ArcGIS.Core.Data.Analyst3D Namespace / TerrainDefinition Class / GetPyramidType Method
Example
    Gets the TerrainPyramidType of the Terrain. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetPyramidType() As TerrainPyramidType
    public TerrainPyramidType GetPyramidType()
    Return Value
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Get Pyramid Information from a TerrainDefinition
      var pyramidType = terrainDef.GetPyramidType();
      var pyramidProps = terrainDef.GetPyramidWindowSizeProperties();
      var method = pyramidProps.Method;
      var threshold = pyramidProps.ZThreshold;
      var strategy = pyramidProps.ZThresholdStrategy;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
