DetectChangeUsingChangeAnalysis
Summary
Uses a change analysis raster to create a raster object containing date-of-change information.
The change analysis raster is generated with the Analyze Changes Using CCDC tool or the Analyze Changes Using LandTrendr tool.
Discussion
For more information on how this function works, see the Detect Change Using Change Analysis raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
Syntax
DetectChangeUsingChangeAnalysis(raster, {change_type}, {max_number_of_changes}, {segment_date}, {change_direction}, {filter_by_year}, {min_year}, {max_year}, {filter_by_duration}, {min_duration}, {min_duration}, {filter_by_magnitude}, {min_magnitude}, {max_magnitude})
| Parameter | Explanation | Data Type |
raster |
The input change analysis raster generated with the Analyze Changes Using CCDC tool or the Analyze Changes Using LandTrendr tool. |
Raster |
change_type |
Specifies the type of change to be extracted from the change analysis raster.
The default value is TIME_OF_LATEST_CHANGE. |
String |
max_number_of_changes |
The maximum number of changes per pixel to be calculated. This number corresponds to the number of bands in the output raster. The default is 1, meaning only one change date will be calculated, and the output raster will contain only one band. This parameter is not available when the The default value is 1. |
Integer |
segment_date |
Specifies whether to extract the date at the beginning of a change segment, or the end. This parameter is available only when the input change analysis raster is the output from the Analyze Changes Using LandTrendr tool.
The default value is BEGINNING_OF_SEGMENT. |
String |
change_direction |
Specifies the direction of change to be included in the analysis. This parameter is available only when the input change analysis raster is the output from the Analyze Changes Using LandTrendr tool.
The default value is ALL. |
String |
filter_by_year |
Specifies whether to filter by a range of years.
The default value is False. |
Boolean |
min_year |
The earliest year to use to filter results. This parameter is required if the The default value is 1970. |
Double |
max_year |
The latest year to use to filter results. This parameter is required if the The default value is 2020. |
Double |
filter_by_duration |
Specifies whether to filter by the duration of a change event.
Boolean |
min_duration |
The minimum number of consecutive years to include in the results. This parameter is required if the The default value is 0. |
Double |
min_duration |
The maximum number of consecutive years to include in the results. This parameter is required if the The default value is 50. |
Double |
filter_by_magnitude |
Specifies whether to filter by the magnitude of change.
Boolean |
min_magnitude |
The minimum change magnitude to include in the results. This parameter is required if the The default value is -50. |
Double |
max_magnitude |
The maximum change magnitude to include in the results. This parameter is required if the The default value is 50. |
Double |
Return value
| Data Type | Explanation |
Raster |
The raster object containing detected change information. |
Code sample
Extracts the dates of change for the three largest changes from the change analysis raster.
import arcpy
from arcpy.ia import *
change_analysis_raster = arcpy.Raster('Landsat_CCDC.crf', True)
# Detect the dates of the three largest changes in pixel values over time
largest_change = arcpy.ia.DetectChangeUsingChangeAnalysis(
change_analysis_raster, "TIME_OF_LARGEST_CHANGE", 3)
