QQ plot
Quantile-quantile (QQ) plots are an exploratory tool used to assess the similarity between the distribution of one numeric variable and a normal distribution, or between the distributions of two numeric variables.
There are two types of QQ plots, normal QQ plots and general QQ plots.
  • Normal QQ plots are constructed by plotting the quantiles of a numeric variable against the quantiles of a normal distribution.
  • General QQ plots plot the quantiles of one numeric variable against the quantiles of a second numeric variable.
If the distributions of the compared quantiles are identical, the plotted points will form a straight 45-degree line. The farther the plotted points deviate from a straight line, the less similar the compared distributions.
Variables
Normal QQ plots require one numeric variable that will be plotted against a normal distribution. General QQ plots require two numeric variables that will be plotted against each other.
Transformation
Some analytical methods require that data be normally distributed. When the data is skewed (the distribution is lopsided), you might want to transform the data to make it normal. Normal QQ plots allow you to explore the effects of data transformations on the distribution of your data while comparing them to a normal distribution.
Logarithmic transformation
The logarithmic transformation is often used where the data has a positively skewed distribution and there are a few very large values. If these large values are located in your dataset, the log transformation will help make the variances more constant and normalize your data.
Logarithmic transformations can only be applied if all of the variable's values are greater than zero. Any values of zero will result in an error.
Square root transformation
A square root transformation is similar to a logarithmic transformation in that it reduces right skewness of a dataset. Unlike logarithmic transformations, square root transformations can be applied to zero.
Square root transformations can only be applied if all the variable's values are greater than or equal to zero. Any negative values will result in an error.
Inverse transformation
An inverse transformation takes the reciprocal (\(1/x\)) of each value (\(x\)) in the field.
Inverse transformations cannot be applied to zero values. If there are zero values in the field, they are treated as null.
Box-Cox transformation
A Box-Cox transformation applies the following power function to normally distribute values:
\[ x' = \begin{cases} \displaystyle \frac{(x+\lambda_2)^{\lambda_1} - 1}{\lambda_1}, & \lambda_1 \neq 0 \\[10pt] \ln(x+\lambda_2), & \lambda_1 = 0 \end{cases} \]
where \(x'\) is the transformed value, \(x\) is the original value, \(\lambda_1\) is the Power parameter value, and \(\lambda_2\) is the Shift parameter value.
Box-Cox transformations can only be applied to positive values. In cases where negative or zero values exist, use the Shift parameter to ensure all values are positive.
Axes
Several options control the axes and related settings.
Axis bounds
Default minimum and maximum axis bounds are set based on the range of data values represented on the axis. These values can be customized by typing a new desired axis bound value. Clicking the reset icon will revert the axis bound to the default value.
Grid intervals
Configure grid intervals for the x-axis and y-axis using the Interval controls. The default grid intervals will be calculated automatically.
Number format
You can format the way an axis displays numeric values by specifying a number format category or defining a custom format string. For example, you can use $#,### as a custom format string to display currency values.
Learn more about numeric formatting
Appearance
Titles and description
The charts and axes default titles are based on the variable names and chart type. These can be edited on the General tab in the Chart Properties pane. You can also provide a value for the Description option, which is a block of text that appears at the bottom of the chart window.
Color
QQ plots inherit their outline and fill colors from the source layer symbology. By symbolizing a layer with a different attribute than either of the QQ plot variables, a third variable can be shown on the QQ plot visualization.
Guides
Guide lines or ranges can be added to charts as a reference or way to highlight significant values. To add a new guide, go to the Guides tab in the Chart Properties pane, and choose whether you want to draw a vertical or horizontal guide. Click the arrow on the Add guide button, and select one of the following options:
  • Create fixed value line or range guide—Draw a line or range guide at a fixed location. When this option is selected, provide a value for Value where you want the line to draw. To create a range, provide a to value.
  • Create data-driven guide—Draw a data-driven guide. When this option is selected, use the Value drop-down list to select a field whose values will be used to calculate the location of the guide. Select an aggregation option to specify how these values are summarized.
  • Create point or polyline guide—Draw a point or polyline guide. When this option is selected, edit the data table to input x- and y-values that will create the vertices to determine how the guide line is drawn. Enter one vertex to create a point guide. This option is only available when both axes are continuous.
The guide style can be configured using the Symbol style, Line style or Fill color style picker, depending on the guide type. Optionally, add text to the guide by specifying a Label value, and configure the label style by clicking the text swatch adjacent to the input to open the style picker. Data-driven guides always display the guide value (based on the field values and aggregation), and this value will be appended to the end of any text provided for the Label value.
Example
Create a QQ plot to evaluate whether particulate matter samples in California are normally distributed.
  • Compare the distribution of—Particulate Matter
  • With transformation—None
  • To—<Normal Distribution>
QQ plot
