ArcGIS requirements for using Dameng
ArcGIS Pro and ArcGIS Server support connections to Dameng databases.
Visit Esri Technical Support for information about the Esri Supported Environment Policy.
The information below applies to ArcGIS Enterprise 12.1 and ArcGIS Pro 3.7.
Supported database versions
The following Dameng releases are the minimum supported with ArcGIS. Patches or updates on these versions are supported but not certified.
Dameng V 8.1.0.147
Dameng V 7.1.6
Dameng V 7.1.5
Database requirements/limitations
Be aware of the following limitations:
Geodatabase functionality is not supported with Dameng.
Dameng is not supported as a data store item in an ArcGIS Enterprise portal.
Dameng is not supported with ArcGIS Enterprise on Kubernetes.
Cloud support
See Requirements for using ArcGIS with databases in the cloud for information about support for database services and databases deployed in the cloud.
Software required to connect to Dameng
Your client machine (for example, the one running ArcGIS Pro or ArcGIS Server) must have the appropriate database client files installed for the RDBMS you are using. These client files are available from their respective RDBMS vendors. See Database clients for more information.
You must use the Dameng 8.x ODBC client to connect from ArcGIS Server on Linux to Dameng.
You can use the Dameng 8.x or 7.x ODBC client to connect from clients on Microsoft Windows to Dameng.
