Privileges for using ArcGIS with a Db2 database
Privileges determine what a user is authorized to do with the data and the database. Assign privileges based on the type of work the person does in the organization.
As an IBM Db2 database administrator, you create groups based on what users need to do in the database, grant privileges to the groups, and add the appropriate users to each group. This page lists the minimum required privileges for common types of users for which you would create groups: data viewers, data editors, and data creators.
These privileges apply to using ArcGIS with a Db2 database. If you need to know the privileges required to use a geodatabase in Db2, see Privileges for geodatabases in Db2.
Type of user
Required privileges
Purpose
Data viewer
CONNECT to the database
SELECT on the following system catalog tables and view:
  • SYSIBM.SYSDUMMY1 (catalog view)
  • SYSCAT.ROLEAUTH
  • SYSCAT.DBAUTH
  • SYSCAT.TABAUTH
These privileges allow the user to connect to the database.
SELECT on other users' tables
Data viewers must have the SELECT privilege on specific tables you want them to query.
Data editor
Data editors require the same privileges as data viewers, as well as these additional privileges.
INSERT, UPDATE, DELETE on other users' tables
CREATEIN, ALTERIN, and DROPIN for the necessary schema
CONTROL, ALTER, DELETE, INSERT, and UPDATE REFERENCES on SYSIBM.SYSDUMMY1
These privileges allow editors to edit data owned by other users.
You can grant any combination of INSERT, UPDATE, and DELETE privileges depending on what editors need to do. Therefore, you can create multiple editor groups and grant the appropriate privileges to each. For example, you can have a full_edit group that has all three privileges as well as SELECT on the tables group members need to edit and an updates_only group that has only SELECT and UPDATE privileges on the tables members need to edit.
Data creator
Data creators require the same privileges as data viewers, as well as these additional privileges.
CREATETAB in database
CONTROL on database objects
These privileges allow data creators to create and own tables and feature classes in the database.
Privileges for Db2
To edit data, publish editable web feature layers that reference the data in your Db2 database.
