Add files as items
You can add supported files from your computer, a shared network location, or a cloud location. When you add a file, an item is created in My content that you can share with others so they can download and use the files.
Other reasons to add files as items include the following:
You must sign in with an organizational account to add specific types of files. These are noted with an asterisk in the list of supported file types in What can you add to ArcGIS Online?
Complete the following steps to add a file to ArcGIS Online:
  1. Verify that you are signed in and have the privilege to create, update, and delete content.
  2. On the My content tab of the Content page, click New item.
  3. Choose the location where the file is stored.
    • Your device—Browse to the location of the file on your local machine or a directory on a network share and click Open.
      Alternatively, drag the file into the drop zone at the top of the New item window.
    • Google Drive—Sign in to your Google Drive account.
    • Dropbox—Sign in to your Dropbox account.
    • OneDrive—Sign in to your Microsoft OneDrive account.
  4. If you add a .zip file, specify the following:
    1. Choose the content type from the Item type drop-down menu.
    2. If the item type is a shapefile, file geodatabase, or photos with locations, choose the option to add the file only.
    3. If the item type is a code sample, choose the language of the sample.
    4. If the item is an ArcPad package, choose the type.
    5. Click Next.
  5. If you add a PDF that contains geographic coordinates and projection information, check the box next to This is a Geospatial PDF.
  6. Provide a title.
  7. Choose a folder in My content where you want to save the item.
    Alternatively, choose Create new folder from the menu and provide a folder name to save the item in a new folder.
    Folder names cannot contain 4-byte Unicode characters.
  8. If your organization has set up content categories, click Assign categories and select up to 20 categories to help users find the item.
    You can also start typing a category name to narrow the list of categories.
  9. Optionally, provide tags that describe the item.
    Separate the terms with commas (for example, Federal land is considered one tag, and Federal, land is considered two tags).
    As you type, you can choose any of the suggested tags that appear; suggestions are generated from tags you previously added.
  10. Optionally, provide a summary that describes the item.
  11. Click Save.
Once you add the file, it appears in your content.
Configure item details and share the item if you have sharing privileges.
