CreateGeodatabase(MemoryConnectionProperties) Method
Creating a memory Geodatabase
await QueuedTask.Run(() =>
// Create the memory connection properties to connect to default memory geodatabase
MemoryConnectionProperties memoryConnectionProperties = new MemoryConnectionProperties();
// Alternatively create the memory connection properties to connect to memory geodatabase named as 'InterimMemoryGeodatabase'
// MemoryConnectionProperties memoryConnectionProperties = new MemoryConnectionProperties("InterimMemoryGeodatabase");
// Creates the new memory geodatabase if it does not exist or connects to an existing one if it already exists
using (Geodatabase geodatabase = new Geodatabase(memoryConnectionProperties))
// Create additional schema here
Creating the memory geodatabase
// Creates the default memory geodatabase if not exist or connects to an existing one if already exists
Geodatabase memoryGeodatabase = new Geodatabase(new MemoryConnectionProperties());
// Creates schema
SchemaBuilder schemaBuilder = new SchemaBuilder(memoryGeodatabase);
schemaBuilder.Create(new TableDescription("MyTable", new List<FieldDescription>()));
schemaBuilder.Build();
return memoryGeodatabase;
