ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigation Class / UpdateFilteredFindPathsConfiguration Method
The ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration to update.
Example
    Updates the specified ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub UpdateFilteredFindPathsConfiguration( _
       ByVal filteredFindPathsConfiguration As CIMFilteredFindPathsConfiguration _
    public void UpdateFilteredFindPathsConfiguration(
       CIMFilteredFindPathsConfiguration filteredFindPathsConfiguration
    Parameters
    Exceptions
    ExceptionDescription
    The filteredFindPathsConfiguration is null.
    The filteredFindPathsConfiguration does not exist in the investigation.
    Remarks
    Use this UpdateFilteredFindPathsConfiguration method to change any of the properties of the ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration with the exception of ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration.Name. Use RenameFilteredFindPathsConfiguration to alter the name of a Filtered Find Paths Configuration.
    Example
    Update Filtered Find Paths Configuration
      // access the currently active knowledge graph investigation view
      KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
      KnowledgeGraphInvestigation investigation = activeView?.Investigation;
      if (investigation != null)
        await QueuedTask.Run(() =>
          // update FFPConfig properties
          var myFFPConig = investigation.GetFilteredFindPathsConfiguration("FFPConfig1");
          if (myFFPConig != null)
            //Limit the set of origin entities to just a specific POI entity
            var poi_entity = new CIMFilteredFindPathsEntity();
            poi_entity.EntityTypeName = "POI";
            poi_entity.ID = "{EC2A2D91-B09C-4CF6-93A3-51D6527CF51E}";//upper case guid with "{}"s
            var originEntities = new List<CIMFilteredFindPathsEntity>();
            originEntities.Add(poi_entity);
            //Apply to the configuration origin entities filter
            myFFPConig.OriginEntities = originEntities.ToArray();
            investigation.UpdateFilteredFindPathsConfiguration(myFFPConig);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
