| Name | Description | |
![]() | AddFeatureClass | Overloaded. |
![]() | AddRelationshipClass | Overloaded. |
![]() | Build | Performs all enqueued operations. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | Create | Overloaded. |
![]() ![]() | CreateFileKnowledgeGraph | Creates a new file ArcGIS.Core.Data.Knowledge.KnowledgeGraph at the specified path. |
![]() ![]() | CreateGeodatabase | Overloaded. |
![]() | Delete | Enqueue the delete operation on the object with the name referred to by the Description. This method must be called on the MCT. Use QueuedTask.Run. |
![]() ![]() | DeleteGeodatabase | Overloaded. |
![]() | Modify | Overloaded. |
![]() | RemoveFeatureClass | Overloaded. |
![]() | RemoveRelationshipClass | Overloaded. |
![]() | Rename | Enqueue the rename operation on the object with the name referred to by the Description. This method must be called on the MCT. Use QueuedTask.Run. |
