Upgrade a geodatabase in Db2
Available with Standard or Advanced license.
The goal of upgrading an enterprise geodatabase is to update the geodatabase system tables, stored procedures, types, and functions to take advantage of new functionality and bug fixes. You may also need to upgrade the database if the version you use is no longer supported for the ArcGIS clients you use.
Install a new version of ArcGIS Pro or ArcGIS Server or apply a service pack, patch, or hot fix to an existing installation and upgrade the geodatabase.
Even if you do not upgrade the geodatabase, the database version you use may no longer be supported with the current release of ArcGIS software. Always check the system requirements to ensure you're still using a supported database release. If the database version is no longer supported, you may need to upgrade the geodatabase. The longer you go between upgrades, the more involved the upgrade process becomes.
When you upgrade the geodatabase using ArcGIS Pro 3.7, the upgraded geodatabase version is 12.1.0.x.
Complete the required steps listed below prior to upgrading, then upgrade the geodatabase using the Upgrade Geodatabase geoprocessing tool or a Python script.
Before you upgrade
Plan ahead before you upgrade any enterprise system, including a geodatabase. Test the new version on a development or test server to ensure that it works with all your client applications.
When you determine that the new system works the way you expect, schedule the upgrade; be sure the necessary staff are available to perform the upgrade and that they have the permissions necessary to complete their assigned tasks.
Be aware of the following:
Upgrades from beta or prerelease versions of the software are not supported.
You can upgrade directly from a 10.8.1, 10.9.x, or 11.x geodatabase if your database release is supported for the ArcGIS versions to which you upgrade.
If the IBM Db2 database is not at a release that is supported for the current geodatabase release, you may have to upgrade the database and the geodatabase more than once before you can upgrade the geodatabase to the current release. The longer you go between geodatabase upgrades, the more upgrades you will have to do to get to the latest geodatabase release.
For each intermediate geodatabase upgrade, follow the upgrade instructions for that geodatabase version, and test the geodatabase as you move from version to version. Similarly, follow the upgrade instructions from the database vendor for each database version, and test as you move from version to version.
There is no formal mechanism to downgrade a geodatabase to a previous version. If, after upgrading to a newer version, you want to downgrade the geodatabase, you can restore the database from a backup file that contains the older geodatabase version.
The following is a checklist of steps to complete before you upgrade the geodatabase:
Ensure that the Db2 and ArcGIS version combination you want to use is supported. See IBM Db2 database requirements for ArcGIS for information.
The database must be at a supported release and your hardware must meet the minimum system requirements before you upgrade the geodatabase.
Read Client and geodatabase compatibility to understand the implications of using mixed ArcGIS client releases and to determine whether specific dataset types must be upgraded separately.
Confirm that the geodatabase can be upgraded. To do this, install the ArcGIS client version you want to move to onto one machine. If you install ArcGIS Desktop, you can connect to the geodatabase and open the Database Properties dialog box to determine whether a geodatabase upgrade is possible. If you install ArcGIS Server, you can use the ArcPy
Describefunction to determine whether the geodatabase can be upgraded. The following example creates a connection to the geodatabase and checks whether the geodatabase can be upgraded:# Open Python. cd /arcgis/server/tools ./python # Import ArcPy. import arcpy # Create a connection to the geodatabase. arcpy.management.CreateDatabaseConnection( "/tmp/", "egdb_connection.sde", "DB2", "mydbgdb", "DATABASE_AUTH", "sde", "mysdepassword", "SAVE_USERNAME", "myconnection" ) # Check the geodatabase release. isCurrent = arcpy.Describe('/tmp/egdb_connection.sde').currentRelease print(isCurrent)If
falseis returned, you can upgrade the geodatabase. Iftrueis returned, you do not need to upgrade the geodatabase. Do not proceed with the subsequent steps.Create a backup of the database.
The sde user must run the
MON_GET_CONNECTIONfunction to remove unneeded connections from the PROCESS_INFORMATION system table. Therefore, grant theEXECUTEprivilege on theMON_GET_CONNECTIONfunction to the sde user.GRANT EXECUTE ON MON_GET_CONNECTION TO SDE;If your database administrator has revoked the
SELECTprivilege on the SYSIBM.SYSDUMMY1 catalog view, the administrator must grant the privilege to all users who connect to the geodatabase in Db2.This privilege is necessary for SQL queries to the database.
If users do not have the
SELECTprivilege on this catalog view, they see an error similar to the following when they try to connect:SQL0551N "SASHA" does not have the privilege to perform operation "SELECT" on object "SYSIBM.SYSDUMMY1". SQLSTATE=42501To grant the
SELECTprivilege on this view toPUBLIC, issue the following command while signed in as a user withDBADMauthority in the database:GRANT SELECT ON SYSIBM.SYSDUMMY1 TO PUBLIC;Grant the sde user
DBADMauthority in the database.This is required to upgrade a geodatabase and can be revoked after upgrading.
Remove any custom functionality you have added to the geodatabase system tables outside ArcGIS, such as triggers or additional indexes.
The upgrade procedure cannot accommodate customizations you make to the system tables. If such customizations prevent the alteration of a system table's schema, the upgrade will fail.
At this point, consider creating a second backup of the database to preserve the changes you made in the preceding steps.
Install the current release of an ArcGIS client—ArcGIS Pro Standard or Advanced or ArcGIS Server—on a computer that can connect to the geodatabase to perform the upgrade.
Ensure that there are no connections to the geodatabase you are upgrading. This includes web services accessing the data in the geodatabase.
To see a list of who is currently connected to the geodatabase, go to the Geodatabase Administration dialog box in ArcGIS Pro.
You can now upgrade the geodatabase.
Upgrade the geodatabase
You can use the Upgrade Geodatabase tool in ArcGIS Pro or a Python script run on an ArcGIS Pro or ArcGIS Server machine to upgrade your geodatabase.
If the geodatabase contains branch versioned data, additional postupgrade steps may be required. See How Upgrade Geodatabase works for instructions.
Use the Upgrade Geodatabase tool
Open the Upgrade Geodatabase geoprocessing tool from one of the following:
The Geodatabase Administration toolset in the Data Management toolbox
The Run Upgrade button on the General tab of the Database Properties dialog box in ArcGIS Pro
If you open the tool from Database Properties, the Input geodatabase text box is prepopulated with the geodatabase connection information.
Esri recommends that you leave the Pre-requisites check and Upgrade geodatabase options checked. That way, the tool confirms that the prerequisites to upgrade have been met before continuing with the geodatabase upgrade.
The prerequisite check detects other active connections to the geodatabase, determines whether the connecting user has sufficient privileges to upgrade the geodatabase, ensures that the database can support XML columns, ensures that all datasets can be opened, and confirms that the database and libraries are at the same release. If any prerequisites are not met, the tool terminates. You must correct any problems before you run the upgrade procedure again.
The results of this check are reported on the geoprocessing tool dialog box. If the check fails, results are also written to the GDBUpgrade.log file in the c:\Users\<user name>\AppData\Local\ESRI\<ArcGIS product> folder.
If all checks pass, the tool proceeds with the upgrade. The status for the prerequisites check and the upgrade are shown on the geoprocessing tool progress dialog box. If the upgrade fails, information is written to the GDBUpgrade.log file. Additional information is written to the sde_setup.log file in your user TEMP directory. If your user does not have a temp directory configured, the system TEMP directory is used.
Run a script
To upgrade the geodatabase using a Python script, copy one of the following example scripts, paste it into a text editor, alter it to use information specific to your site, save and close the file, and run it.
Tip:
For information about running Python from an ArcGIS Server machine, see ArcGIS Server and ArcPy.
The examples assume that you have an existing database connection file (.sde) that connects as the sde user. If you do not have a connection file, create one before upgrading.
# Name: upgradesdegdb_example.py
# Description: Uses existing database connection file
# on a Windows computer to run prerequisite check
# and upgrade an enterprise geodatabase.
# Import arcpy module
import arcpy
# Local variables:
Output_Workspace = "C:\\ArcGIS\connection_files\<Connection file>"
Default_gdb = "C:\\ArcGIS\connection_files\<Connection file>"
# Process: Upgrade Geodatabase
arcpy.management.UpgradeGDB(Default_gdb, "PREREQUISITE_CHECK", "UPGRADE")
# on a Linux computer to run prerequisite check
import arcpy
# Local variables:
Output_Workspace = "<user>/connections/<Connection_file>"
Default_gdb = "<user>/connections/<Connection_file>"
