Tool definitions in a Python toolbox
Tools are added to a .pyt file as classes. Each tool class must include, at a minimum, the __init__ and execute methods. You can also use the getParameterInfo, isLicensed, updateParameters, updateMessages, and postExecute methods to add control to the behavior of the tool.
Methods used to define a working tool class
Tool method |
Required or optional |
Description |
Required |
Initializes the tool class. |
Optional |
Defines the tool's parameters. |
Optional |
Returns whether the tool is licensed to run. |
Optional |
Called each time the user changes a parameter on the tool dialog box. After returning from |
Optional |
Called after returning from the internal validation routine. You can examine the messages created from internal validation and change them if desired. |
Required |
Runs the tool's source code. |
Optional |
Called after the |
Setting a tool class init method
The __init__ method in a tool class is a standard Python class initialization method. For a tool in a Python toolbox, the __init__ method is used to set the tool properties, including the label and description properties. The tool's name is established by the name of the class (in the example below, the tool name is CalculateSinuosity).
The __init__ method establishes tool properties such as the label and description. Below, a tool named CalculateSinuosity is created.
class CalculateSinuosity(object):
def __init__(self):
self.label = "Calculate Sinuosity"
self.description = "Sinuosity measures the amount that a river meanders within its valley, " + \
"calculated by dividing total stream length by valley length."
Python syntax rules enforce most geoprocessing conventions when naming a Python toolbox tool class. However, avoid underscores in a tool class name, as they cause errors when running tools from ArcGIS Server.
The following properties can be set in a tool's __init__ method:
Property |
Description |
The name of the toolset where the tool is located. A toolset is a way to organize tools in a toolbox. To nest toolsets, separate their names with consecutive backward slashes, for example: |
The description for the tool. |
The display name for the tool as shown in the Geoprocessing pane. |
