ArcGIS requirements for using Microsoft SQL Server
ArcGIS Enterprise and ArcGIS Pro support connections to Microsoft SQL Server databases and enterprise geodatabases in SQL Server.
SQL Server databases used to store a geodatabase must be configured with a collation that is not case sensitive.
Visit Esri Technical Support for information about the Esri Supported Environment Policy.
The information below applies to ArcGIS Enterprise 12.1 and ArcGIS Pro 3.7.
Supported database versions
The Microsoft SQL Server releases listed below are the minimum certified versions supported with ArcGIS. SQL Server service packs and cumulative updates on these versions are supported but not certified.
Enterprise, Standard, Developer, and Express editions
Microsoft SQL Server 2025 (64 bit)
Microsoft SQL Server 2025 on Linux (64 bit)
Microsoft SQL Server 2022 (64 bit)
Microsoft SQL Server 2022 on Linux (64 bit)
Microsoft SQL Server 2019 (64 bit)
Microsoft SQL Server 2019 on Linux (64 bit)
Developer edition is only supported in nonproduction environments.
Supported operating systems
If your database management system is installed on a server where ArcGIS products are installed, the server operating system must meet the ArcGIS product system requirements as well as the operating system requirements for your SQL Server version.
If your database is not installed on the same server as an ArcGIS product, see the Microsoft documentation for operating system requirements for your SQL Server version.
Database requirements and limitations
When you use a database connection file (.sde) to access SQL Server data in ArcGIS Pro, you can only edit data that is registered with the geodatabase. To edit database data, publish an editable web feature layer that references the database data, and edit through the web feature layer.
Cloud support
See Requirements for using ArcGIS with databases in the cloud for information about support for database services and databases deployed in the cloud.
Software required to connect to SQL Server
Any client machines that connect directly to SQL Server must have a SQL Server client installed. SQL Server clients for Microsoft Windows and Linux are distributed by Microsoft. SQL Server clients for Windows are also available on My Esri. You must install a client that is the same version or a later version than the SQL Server database to which you want to connect. If you upgrade SQL Server, upgrade the SQL Server clients at the same time. When a version of SQL Server is no longer supported by ArcGIS, the corresponding SQL Server client library is not supported either.
Supported minimum SQL Server client versions are as follows:
SQL Server 2022 and 2025—Microsoft ODBC Driver 18.1 for SQL Server
SQL Server 2019—Microsoft ODBC Driver 18 for SQL Server
Microsoft changed the default encryption setting for the ODBC driver to yes with the release of ODBC Driver 18. To ensure that existing database connections continue to work even if you update to ODBC Driver 18, encryption is set to no by default. To use an encrypted connection instead, you can configure the database connection as described in Encrypted connections to SQL Server databases.
