Types of tabular charts
In ArcGIS Pro, you can make several types of charts that visualize various characteristics and relationships in tabular data. Tabular data refers to vector or feature data, as well as stand-alone tables.
Learn how to make a chart
Compare categories and amounts
Chart
Create Bar Chart Bar chart
Use a bar chart to summarize and compare categorical data.
Create Combo Chart Combo chart
Use a combo chart to combine bar and line series in one chart, with optional dual y-axes.
Pie Chart Pie chart
Use a pie chart to visualize part-to-whole relationships using slices to represent proportions.
Matrix Heat Chart Matrix heat chart
Use a matrix heat chart to visualize relationships between categorical variables.
Explore relationships and correlation
Chart
Create Scatter Plot Scatter plot
Use a scatter plot to visualize the relationship between two numeric variables by displaying one variable on the x-axis and the other variable on the y-axis.
Create Scatter Plot Matrix Scatter plot matrix
Use a scatter plot matrix to create a grid of scatter plots visualizing bivariate relationships between combinations of multiple numeric variables.
Visualize distributions and frequency
Chart
Create Histogram Histogram
Use a histogram to visualize the distribution of values in a numeric variable by grouping numbers into bins and measuring the frequency of those groups.
Create Box Plot Box plot
Use a box plot to visualize and compare the distribution and central tendency of numeric values through their quartiles.
Create QQ Plot QQ plot
Use a QQ plot to assess the similarity between the distribution of two numeric variables or between one numeric variable and a standard normal distribution.
Visualize change over time or distance
Chart
Create Line Chart Line chart
Use a line chart to visualize change over a continuous range, such as time or distance.
Data Clock Data clock
Use a data clock to visualize seasonal or cyclical patterns and trends over time.
Calendar Heat Chart Calendar heat chart
Use a calendar heat chart to visualize yearly or weekly patterns in temporal data.
Create Profile Graph Profile graph
Use a profile graph to visualize change in elevation or measure along 3D lines, to chain lines, or to graph output from the Line Of Sight geoprocessing tool.
