TfExponential
Summary
Defines an Exponential transformation function which is determined from the shift and base factor shape–controlling parameters as well as the lower and upper threshold that identify the range within which to apply the function.
Learn more about how the parameters affect this transformation function
Discussion
The tool that uses the TfExponential object is Rescale by Function.
The highest possible function value is limited to one-half of the maximum single-precision floating-point value (FLT_MAX, whose value is 3.402823466 x 1038), the value of which is 1.701411733 x 1038. Any input values that exceed this limit will receive the To scale value on the output raster.
Each increment of high input values can dramatically increase the resulting function range. As a result, when the function range is linearly transformed to the evaluation scale, the higher function values skew the function range so the shape of the Exponential function curve may be lost in the output evaluation scale. Lowering the upperThreshold can be used to truncate some of the high values.
Dive in:
There is a relationship between the baseFactor and the base of the exponential. The formula to change the base to a natural base is:
\(b^x = ({\rm e}^{\large \ln(b)})^x = {\rm e}^{\large x \space * \space \ln(b)}\)
where \({\ln(b)}\) is the baseFactor in the formula used in the TfExponential function \({\rm Exp}((x - shift) * baseFactor\)).
Syntax
TfExponential({shift}, {baseFactor}, {lowerThreshold}, {valueBelowThreshold}, {upperThreshold}, {valueAboveThreshold})
| Name | Explanation | Data type |
shift (Optional) |
Defines how much each input value is to be shifted. The shift value is subtracted from the input value. The transformation function is applied to the shifted input value to determine the function value. The shift can be positive or negative. The default value is None. |
Double |
baseFactor (Optional) |
A multiplier that controls how steep the Exponential function increases. The larger the multiplier, the steeper the curve will be at the larger input values. There is a close connection between the base factor and the base of the Exponential function. A The default value is None. |
Double |
lowerThreshold (Optional) |
Defines the starting value at which to begin applying the specified transformation function. The input value corresponding to the The The default value is None. |
Double |
valueBelowThreshold (Optional) |
A user-specified value to assign output cell locations with input values below the The value for The default value is None. |
Variant |
upperThreshold (Optional) |
Defines the ending value at which to stop applying the specified transformation function. The input value corresponding to the The The default value is None. |
Double |
valueAboveThreshold (Optional) |
A user-specified value to assign output cell locations with input values above the The value for The default value is None. |
Variant |
Properties
shift (Read and Write) |
The value of the |
Double |
baseFactor (Read and Write) |
The value of the |
Double |
lowerThreshold (Read and Write) |
The value of the |
Double |
valueBelowThreshold (Read and Write) |
The value that will be assigned to the output cells whose input values are below the |
Variant |
upperThreshold (Read and Write) |
The value of the |
Double |
valueAboveThreshold (Read and Write) |
The value that will be assigned to the output cells whose input values are above the |
Variant |
Code sample
Demonstrates how to create a TfExponential class and use it in the RescaleByFunction tool within the Python window.
import arcpy
from arcpy.sa import *
from arcpy import env
env.workspace = "c:/sapyexamples/data"
outRescale = RescaleByFunction("distroads", TfExponential(30, 0.00035, "#", "#", "#", "#"), 1, 10)
outRescale.save("c:/sapyexamples/rescaletfex1")
Demonstrates how to transform the input data with the RescaleByFunction tool using the TfExponential class.
# Name: TfExponential_Ex_02.py
# Description: Rescales input raster data using an Exponential function and
# transforms the function values onto a specified evaluation scale.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
env.workspace = "C:/sapyexamples/data"
# Set local variables
inRaster = "distroads"
# Create the TfExponential object
shift = 30
basefactor = 0.00035
lowerthresh = "#"
valbelowthresh = "#"
upperthresh = "#"
valabovethresh = "#"
myTfFunction = TfExponential(shift, basefactor, lowerthresh, valbelowthresh, upperthresh, valabovethresh)
# Set evaluation scale
fromscale = 1
toscale = 10
# Run RescaleByFunction
outRescale = RescaleByFunction(inRaster, myTfFunction, fromscale, toscale)
# Save the output
outRescale.save("c:/sapyexamples/rescaletfex2")
