ArcGIS.Desktop.Layouts Namespace / GraphicFactory Class / CreateSimpleTextGraphic Method
The type of text graphic to create
The geometry for the resulting graphic
The text symbol to be used with the graphic (optional)
The text string (optional)
Example
    CreateSimpleTextGraphic Method (GraphicFactory)
    Creates a text graphic based on the input geometry, symbol, and text. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CreateSimpleTextGraphic( _
       ByVal textType As TextType, _
       ByVal geometry As Geometry, _
       Optional ByVal textSymbol As CIMTextSymbol, _
       Optional ByVal text As String _
    ) As CIMTextGraphicBase
    Parameters
    textType
    geometry
    textSymbol
    text
    Return Value
    Exceptions
    ExceptionDescription
    empty or null geometry
    Remarks
    For:
    • TextType.PointText use a point
    • TextType.SplinedText use a polyline (straight or curved)
    • TextType.CircleParagraph use a circle (polygon)
    • TextType.EllipseParagraph use an ellipse (polygon)
    • TextType.RectangleParagraph use an envelope
    • TextType.PolygonParagraph use a polygon
    For TextType.PointText and TextType.SplinedText, cast the returned CIMTextGraphicBase to ArcGIS.Core.CIM.CIMTextGraphic. For all paragraph text types cast to ArcGIS.Core.CIM.CIMParagraphTextGraphic.
    Example
    Create Circle Text Graphic
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D center = new Coordinate2D(4.5, 4);
      var eabCir = new EllipticArcBuilderEx(center, 0.5, ArcOrientation.ArcClockwise);
      var cir = eabCir.ToSegment();
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(cir, AttributeFlags.AllAttributes));
      //Set symbology, create and add element to layout
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
        ColorFactory.Instance.GreenRGB, 10, "Arial", "Regular");
      string text = "Circle, circle, circle";
      var graphic = GraphicFactory.Instance.CreateSimpleTextGraphic(
        TextType.CircleParagraph, poly, sym, text);
      //Make an element to add to GraphicsLayer or Layout
      //var ge = ElementFactory.Instance.CreateGraphicElement(layout, graphic,
      //  "New Circle Text", true);
    Create Bezier Graphic
      //Build geometry
      Coordinate2D pt1 = new Coordinate2D(3.5, 7.5);
      Coordinate2D pt2 = new Coordinate2D(4.16, 8);
      Coordinate2D pt3 = new Coordinate2D(4.83, 7.1);
      Coordinate2D pt4 = new Coordinate2D(5.5, 7.5);
      var bez = new CubicBezierBuilderEx(pt1, pt2, pt3, pt4);
      var bezSeg = bez.ToSegment();
      Polyline bezPl = PolylineBuilderEx.CreatePolyline(bezSeg, AttributeFlags.AllAttributes);
            ColorFactory.Instance.BlackRGB, 24, "Comic Sans MS", "Regular");
        TextType.SplinedText, bezPl, sym, "Splined text");
      //var ge = ElementFactory.Instance.CreateGraphicElement(layout, graphic);
    Requirements
