map. These cannot be accessed from the Layers pane, and their symbology cannot be modified.
To view the current footprint, additional footprints, and additional camera locations, do the following:
Click Current footprint
to show or hide the footprint on the map.Click Additional footprints
to show or hide the footprints of additional images for a location. Additional footprints are displayed as blue polygons on the map.Click Additional camera locations
to show or hide the camera locations of additional images for a location. Additional camera locations are displayed as blue dots on the map.
Use the Map‑image location tool
to perform the image-to-ground and ground-to-image transformations. It identifies the same location in map space and in image space (oriented imagery viewer).
To perform the image-to-ground and ground-to-image transformations, complete the following steps:
Enable Map‑image location
.Click the image.
The corresponding location on the map is marked with a red diamond.
Alternatively, if you click the map, the corresponding location in the image is marked with a red diamond.
Select Image overlays
to list the feature layers available in the layer list and overlay them on the selected image in the oriented imagery viewer.
The following two types of overlay options are available:
Overlay camera locations—Enable the option to overlay all the camera locations (feature points) from the layer that intersect with the footprint of the loaded image.
Overlay map features—Enable the option to overlay map features from the current map view, excluding the oriented imagery layers. You can select from all available feature layers—such as points, lines, or polygons—that are listed in the layer list and rendered on the map.
The symbology and visibility settings of the map features you overlay in the oriented imagery viewer correspond with those shown on the map. Any updates to the map feature's symbology are reflected in the viewer when refreshed.
Image navigation
Image navigation
provides tools that help you move efficiently between neighboring or sequential images in the oriented imagery viewer, including access to Navigation tool and Image Gallery for exploring additional imagery. Select Image navigation
Directional navigation
—Move between images using directional arrows that indicate the availability of the next image.The arrows appear off-white and are highlighted in blue when you hover over them.
Click an arrow to move to the next image.
If an arrow is disabled or not visible, it means there are no images available in that direction.
For frame imagery, you can maintain camera orientation using the Preserve heading and Preserve pitch options available under Configure navigation
to navigate to imagery with similar camera angles.Sequential navigation
—Move to the previous and next images in the viewer using buttons. The sequence of transition is determined by the data in the sequenceOrderFields property of the oriented imagery layer. The property supports multi-field sorting. The fields are defined as an ordered array. The fields are processed from first to last, and any field without an explicit direction is sorted in ascending order by default.
For additional information on oriented imagery properties refer here.
To visualize additional images of the same location, complete the following steps:
Follow the first five steps of the View oriented imagery layers workflow above.
Select Navigation tool
to explore the images that contain the selected location on the map using a compass.Note:
The selected location is seen as a red cross
in the center of the Navigation tool and on the map. The camera location for images that include the selected map location are shown as points on the tool, arranged based on their distance and heading relative to the red cross icon
. The tool is divided into four quadrants (north, south, east, and west); each quadrant is divided into three segments that show the relative distance of each camera location from the selected location on the map.For the current image in the oriented imagery viewer, the camera location and heading relative to the red cross icon
is shown in red. Additional camera locations depicting the selected map location are shown as blue dots.To view a different image of the selected map location, click a blue dot, or click a tool segment to view the best image from that segment. Segments with images are shown in white; segments without images are gray.
Select Image gallery
to explore a carousel of low-resolution thumbnails of all images that depict the selected map location. Click a thumbnail to view the full-resolution image in the oriented imagery viewer.When additional footprints are shown on the map, hovering over a gallery image highlights the corresponding footprint.
Image gallery only supports the image formats that are internally tiled, such as MRF or COG. It does not support JPEG images (not tiled) and MRF and COG formats without the file extension
.mrfor.tif. The images should be available in publicly accessible cloud storage or as feature attachments (.tifonly). If Image gallery is disabled, the current image in the oriented imagery viewer is not internally tiled or does not have the required file extension.
Image measurement tools
Select the Image measurement tool
to list the various ground and triangulated measurement options that can be applied to the image in the oriented imagery viewer.
Currently, the following ground-related measurement options are available:
Ground distance—Click Ground distance
from the measurement options available in the drop-down menu. Click two or more points on the image in the oriented imagery viewer. The distance between the first and last point selected are calculated and displayed.Ground area—Click Ground area
from the measurement options available in the drop-down menu. Click multiple points on the image in the oriented imagery viewer. The area bounded by the ground points, corresponding to the points selected, are calculated and displayed.Height above ground—Click Height above ground
from the measurement options available in the drop-down menu. In the oriented imagery viewer, click a point at the base of the item, and move the pointer upward to start the measurement. A rubber band that is always perpendicular to the ground plane is displayed, locking the pointer movement direction. Based on the movement of the pointer (up or down), the asset's height above the ground is displayed.Ground location—Click Ground location
from the measurement options available in the drop-down menu, and click the image in the oriented imagery viewer. The ground coordinates in the map that correspond to the selected point are computed and displayed.
The Image measurement tool is enabled only if the Orientation Accuracy property is defined for the oriented imagery layer.
After selecting the measurement option (except Ground location), you must click New measurement.
For all the ground-related measurement options (except Ground location), double-click to identify the last point.
Accuracy is determined by testing the effect of the standard deviation accuracy defined for each orientation parameter and returning the square root of the sum of the errors squared.
Triangulated measurement uses two images of the same object, captured from distinct viewpoints, to determine distance, area, or position. It works by tracing directional vectors through the corresponding measurement points in each image and computing their intersection, which provides the final measurement values. It is dependent on suitable accuracy in the image orientation parameters and is only available if accurate camera orientation values are defined.
Triangulated measurement is supported for Frame imagery only.
Currently, the following triangulated measurement options are available:
Triangulated distance
Triangulated area
Triangulated location
To compute any of the triangulated measurements, complete the following steps:
Select a measurement option from the drop-down menu.
The oriented imagery viewer splits into two. The first oriented imagery viewer (on top) is loaded with the best image of the current location.
Select an image that is positioned at an angle relative to the image in the first viewer using Navigation tool
.The selected image is loaded in the second viewer.
Tip:
The recommended angle between the two images is approximately 45 degrees.
Tip:
The loaded image can be changed if necessary.
Based on the selected measurement option, refer to Image measurement tools to draw a line, polygon, or point in the image displayed in the first oriented imagery viewer (on top), and double-click to end the measurement.
A corresponding vector appears in the second viewer.
Manually align or move the vector in the second viewer to match the location or asset to be measured, and click to finish the edits.
The values of the triangulated measurement are displayed in the measurement toolbox.
Slope and azimuth are also calculated for triangulated distance measurements.
Tip:
Double-click in the second viewer pane to return to edit mode.
Utilities
Utilities include additional tools available for enhancing images and viewing pop‑ups in the oriented imagery viewer. Select Utilities
to access the options described below.
Select Image enhancement
to adjust the brightness, contrast, and sharpness of the image using sliders. The enhancements will be maintained in the oriented imagery viewer and applied to all the images viewed later, until the oriented imagery viewer is closed. Click Reset
to reset to the original values at any time.
Image enhancements are not supported for 360-degree images.
Select Show pop-ups
to view the pop-up for the image in the oriented imagery viewer. See Configure pop-ups to learn more about configuring pop-ups for feature layers.
Turn on the Superimpose view toggle button
to overlay the image currently displayed in the oriented imagery viewer directly onto a 3D scene. The imagery is applied as a texture to a mesh positioned in the scene, allowing users to visualize the image within the spatial context in which it was originally captured.
The superimposed image is rendered in front of existing scene layers, allowing users to compare the captured imagery with surrounding 3D content and to assess spatial alignment and relationships better.
Once the image is superimposed, use the Adjust Mesh position slider to move and adjust the textured mesh between the feature's near and far distance to fine‑tune where the image sits in the 3D space.
Turn off the Superimpose view toggle button to return the image to the oriented imagery viewer.
The superimpose view works exclusively in 3D scenes and is accessible only in applications that support scene‑based visualization.
The Oriented Accuracy property must be defined for the associated oriented imagery layer for Superimpose view to be enabled. Refer to the product documentation for additional details.
Enable video support
The oriented imagery viewer supports video playback in a 2D map and 3D scene.
The footprint or frustum of the current zoomed extent is displayed. During display, standard video viewer tools such as play and pause, video slider, and volume controls are available. In addition, the standard Current footprint, Additional footprints, Additional camera locations, Image overlays, Map‑image location, and Image enhancement tool options are also available.
Only video compatible with standard web browsers is supported. Refer to Common codecs for more information about the supported video types (formats and codecs).
To create an oriented imagery dataset to support video, you must add a record for each keyframe.
To enable video support, complete the following steps:
Place the URL of the video in the
ImagePathfield.Add an
OffsetFromStartfield that defines the time offset in seconds from the start of the video.Assign the following types (as required) to the
OrientedImageryTypefield in the oriented imagery table:TerrestrialFrameVideo—For videos captured from the ground using terrestrial handheld cameras
AerialFrameVideo—For videos captured using aerial and drone cameras
Terrestrial360Video —For videos captured from the ground using terrestrial 360 cameras
Aerial360Video —For videos captured using 360 aerial and drone cameras
For more information, refer to Oriented imagery dataset and Update Oriented Imagery Dataset Properties .
