Cameras table schema
This is a description of the cameras table of the frame camera raster type with a list of supported fields. A frame camera refers to a single perspective imaging camera with an optical lens that can be modeled as a pinhole. The frame camera raster type enables you to manage frame camera imagery in a mosaic dataset.
Cameras table
To use frame camera imagery in a mosaic dataset, you must provide detailed camera parameters and frame information that define a mathematical relationship between the image coordinate system, camera coordinate system, and ground coordinate system.
The following diagram shows how pixels are transformed between the coordinate systems:
The cameras table contains parameters that are unique to each camera, such as focal length, principal point of autocollimation, X and Y coordinates, and optionally, affine transformation coefficients. These parameters define the interior orientation of the camera. The table format can be a geodatabase table, a feature class table, or a .csv file.
You can also use the Build Frames & Cameras Tables tool to create the cameras table in a guided process.
Cameras table fields
The supported cameras table fields are listed below. Note that a parameter definition that is duplicated in the frames table will take precedence over the definition in the cameras table.
Fields supported in the cameras table
Field name |
Field type |
Data type |
Description |
Domain |
ObjectID |
Required |
Numeric |
The unique number identifier for each camera. |
CameraID |
Required |
String |
The primary key identifying the camera parameters. |
FocalLength |
Required |
Numeric |
The focal length of the camera lens, measured in microns. |
PrincipalX |
Optional |
Numeric |
The x-coordinate of the principal point of the autocollimation, measured in microns. If not defined, the default is 0. The principal point is the offset between the fiducial center and the principal point of autocollimation (PPA). The principal point of symmetry (PPS) is assumed to be the same as the PPA. |
PrincipalY |
Optional |
Numeric |
The y-coordinate of the principal point of the autocollimation, measured in microns. If not defined, the default is 0. The principal point is the offset between the fiducial center and the PPA. The PPS is assumed to be the same as the PPA. |
BlockName |
Optional |
String |
The name of the block (project) where the image belongs. |
NRows |
Optional |
Numeric |
The number of rows of pixels in the image. |
NColumns |
Optional |
Numeric |
The number of columns of pixels in the image. |
NBands |
Optional |
Numeric |
The number of bands of pixels in the image. |
PixelType |
Optional |
Numeric or String |
The pixel type for the image, either as a numeric value matching an |
Numeric value matching an rstPixelType: PT_U1=0, PT_U2=1, PT_U4=2, PT_UCHAR=3, PT_CHAR=4, PT_USHORT=5, PT_SHORT=6, PT_ULONG=7, PT_LONG=8, PT_FLOAT=9, PT_DOUBLE=10, PT_COMPLEX=11, PT_DCOMPLEX=12, PT_CSHORT=12, PT_CLONG=14. |
Matching string: 8_BIT_UNSIGNED, 8_BIT_SIGNED, 16_BIT_UNSIGNED, 16_BIT_SIGNED, 32_BIT_UNSIGNED, 32_BIT_SIGNED, 32_BIT_FLOAT, 1_BIT, 2_BIT, 4_BIT, 64_BIT. |
PixelSize |
Required |
Numeric |
The sensor pixel size. |
Unit is micron. |
FilmCoordinateSystem (FCS) |
Optional |
Integer |
Defines the film coordinate system of a scanned aerial photograph, and digital aerial camera. It is used in computing fiducial information and affine transformation construction. Note:Common practice of the digital aerial camera case is the camera's X is aligned with flight direction (option 1, X_RIGHT_Y_UP, the default). FCS is used to accommodate non standard cases. |
SRS |
Optional |
String |
The coordinate system associated with the perspective point as a file path or WKID (EPSG code). For EPSG code, the coordinate system for x,y and z are separated by a semicolon (;), for example 26918;5773. If not defined, it defaults to the user-specified coordinate system or the coordinate system defined in the mosaic data spatial reference. The spatial reference can be defined for each image item in the mosaic dataset as well. If the SRS parameter is defined in both the cameras table and the frames table, the value in the frames table will take precedence. |
OrientationType |
Optional |
String |
Specifies how the rotational Exterior Orientation (EO) parameters are described. The default is |
OPK—Indicates that the rotational EO parameters are defined as angles in the Omega, Phi, Kappa, Angle Direction, and Polarity fields. |
Matrix—Indicates that the rotational EO parameters are defined as a matrix of nine coefficients in the Matrix field. |
AverageZ |
Optional |
Numeric |
The average ground height. The default is the value specified in the raster type's orthorectification properties, or zero if it's not specified. |
ApplyECC |
Optional |
Boolean |
Indicates whether to account for the curvature of the earth when applying transformations with respect to ground coordinates. The default is |
True—Accounts for the curvature of the earth when applying the transformations with respect to ground coordinates. |
False—Assumes the earth is flat. |
EarthRadius |
Optional |
Numeric |
An alternative value to use for the curvature of the earth adjustment. The default value is |
Units are meters. |
AngleDirection |
Optional |
String |
Specifies the direction of the EO angles. The default value is |
-1: Indicates that the EO angles are specified in the clockwise direction. |
+1: Indicates that the EO angles are specified in the counterclockwise direction. |
Polarity |
Optional |
Numeric |
Indicates whether the image plane is presumed to be on the same or the opposite side of the perspective center as the object or ground plane. The default is |
-1: Indicates the opposite side of the image-plane. |
+1: Indicates the same side of the image-plane. |
DistortionType |
Optional |
String |
Specifies how the lens distortion is described. The options are |
The default is Distortion Model. |
Distortion Model—Indicates that the distortion correction is described by the coefficients defined in the |
Distortion Table—Indicates that distortion is defined as a set of (r,v) pairs indicating radial distance and corresponding distortion value. The RadialDistances and RadialDistortions. fields must be populated. |
Radial |
For Distortion Type = DistortionModel |
String |
Specifies the set of four space- or semicolon-delimited coefficients describing radial distortion, for example, 0;0;0;0 for K0;K1;K2;K3. The coupling unit is millimeter (mm). If there are three radial distortion parameters provided, leave k0 equal to zero, and enter values for k1, k2, and k3. If parameters are provided with no coupling unit, which is common in computer vision applications, convert the parameters using the following equations, where f is the focal length in millimeters and K1_cv is the computer vision parameter without a coupling unit:
Tangential |
String |
Specifies the set of two space- or semicolon-delimited tangential distortion coefficients, for example, 0;0 for P1;P2. The coupling unit is millimeter (mm). If parameters are provided with no coupling unit, convert the parameters using the following equations, where f is the focal length in millimeters and p1_cv is the computer vision parameter without a coupling unit:
RadialDistances |
Optional |
String |
The space- or semicolon-delimited radial distances are indicated as an ordered set of N values <r[i]>. Each r[i] distance value has a corresponding d[i] distortion value in the The unit is micrometers. |
RadialDistortions |
Optional |
String |
The space- or semicolon-delimited distortion values are indicated as an ordered set of N values <d[i]>. Each d[i] distortion value corresponds to the distance value r[i] in the The unit is micrometers. |
FilmFiducials |
Optional |
Numeric |
Stores fiducial coordinates for the camera in microns. |
The format is value pairs separated by semicolons, for example, "106003.0 -106000.0;-105997.0 -106001.0;-106002.0 105998.0;105999.0 106000.0". This example shows four corner fiducials, whereas some cameras may have four edge fiducials, while other cameras may have 8 fiducial locations. |
AffineDirection |
Optional |
String |
Specifies the direction of the IO affine transformation. If not specified, a default direction of image-to-film (+1) is assumed. |
+1: image-to-film. |
-1: film-to-image. |
A0, A1, A2 and B0, B1, B2 fields |
Optional. Not required when pixel size and FCS are defined. |
Numeric |
The coefficient of the affine transformation that establishes a relationship between image space and film space. The direction of this transformation is indicated using the
Instead of calculating A0, A1, A2 and B0, B1, and B2, it is recommended that you define the pixel size of the camera, which is used to automatically determine the affine parameters. The camera's pixel size is typically supplied with a camera's calibration information. If the camera's pixel size is not provided, you can compute it using the equation below:
\(Pixel \space Size \space = \space CCD \space Diagonal \space / \space Image \space Diagonal(in \space pixels)\)
where
\(CCD \space Diagonal \space = \space 2 \space * \space (Focal \space Length \space * \space Tan(FOV/2))\)
Cameras table example
A sample cameras table stored as a geodatabase table is shown below. This table references the possible fields above. The sample contains one row, since only one camera was used.
Sample cameras table
OBJECTID |
CameraID |
Focal Length (µm) |
Principal X (µm) |
Principal Y (µm) |
Pixel Size (µm) |
1 |
UltraCamXp_Pan |
100500 |
-120 |
0 |
6 |
2 |
UltraCamXp_MS |
100500 |
0 |
0 |
18 |
