Public Property FilterType As TinFilterType
public TinFilterType FilterType {get; set;}
Here is a brief explanation of the possible combinations between FilterType and DataElementsOnly.
FilterType = All and DataElementsOnly = false; find all elements in the extent. If your extent is the super node extent (see TinDataset.GetSuperNodeExtent) or includes part of the super node extent, then super nodes and the incident edges and triangles will be retrieved.
FilterType = All and DataElementsOnly = true; find all elements in the extent that are classified as "inside". If your extent is the super node extent (see TinDataset.GetSuperNodeExtent) or includes part of the super node extent, then super nodes and the incident edges and triangles will not be retrieved as they are not classified as "inside".
FilterType = InsideTin and DataElementsOnly = false; find all elements inside the TIN not associated with super nodes that are in the extent.
FilterType = InsideTin and DataElementsOnly = true; find all elements inside the TIN not associated with super nodes that are in the extent and classified as "inside"
FilterType = InsideDataArea; find all elements inside the TIN's data area that are in the extent. Elements that are in the TIN's data area are by definition classified as "inside" so the DataElementsOnly property is unnecessary.
// search all nodes that intersect the data extent
using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorsearch = tinDataset.SearchNodes(null))
while (nodeCursor.MoveNext())
using (ArcGIS.Core.Data.Analyst3D.TinNode nodeCurrent = nodeCursor.Current)
// do something with the node
// search within an extent
ArcGIS.Core.Data.Analyst3D.TinNodeFilter nodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
nodeFilter.FilterEnvelope = envelope; //or use any other appropriate envelope
using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorSearch = tinDataset.SearchNodes(nodeFilter))
// search all "inside" nodes
nodeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
// search for super nodes only
nodeFilter.FilterEnvelope = tinDataset.GetSuperNodeExtent();
nodeFilter.SuperNode = true;
// search all single edges that intersect the data extent
using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(null))
while (edgeCursor.MoveNext())
using (ArcGIS.Core.Data.Analyst3D.TinEdge edgeCurrent = edgeCursor.Current)
// do something with the edge
ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
edgeFilter.FilterEnvelope = envelope;
using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(edgeFilter))
// search all "inside" edges
edgeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
// search for hard edges
edgeFilter.FilterByEdgeType = true;
edgeFilter.EdgeType = ArcGIS.Core.Data.Analyst3D.TinEdgeType.HardEdge;
// search all triangles that intersect the data extent
using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleSearchCursor = tinDataset.SearchTriangles(null))
while (triangleCursor.MoveNext())
using (ArcGIS.Core.Data.Analyst3D.TinTriangle triangleCurrent = triangleCursor.Current)
ArcGIS.Core.Data.Analyst3D.TinTriangleFilter triangleFilter = new ArcGIS.Core.Data.Analyst3D.TinTriangleFilter();
triangleFilter.FilterEnvelope = envelope;
using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleSearchCursor = tinDataset.SearchTriangles(triangleFilter))
// search all "inside" triangles
triangleFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
