Parameters
- subtype
- If it is a non-null and valid subtype, a RowBuffer will be created for the specified subtype.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
No row is created in the database.
The returned RowBuffer does not have an object ID value.
If the table contains read-only fields with default values (e.g. tables with fields maintained by attribute rules or utility network features with system-maintained fields), we recommend using CreateRowBuffer(Subtype) instead of this overload.
