Customize tool behavior in a Python toolbox
Validation is everything that happens before a tool's Run button is clicked. When creating custom tools, validation allows you to customize how parameters respond and interact to values and each other. Validation is performed with a block of Python code that is used to control tool behavior.
To learn more about validation, see Understanding validation in script tools.
In a Python toolbox, every tool parameter has an associated Parameter object with properties and methods that are useful in tool validation. In a Python toolbox, parameters are defined in the getParameterInfo method of the tool class. The behavior of those parameters, and how they interact with each other and inputs, is validated according to the updateParameters method of the tool class.
Access the tool parameters
Parameter objects form the foundation of how parameters are defined and interact in a Python toolbox. The standard practice is to create the list of parameters in the tool class's getParameterInfo method, as shown in the code below.
def getParameterInfo(self):
#Define parameter definitions
# First parameter
param0 = arcpy.Parameter(
displayName="Input Features",
name="in_features",
datatype="GPFeatureLayer",
parameterType="Required",
direction="Input")
return [param0]
For more about defining parameters in a Python toolbox, see Define parameters in a Python toolbox.
Parameter object
Methods
The Parameter object methods are described in the following table:
Method name |
Usage description |
Marks the parameter as having an error ( |
Marks the parameter as having a warning ( |
Allows you to set a system message. The arguments are the same as the |
Clears any message text and sets the status to informative (no error or warning). |
Returns true if the parameter contains an error. |
Returns true if the parameter contains a warning. |
Returns true if the tool is being validated inside a model and the input value is the output of another tool in the model. |
Properties
Property name |
Read/write |
Value |
Description |
Read-only |
String |
The parameter name. |
Read-only |
String: "Input", "Output" |
Input/Output direction of the parameter. |
Read-only |
String |
For a list of parameter data types, see Parameter data types in a Python toolbox. |
Read-only |
String: "Required", "Optional", "Derived" |
The parameter type. |
Read/write |
Python list |
A list of indexes of each dependent parameter. |
Read/write |
The value of the parameter. |
Read-only |
String |
The default environment setting. |
Read/write |
Boolean |
False if the parameter is unavailable. |
Read-only |
Boolean |
True if the user has modified the value. |
Read-only |
Boolean |
True if the internal validation routine has checked the parameter. |
Read/write |
String |
The category of the parameter. |
Read-only |
The schema of the output dataset. |
Read-only |
The filter to apply to values in the parameter. |
Read/write |
String |
The path to a layer file ( |
Read-only |
String |
The message to be displayed to the user. See |
Although many Parameter object properties are read/write, most of them can only be set or modified when you initially create or modify the object. The following properties establish the characteristics of a parameter and cannot be modified during validation methods (such as updateMessages and updateParameters):
categorycontrolCLSIDdatatypedirectiondisplayNamedisplayOrdermultiValuenameparameterDependenciesparameterType
You typically set parameter dependencies for use by the Schema object. There are two cases in which the dependencies may already be set in the getParameterInfo method of the tool.
For an output dataset parameter with a derived type, the dependency is the index of the parameter from which the output is derived.
For certain input data types, the dependency is the index of the parameter containing the information used by the control, as shown in the table below.
Parameter data type |
Dependant parameter data type |
Areal Unit ( |
A geographic dataset used to determine the default units. For example, the Feature Layer ( |
Field ( |
The table containing the fields. For example, the Table View ( |
Field Mappings ( |
A collection of fields in one or more input tables. For example, the Table View ( |
Geostatistical Value Table ( |
A table of datasets and fields to be used in Geostatistical Analyst tools. Use the Geostatistical Layer ( |
Linear Unit ( |
Network Analyst Hierarchy Settings ( |
The network dataset containing hierarchy information. Use the Network Dataset ( |
Network Travel Mode ( |
A list of travel modes. Use the Network Data Source ( |
SQL Expression ( |
Dependencies are typically set in the getParameterInfo method:
# First parameter
name="in_features",
direction="Input")
# Second parameter
param1 = arcpy.Parameter(
displayName="Sinuosity Field",
name="sinuosity_field",
datatype="Field",
parameterType="Optional",
direction="Input")
param1.value = "sinuosity"
# Third parameter
param2 = arcpy.Parameter(
displayName="Output Features",
name="out_features",
parameterType="Derived",
direction="Output")
param2.parameterDependencies = [param0.name]
param2.schema.clone = True
params = [param0, param1, param2]
return params
value
This is the value of the parameter that the user entered or you set programmatically. You can set the value in the getParameterInfo method, in which case it serves as the initial default value for the parameter. You can also set the value in updateParameters in response to user input, as shown below.
def updateParameters(self, parameters):
# Set the default distance threshold to 1/100 of the larger of the width
# or height of the extent of the input features. Do not set if there is no
# input dataset yet, or the user has set a specific distance (Altered is true).
if parameters[0].valueAsText:
if not parameters[6].altered:
extent = arcpy.Describe(parameters[0]).extent
if extent.width > extent.height:
parameters[6].value = extent.width / 100
else:
parameters[6].value = extent.height / 100
return
A parameter's value property returns an object unless the parameter isn't populated in which case value returns None. To ensure that a parameter is populated, use an if check before using its value.
The code snippet below tests whether the value is equal to the string "Get Spatial Weights From File". This test works because the parameter data type is a string.
# If the option to use a weights file is selected, enable the
# parameter for specifying the file, otherwise disable it
if parameters[3].value: # check that parameter has a value
if parameters[3].value == "Get Spatial Weights From File":
parameters[8].enabled = True
else:
parameters[8].enabled = False
Since a Value object does not support string manipulation, use the Value object's value property whenever a string is to be manipulated or parsed. The code sample below uses the os.path.dirname method to return the directory from a dataset.
if parameters[0].value:
workspace = os.path.dirname(parameters[0].value.value)
With the exception of Describe, don't use methods that take a catalog path, such as ListFields, in validation. The dataset may not exist when your tool is validated in ModelBuilder, and the method may fail or give unexpected results.
In the specific case of ListFields, the Describe object's fields property will provide the equivalent information.
Don't set a parameter value in updateMessages(), since the value will not be validated by the internal validation routine.
altered
The altered property is true if the value of a parameter is changed—by entering an output path, for example. Once a parameter has been altered, it remains altered until the user empties (removes) the value in which case it returns to an unaltered state. Programmatically changing a value with a validation code will change the altered state. That is, if you set a value for a parameter, the altered state of the parameter will be updated.
The altered property is used to specify whether you can change the value of a parameter.
Then, the user enters a point feature class. If the keyword parameter is unaltered, you set the value to RED, since it's the default value.
If a line feature class is entered, you set the default value to ORANGE as long as the keyword parameter is unaltered.
However, if the keyword parameter has been altered by the user (that is, the keyword is set to GREEN), do not reset the keyword. The user has made their choice (GREEN) and you don't know their intention. They may change the feature class so that GREEN is valid, or they may change the keyword (to PURPLE, for example). Since GREEN isn't a member of the set of keywords you created for lines, internal validation flags the parameter with an error. Then, the user has two options: change the input feature class or change the keyword.
if not parameters[2].altered:
parameters[2].value = "POINT"
hasBeenValidated
hasBeenValidated is false if a parameter's value has been modified by the user since the last time updateParameters and internal validate were called. Once internal validate has been called, geoprocessing automatically sets hasBeenValidated to true for every parameter.
hasBeenValidated is used to determine whether the user has changed a value since the last call to updateParameters. You can use this information in deciding whether to do your own checking of the parameter.
# input dataset yet, or the user has set a specific distance.
if parameters[6].hasBeenValidated:
else:
return
