Updating schema in a Python toolbox
Every output parameter of type feature class, table, raster, or workspace has a schema object. Only output feature classes, tables, rasters, and workspaces have a schema; other types do not. The schema object is created for you by geoprocessing. You access this schema through the parameter object and set the rules for describing the output of your tool. After you set the schema rules, the geoprocessing internal validation code examines the rules you set and updates the description of the output.
To review, the flow of control is as follows:
When the tool dialog box is first opened,
getParameterInfois called. You set up the static rules (rules that don't change based on user input) for describing the output. No output description is created at this time, since the user hasn't specified values for any of the parameters (unless you've provided default values).Once the user interacts with the tool dialog box in any way,
updateParametersis called.updateParameterscan modify the schema object to account for dynamic behavior that can't be determined from the parameter dependencies (such as adding a new field like Add Field).After returning from
updateParameters, the internal validation routines are called and the rules found in the schema object are applied to update the description of the output data.updateMessagesis called. You can examine the warning and error messages that internal validation may have created and modify them or add your own custom warning and error messages.
All schema properties are read and write except type, which is read-only.
Property name |
Value |
String: |
Boolean |
String: |
String: |
String: |
String: |
String: |
String: |
List of |
String: |
Double |
String: |
String: |
List of datasets to add to a workspace schema |
Using FirstDependency
Several of the rules can be set to "FirstDependency", which means the value of the first parameter found in the parameter dependency array set will be used with parameter.parameterDependencies. In the code example below, parameter 2 has two dependent parameters, 0 and 1, and the first dependency is parameter 0.
# Set the dependencies for the output and its schema properties
parameters[2].parameterDependencies = [parameters[0].name, parameters[1].name]
If any dependent parameter is a multivalue (a list of values), the first value in the multivalue list is used.
type
The type property is read-only and is set by geoprocessing.
clone
If true, you are instructing geoprocessing to make an exact copy (clone) of the description in the first dependent parameter. The default value is false. Typically, you set clone to true in the getParameterInfo method. If the first dependent parameter is a multivalue (a list of values), the first value in the multivalue list is cloned.
If
parameter.parameterTypeis"Derived", an exact copy is made. This is the behavior of the Add Field tool.If
parameter.parameterTypeis"Required", an exact copy is made, but the catalog path to the dataset is changed. Catalog paths consist of two parts: the workspace and the base name, for example,E:/Data/TestData/netcity.gdb/infrastructure/roads, with the following explanation:Workspace =
E:/Data/TestData/netcity.gdb/infrastructureBase name =
roads
The rules used to construct new output names are as follows:
The base name is the same as the base name of the first input parameter containing a dataset (not the first dependency but the first parameter) appended with the name of the script tool (for example,
roads_MyTool).The workspace is set to the scratch workspace environment setting. If this is empty, the current workspace environment setting is used. If this is empty, the workspace of the first input parameter containing a dataset is used. If this workspace is read-only, the system temp directory is used.
After setting clone to true, all rule-based methods, such as featureTypeRule, geometryTypeRule, and extentRule, are set to "FirstDependency".
The two code examples below do equivalent work. Both examples are based on how the Clip tool creates the output schema.
Example 1: Explicitly setting all rules
class ExampleClipTool1(object):
def __init__(self):
self.label = "Example Clip tool 1"
self.description = "Explicitly setting all rules"
def getParameterInfo(self):
# Input feature class
param0 = arcpy.Parameter(
displayName="Input Features",
name="in_features",
datatype="GPFeatureLayer",
parameterType="Required",
direction="Input")
# Input table
param1 = arcpy.Parameter(
displayName="Clip Features",
name="clip_features",
direction="Input")
# Input workspace
param2 = arcpy.Parameter(
displayName="Output Feature Class",
name="out_feature_class",
datatype="DEFeatureClass",
direction="Output")
# The two input parameters are feature classes.
param2.parameterDependencies = [param0.name, param1.name]
# Feature type, geometry type, and fields all come from the first
# dependency (parameter 0), the input features
param2.schema.featureTypeRule = "FirstDependency"
param2.schema.geometryTypeRule = "FirstDependency"
param2.schema.fieldsRule = "FirstDependency"
# The extent of the output is the intersection of the input features
# and the clip features (parameter 1)
param2.schema.extentRule = "Intersection"
params = [param0, param1, param2]
return params
Example 2: Use clone to set rules to FirstDependency and override the extent rule
class ExampleClipTool2(object):
def __init__(self):
self.label = "Example Clip tool 2"
self.description = "Using clone to set rules to FirstDependency, then overriding the extent rule"
name="in_features",
direction="Input")
# Input table
direction="Input")
# Input workspace
direction="Output")
param2.schema.clone = True
return params
def updateParameters(self, parameters):
# The only property of the clone that changes is that the extent
# of the output is the intersection of the input features
parameters[0].schema.extentRule = "Intersection"
return
featureTypeRule
This setting determines the feature type of the output feature class. This rule has no effect on output rasters or tables.
Value |
Description |
The feature type will be determined by the |
The feature type will be the same as the first parameter in the dependencies. If the first dependent parameter is a multivalue (a list of values), the first value in the multivalue list will be used. |
featureType
When featureTypeRule is "AsSpecified", the value for featureType is used to specify the feature type of the output.
Value |
Description |
The output will contain simple features. The geometry type of the features is specified by |
The output will contain annotation features. |
The output will contain dimension features. |
geometryTypeRule
This setting determines the geometry type (such as point or polygon) of the output feature class.
Value |
Description |
This is the default setting. Typically, you should be able to determine the geometry type in |
The geometry type is the same as the first dependent parameter. If the first dependent parameter is a multivalue (a list of values), the first value in the multivalue list is used. |
The geometries of all dependent parameters are examined and the output geometry type is set to the minimum or maximum type found.
For example, if the dependent parameters are a point and polygon feature class, the minimum will be point, and the maximum will be polygon. |
The geometry type will be determined by the value of the |
geometryType
Set this to the geometry type to use ("Point", "Multipoint", "Polyline", or "Polygon") when geometryTypeRule is "AsSpecified".
extentRule
Value |
Description |
The output extent will be specified in the |
The output extent is the same as the first dependent parameter. If the first dependent parameter is a multivalue (a list of values), the first value in the multivalue list is used. |
The output extent will be the geometric intersection of all dependent parameters. (This is what the Clip tool uses, as shown below.) |
The output extent will be the geometric union of all dependent parameters. |
The output extent will be calculated based on the Extent environment setting. |
Example
# and the clip features (the dependent parameters)
parameters[2].schema.extentRule = "Intersection"
extent
Set this to the extent to use when extentRule is "AsSpecified". You can set the extent with either a space-delimited string or a list with four values. The sequence is xmin, ymin, xmax, ymax.
Example
parameters[2].schema.extentRule = "AsSpecified"
parameters[2].schema.extent = "123.32 435.8 987.3 567.9"
# Alternatively use a list, as follows:
# parameters[2].schema.extent = [123.32, 435.8, 987.3, 567.9]
fieldsRule
The fieldsRule property determines the fields that will exist in the output feature class or table.
In the table below, FID stands for Feature ID but actually refers to the ObjectID field in every feature class or table.
Value |
Description |
No fields will be output except ObjectID. |
Output fields will be the same as the first dependent parameter. If the first dependent parameter is a multivalue (a list of values), the first value in the multivalue list will be used. |
Only the ObjectID of the first dependent input will be written to the output. |
All fields in the list of dependent parameters will be output. |
All fields except ObjectID fields will be written to the output. |
All ObjectID fields will be written to the output, but no other fields from the inputs will be written. |
additionalFields
Along with the fields that are added by the application of fieldsRule, you can add more fields to the output. The additionalFields property takes a list of field objects.
cellSizeRule
The cellSizeRule property determines the cell size of output rasters or grids. Its values are described in the following table:
Value |
Description |
The output cell size is specified in the |
The cell size is calculated from the first dependent parameter. If the dependent parameter is a raster, its cell size is used. For other types of dependent parameters, such as feature classes or feature datasets, the extent of the data is used to calculate the cell size. If the first dependent parameter is a multivalue (a list of values), the first value in the multivalue list is used. |
The output cell size is calculated based on the Cell Size environment setting. |
cellSize
Set the cellSize property to the cell size to use when cellSizeRule is "AsSpecified".
rasterRule
The rasterRule property determines the data type—integer or float—contained in the output raster. Its values are described in the following table:
Value |
Description |
The data type (integer or float) is the same as the first dependent parameter. If the first dependent parameter is a multivalue (a list of values), the first value in the multivalue list is used. |
Integer is considered smaller than float. For example, if there are two dependent parameters, one containing integers and the other containing floats, |
The output raster contains integers (whole numbers). |
The output raster contains floats (fractional numbers). |
rasterFormatRule
The rasterFormatRule property specifies the output raster format, either "Grid" or "Img". The default is "Img", which is an ERDAS IMAGINE format. "Grid" is an Esri format.
additionalChildren
A workspace is a container for datasets (features, tables, and rasters). These datasets are children of the workspace (think of the workspace as the parent). If the tool adds datasets to a new or existing workspace, you can update the description of the workspace by adding descriptions of the children. For example, you have a tool that takes a list of feature classes (a multivalue), modifies them in some way, and writes the modified feature classes to an existing workspace. When the tool is used in ModelBuilder, the workspace is the derived output of the tool, and you can use this workspace as input to the Select Data tool. The Select Data tool allows you to select a child dataset from a container and use it as input to another tool.
The input to additionalChildren is one or more descriptions of the children. The two forms of child descriptions are described in the following table:
Form |
Description |
A feature class, table, raster, dimension, or annotation value as returned by the |
List object of the form |
A list containing a description of the child to be added. Only the first two entries in the list, |
When adding more than one child, provide a list of child descriptions. If you're adding the children in list form, create a list of lists for additionalChildren.
The list form uses the arguments described in the following table:
Argument |
Type |
Description |
Required |
One of the following: |
Required |
The name of the dataset. It can be the base name of the dataset, for example, |
Optional |
A list of field objects. This contains the fields appearing on the child, if known. |
Optional |
A string or list containing the spatial extent of the child. |
Optional |
A spatial reference object. |
These arguments must be supplied in the order shown. To skip an optional argument, use None or '#'.
Examples of setting a workspace schema are below. The examples are based on a script tool that has the following arguments:
Parameter index |
Parameter name |
Property |
0 |
Input feature class |
Feature class—input. |
1 |
Input table |
Table—input. |
2 |
Input workspace |
Workspace—input (an existing workspace that contains the results of the tool). |
3 |
Derived workspace |
Workspace—Derived output obtained from input workspace. The schema of this workspace is modified to contain additional children. |
The tool takes the input feature class and table, copies both to the workspace, adds a new field to the feature class, and creates a polygon feature class in the workspace. (The actual work of the tool isn't important as it only serves to illustrate setting a workspace schema.) The code examples below build on one another, starting with simple usage of additionalChildren.
In getParameterInfo, the output workspace is cloned from its dependent parameter (param2).
class ExampleTool(object):
def __init__(self):
self.label = "Example tool"
self.description = "Example of parameter dependencies"
#Define parameter definitions
displayName="Input feature class",
name="in_features",
direction="Input")
# Input table
displayName="Input table",
name="in_table",
datatype="GPTableView",
direction="Input")
# Input workspace
displayName="Input workspace",
name="in_workspace",
datatype="DEWorkspace",
direction="Input")
# Derived workspaces
param3 = arcpy.Parameter(
displayName="Derived workspace",
name="out_workspace",
parameterType="Derived",
direction="Output")
# Set dependencies to the input workspace parameter
param3.parameterDependencies = [param0.name]
# Copy all existing contents to output
param3.schema.clone = True
params = [param0, param1, param2, param3]
return params
Example: Copy the two inputs (no modifications) to the output workspace:
inFC = parameters[0].value # input feature class
inTable = parameters[1].value # input table
inWS = parameters[2].value # input workspace
if inFC and inTable and inWS:
parameters[3].schema.additionalChildren = [inFC, inTable]
return
Example: The tool creates a new polygon feature class. The only properties known about this new feature class (when validating) are the name ("SummaryPolygon") and type ("polygon").
children = [] # New empty list
children.append(parameters[0].value)
children.append(parameters[1].value)
children.append(["polygon", "SummaryPolygon"])
parameters[3].schema.additionalChildren = children
return
Example: Add a field to the input feature class.
# Create a field object with the name "Category" and type "Long"
newField = arcpy.Field()
newField.name = "Category"
newField.type = "Long"
# Describe the input feature class in order to get its list of fields. The 9.3
# version of the geoprocessing object returns fields in a Python list, unlike
# previous versions, which returned fields in an enumerator.
desc = arcpy.Describe(parameters[0].value)
fieldList = desc.fields
# Add the new field to the list
fieldList.append(newField)
# Create a new child based on the input feature class, but with the
# additional field added
newChild = [desc.shapeType, desc.catalogPath, fieldList,
desc.extent, desc.spatialReference]
# Now create our list of children and add to the schema
children = []
children.append(newChild)
children.append(inTable)
return
To create fields for SummaryPolygon (the new polygon feature class), create a list of field objects similar to the pattern shown in the example above.
Example: Multivalue input
In this example, the first parameter is a multivalue of feature classes. Each feature class in the multivalue is copied to the derived workspace. A new field, "ProjectID", is added to each of the copied feature classes.
# 0 - input features (multivalue)
# 1 - input workspace
# 2 - derived workspace
inVT = parameters[0].value # multivalue ValueTable
inWS = parameters[1].value # WorkSpace
# Add each feature class to the output workspace. In addition,
# add a new field "ProjectID" to each feature class
if inVT and inWS:
rowCount = inVT.rowCount # Row count in MultiValue table
children = []
newField.name = "ProjectID"
for row in range(0, rowCount):
value = inVT.getValue(row, 0)
if value:
d = arcpy.Describe(value)
fieldList = d.fields
# Note -- not checking if field already exists
# Create new child with additional ProjectID
# field and add child to list of children
child = [d.shapeType, d.catalogPath, fieldList]
children.append(child)
parameters[2].schema.additionalChildren = children
return
