ArcGIS.Core.Data Namespace / Database Class
    Database Class Methods
    For a list of all members of this type, see Database members.
    Public Methods
     NameDescription
    Public Method Gets a value indicating whether this datastore supports datastore properties. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodCalculates the extent for the spatial single table or query layer specified by featureClass. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the connection string associated with the currently opened data store (e.g., an enterprise geodatabase). This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodOverridden. Gets the DatabaseConnectionProperties associated with the currently opened database. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the datastore properties of the datastore. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodGets the TableDefinition or FeatureClassDefinition (if QueryDescription.IsSpatialQuery in queryDescription returns true) whose Table or FeatureClass is associated with queryDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the path to the currently opened data store (e.g., an enterprise geodatabase .sde connection file). This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodOverloaded.
    Public MethodGets the gateway to access information about the SQL syntax and other functionality supported by this Datastore. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public Method Gets the fully qualified name of all the tables that exist in the currently opened database. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Determines whether the currently opened data store (e.g., an enterprise geodatabase) has any pending edits which have not been saved. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodGets the Table or FeatureClass (if it is spatially enabled) associated with queryDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Top
