Frames table schema
A frame camera refers to a single-perspective imaging camera with an optical lens that you can model as a pinhole. The frame camera raster type allows you to manage frame camera imagery in a mosaic dataset.
Frames table
To use frame camera imagery in a mosaic dataset, you must provide detailed camera parameters and frame information that define the mathematical relationship between the image coordinate system, camera coordinate system, and ground coordinate system. Image points in the camera coordinate system are related to corresponding points in the ground coordinate system based on the exterior orientation parameters defined in the frames table and a suitable DEM. The following diagram shows how pixels are transformed between the coordinate systems:
The frames table contains the camera exterior orientation information that is specific to each frame, such as frame camera image path; perspective x-, y-, and z-coordinates; and omega, phi, and kappa values. The table format can be a geodatabase table, a feature class table, or a .csv file. You can also use the Build Frames and Cameras Tables tool to create the frames table in a guided process.
Frames table fields
The supported frames table fields are listed below. Note that a parameter definition in the frames table takes precedence over any duplicate definitions in the cameras table.
Fields supported in the frames table
Field name |
Field type |
Data type |
Description |
ObjectID |
Required |
Numeric |
The unique number identifier for each image. |
Raster |
Required |
String |
The path to the image file. |
CameraID |
Required |
String |
The primary key identifying the camera parameters. This must match the |
PerspectiveX |
Required |
Numeric |
The x-coordinate of the perspective center in the ground coordinate system. The units are in the coordinate system units. Geographic coordinate system units are not supported. Specify the |
PerspectiveY |
Required |
Numeric |
The y-coordinate of the perspective center in the ground coordinate system. The units are in the coordinate system units. Geographic coordinate system units are not supported. Specify the |
PerspectiveZ |
Required |
Numeric |
The z-coordinate value of the perspective center in the ground coordinate system. The z-coordinate units should be consistent with the x- and y-coordinate units. The z-coordinates are typically expressed as orthometric heights, which means elevation above sea level. This is appropriate if you'll be inputting a DEM that is also using orthometric heights. If you have z-coordinates that are using ellipsoidal heights, your DEM should also be in ellipsoidal heights. When z-units are ellipsoidal and the DEM is orthometric, you can use the Geoid flag to enable an approximate correction. |
Omega |
Required* |
Numeric |
The rotational angle of the camera's x-axis in degrees. The units are in decimal degrees. |
Phi |
Required* |
Numeric |
The rotational angle of the camera's y-axis in degrees. The units are in decimal degrees. |
Kappa |
Required* |
Numeric |
The rotational angle of the camera's z-axis in degrees. The units are in decimal degrees. |
CenterLongitude |
Optional |
Numeric |
Longitude origin point of Local Tangent Plane Coordinate System in degrees defined in WGS 1984. This is required for frame camera and pushbroom datasets, which have adjustment done in Local Tangent Plane coordinate system. |
CenterLatitude |
Optional |
Numeric |
Latitude origin point of Local Tangent Plane Coordinate System in degrees defined in WGS 1984. This is required for frame camera and pushbroom datasets, which have adjustment done in Local Tangent Plane coordinate system. |
Matrix |
Required* |
String |
The matrix describing the transformation from image space to map space. The matrix is specified as nine floating-point values, which are delimited by spaces or semicolons. |
Shape |
Optional |
Geometry |
The polygon identifying the region containing valid image data. This polygon becomes the footprint of the corresponding mosaic dataset item. |
Name |
Optional |
String |
An alias name to identify the image. If this is left blank, the image file name is used. |
Tag |
Optional |
String |
A tag that allows the image to participate in a function template. |
GroupName |
Optional |
String |
An optional categorization for images. All images with the same group name participate together in a function template. |
SRS |
Optional |
String |
The coordinate system associated with the perspective point as a file path or WKID (EPSG code). For EPSG code, the coordinate system for x,y, and z are separated by a semicolon (;), for example 26918;5773. If not defined, it defaults to the data-specified or mosaic dataset SR. The spatial reference can be defined for each image item in the mosaic dataset as well. If the |
ImageFiducials |
Optional |
String |
Stores film fiducial image coordinates (as measured for each unique image in the frame table) separated by semicolons. The image coordinate system has an origin in the upper left corner, and the order of the coordinates is clockwise. The unit is pixel. An example is "108 111;5014.0 113;5012.0 5010.0;109 5013.0". Note:In most instances, the measured fiducial coordinates will be computed automatically in the ortho mapping workspace. |
FCS |
Optional |
Numeric |
Values of 1, 2, 3, or 4, where 1 represents X_Right_Y_Up, 2 represents X_Up_Y_Left, 3 represents X _Left_Y_Down, and 4 represents X_Down_Y_Right. |
StripName |
Optional |
String |
The identification number of a flight strip. |
PriorAccuracyX |
Optional |
Numeric |
The accuracy of the x-coordinate provided by the airborne Position Orientation System (POS). The units must match PerspectiveX. |
PriorAccuracyY |
Optional |
Numeric |
The accuracy of the y-coordinate provided by the airborne Position Orientation System (POS). The units must match PerspectiveY. |
PriorAccuracyZ |
Optional |
Numeric |
The accuracy of the z-coordinate provided by the airborne Position Orientation System (POS). The units must match PerspectiveZ. |
PriorAccuracyOmega |
Optional |
Numeric |
The accuracy of the Omega angle provided by the airborne Position Orientation System (POS). The units are in decimal degrees. |
PriorAccuracyPhi |
Optional |
Numeric |
The accuracy of the Phi angle provided by the airborne Position Orientation System (POS). The units are in decimal degrees. |
PriorAccuracyKappa |
Optional |
Numeric |
The accuracy of the Kappa angle provided by the airborne Position Orientation System (POS). The units are in decimal degrees. |
GPTTime |
Optional |
Numeric |
GPS time, sometimes referred to as GPSTime. This is the time stamp recorded by the GNSS receiver. It represents the exact time (in GPS time scale, not UTC) when the camera exposure was triggered. GPS time is continuous (no leap seconds) and is critical for georeferencing imagery and synchronizing with external sensors. |
IMUTime |
Optional |
Numeric |
The Inertial Measurement Unit (IMU) time. The IMU records accelerations and angular rates at a high frequency. Each IMU observation is time stamped with its own internal clock. When IMU time differs slightly from GPS time, time synchronization is applied to align GPS (position fixes) with IMU (orientation/attitude data) during processing. |
Required*—The frames table must have either the Omega, Phi, and Kappa fields or the Matrix field for the data to be added to the mosaic dataset. If both types of EO exist in the table, the transformation matrix value will be used.
Frames table example
A frames table stored as a geodatabase table is shown below, where only a selection of the available fields are being used. Since four frames (images) are used in this example, there are four rows in the table.
Sample frames table
OBJECTID |
CAMERAID |
RASTER |
PERSPECTIVEX |
PERSPECTIVEY |
PERSPECTIVEZ |
OMEGA |
PHI |
KAPPA |
1 |
[0] |
512435.5404 |
3974985.555 |
958.42006 |
-4.485 |
-0.545 |
171.598 |
2 |
[0] |
512234.9366 |
3974978.869 |
961.96833 |
-0.834 |
-0.785 |
172.683 |
3 |
[0] |
512016.6162 |
3974971.704 |
969.68074 |
-1.177 |
0.994 |
171.427 |
4 |
[0] |
511799.7245 |
3974972.277 |
976.05905 |
-0.996 |
-1.061 |
171.542 |
