Public Class TerrainDirtyAreaRendererDefinition Inherits TinSimpleRendererDefinition
public class TerrainDirtyAreaRendererDefinition : TinSimpleRendererDefinition
The dirty area renderer is only valid for TerrainLayer.
Once you define a simple renderer, you can call a surface layer's CanCreateRenderer, CreateRenderer, CanSetRenderer and SetRenderer methods to create and assign a renderer to a surface layer.
var terrainCP_renderers = new TerrainLayerCreationParams(terrain);
terrainCP_renderers.Name = "My LAS Layer";
terrainCP_renderers.IsVisible = true;
// define the edge type renderer - use defaults
var edgeRD = new TinBreaklineRendererDefinition();
// define the face/surface renderer
var faceRD = new TinFaceClassBreaksRendererDefinition();
faceRD.ClassificationMethod = ClassificationMethod.NaturalBreaks;
// accept default color ramp, breakCount
// define the dirty area renderer - use defaults
var dirtyAreaRD = new TerrainDirtyAreaRendererDefinition();
// add renderers to dictionary
var t_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
t_dict.Add(SurfaceRendererTarget.Edges, edgeRD);
t_dict.Add(SurfaceRendererTarget.Surface, faceRD);
t_dict.Add(SurfaceRendererTarget.DirtyArea, dirtyAreaRD);
// assign dictionary to creation params
terrainCP_renderers.RendererDefinitions = t_dict;
// Note: Needs QueuedTask to run
//Create the layer to the terrain
var terrainLayer_rd = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_renderers, map);
var dirtyAreaRendererDef = new TerrainDirtyAreaRendererDefinition();
// accept default labels, symbolTemplate
if (terrainLayer == null)
return;
if (terrainLayer.CanCreateRenderer(dirtyAreaRendererDef))
CIMTinRenderer renderer = terrainLayer.CreateRenderer(dirtyAreaRendererDef);
if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.DirtyArea))
terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.DirtyArea);
System.Object
ArcGIS.Desktop.Mapping.LayerDrawingDefinition
ArcGIS.Desktop.Mapping.TinRendererDefinition
ArcGIS.Desktop.Mapping.TinSimpleRendererDefinition
ArcGIS.Desktop.Mapping.TerrainDirtyAreaRendererDefinition
