Get started with notebooks
Notebooks are authored in the notebook editor, which you open from ArcGIS Online. In the notebook editor, you can write, document, and run Python code in one place. This topic introduces the components and menus in the notebook editor.
Open and edit a notebook
To open and edit a notebook, complete the following steps.
Sign in as a member with privileges to create and edit notebooks.
On the navigation bar of your organization, click Notebooks.
The Notebooks home page appears.
Optionally, click the Options button
on an item to do one of the following:Click Preview or View details to see notebooks that you own (in My notebooks) or that have been shared with you (in Shared notebooks or Esri sample notebooks).
Click Delete to remove notebook items that you own (in My notebooks).
Click Open.
The notebook editor opens.
Make edits to the notebook, as needed.
If you own the notebook, click Save to save edits.
Optionally, to save a copy of the notebook to your workspace, do one of the following:
If you already own the notebook, click the drop-down menu
and click Save as to save a copy.If you do not own the notebook, click Save as.
The Save notebook as window appears.
Add a title and, optionally, alter the Folder, Tags, and Summary options.
Click Save notebook.
The notebook is saved and added to My notebooks.
Interface basics
The notebook editor has the following basic components:
Navigation bar—Browse the website, open other apps from the app launcher, view help resources, and sign in or out of your profile. The navigation bar also displays the title of your notebook and indicates whether you have unsaved changes to the notebook.
Top ribbon—Perform various tasks involving your notebook. This ribbon has the following buttons:
Add—Add items to the notebook.
Analysis—Access analysis tools to use in the notebook.
ArcGIS Notebooks assistant (beta)— Use ArcGIS Notebooks assistant (beta) to write, explain, and troubleshoot Python code.
Code snippets—Use Python code snippets in the notebook.
Files—Browse files in your ArcGIS workspace and the data from sample notebooks.
Tasks—Create one or multiple tasks to automate running of the notebook, and specify the task's schedule.
Parameters—Configure notebook parameters for use when running the notebook as a task or a web tool.
Publish—Publish the notebook as a web tool.
Snapshots—Create a snapshot of the notebook.
Share—Share the notebook.
Info—Get information about the notebook. You can edit the notebook's metadata (title, tags, description, terms of use, and credits). You can also view the notebook runtime and its available libraries.
Save—Save the notebook in its present state. When you open a shared notebook, this button reads Save As.
Notebook menu ribbon—The actions on this ribbon are for working directly in the notebook. You can add and delete cells, change the notebook appearance, return the notebook to a previous checkpoint, and more. This ribbon also displays whether the notebook is trusted and the version of Python being run.
Toolbar—Use the tools for common tasks in the notebook.
Workspace—The notebook content is displayed here, and you can modify the content here as well.
The following actions are available from the drop-down lists in the notebook menu ribbon.
The notebook menu ribbon options may differ depending on the runtime version.
File
From the File menu, you can download or export the notebook in one of the following formats:
Markdown (
.md)Notebook (
.ipynb)Reveal.js slides (
.slides.html)
You can also download the notebook in .ipynb format from the notebook's item page.
Edit
The following items are available on the Edit menu:
Undo
Redo
Undo Cell Operation
Redo Cell Operation
Cut Cell
Copy Cell
Paste Cell Below
Paste Cell Above
Paste Cell and Replace
Delete Cell
Select All Cells
Deselect All Cells
Move Cell Up
Move Cell Down
Edit Notebook Metadata
Split Cell
Merge Selected Cells
Merge Cell Above
Merge Cell Below
Clear Cell Output
Clear Outputs of All Cells
Find
Find Next
Find Previous
View
The following items are available on the View menu:
Active Command Palette
Table of Contents
Debugger Panel
Show Line Numbers
Collapse Selected Code
Collapse Selected Outputs
Collapse All Code
Collapse All Outputs
Expand Selected Code
Expand Selected Outputs
Expand All Code
Expand All Outputs
Render Side-by-Side
Run
The following items are available on the Run menu:
Run Selected Cell
Run Selected Cell and Insert Below
Run Selected Cell and do not Advance
Run All Above Selected Cell
Run Selected Cell and All Below
Render All Markdown Cells
Run All Cells
Restart Kernel and Run All Cells
Cell Type—Change the type of the currently selected cell. The options are Code, Markdown, and Raw.
Kernel
The following items are available on the Kernel menu:
Interrupt Kernel
Restart Kernel
Restart Kernel and Clear Outputs of All Cells
Restart Kernel and Run up to Selected Cell
Restart Kernel and Debug
Shut Down Kernel
Settings
The following items are available on the Settings menu:
Theme
JupyterLab Light
JupyterLab Dark
JupyterLab Dark High Contrast
Theme Scrollbars
Increase Code Font Size
Decrease Code Font Size
Increase Content Font Size
Decrease Content Font Size
Increase UI Font Size
Decrease UI Font Size
Auto Close Brackets
Help
This list provides access to information on keyboard shortcuts, the user interface, and the various help documents associated with ArcGIS Notebooks and key Python modules.
Notebook toolbar buttons
The notebook toolbar provides quick access to the most commonly used actions from the notebook menu ribbon. The available buttons, from left to right, are as follows:
Add—Insert a cell below the currently selected cell.
Cut—Cut the currently selected cell.
Copy—Copy the currently selected cell.
Paste—Paste the copied cells below the currently selected cell.
Run—Run the currently selected cell.
Stop—Interrupt the kernel.
Restart—Restart the kernel.
Fast-forward—Restart the kernel and run all cells.
Cell type—Select or change the type of the currently selected cell.
