Projection during analysis in Spatial Analyst
Available with Spatial Analyst license.
Inputs to an ArcGIS Spatial Analyst extension tool that are in the same coordinate system (same projection and datum) are used directly. If the inputs have different projections, they may be projected to temporary intermediate datasets before the selected tool operates on them. As a result, the coordinate system of the output will be dependent on the coordinate system of the input datasets.
Default behavior
The default behavior determining the coordinate system of the output is described in the following table. When any input dataset is in a different projection from that of the output, it is first projected to that projection.
Relationship of output coordinate system to input data
Input type
Condition
Output coordinate system
Raster only
Only one raster dataset is input.
The output will be in the same coordinate system.
More than one raster dataset is input, and all are in the same coordinate system.
More than one raster dataset is input, and they are in different coordinate systems.
The output will be in the same coordinate system as the first defined input.
Feature only
The only input is feature data.
Both raster and feature
The raster and feature inputs are all in the same coordinate system.
The raster and feature inputs are in different coordinate systems.
The output will be in the same coordinate system as the first raster input.
Override the default
To override the default behavior for coordinate systems, set the Output Coordinate System in the geoprocessing Environment Settings before running the tool. You can set the coordinate system of all output raster datasets to be the same as the current map or the same as a layer in that map, or you can choose a different coordinate system with the Select coordinate system dialog .
Automatically transforming a raster dataset into the common coordinate system in the cases identified above is referred to as projecting on the fly. The transformation method used when projecting rasters on the fly is a piecewise polynomial transformation, where the data is transformed block by block, guaranteeing high accuracy.
When performing repeated operations on a raster dataset that would otherwise be projected on the fly, it is recommended that you project the raster directly before performing the analysis. It is significantly more efficient to only have to project the raster one time instead of each time the operation is run. You will also have more control over the parameters used when projecting. Use the Project Raster tool to project rasters into a different coordinate system permanently.
