Imagery appearance
The Raster Layer, Mosaic Layer, and Image Service Layer tabs contain essential raster functionality that allows you to adjust the display and appearance of your imagery.
Visibility Range
Use the Maximum scale
and Minimum scale
values to limit the visibility of a raster to be between specific scales. Choose from one of the preset options in the drop-down menu or provide a custom scale in the text box. Click the Scale Range button
to turn the scale range on or off without changing the scale range values.
Effects
The Effects options allow you to specify how layers are displayed.
Use the Transparency slider to reduce the opacity of the selected raster. Doing so makes the underlying raster visible. The selected raster must be the uppermost layer in the Contents pane for you to visualize its transparency and reveal the underlying layer.
Layer Blend draws the entire layer and blends it with the content below it in the drawing order. Each mode performs a type of mathematical calculation on the layer to accomplish various goals, such as drawing topography above background layers but keeping its labels visible. For more information, see Layer blending.
Compare
The Compare group allows you to compare two overlapping rasters.
Use the Swipe tool
to peel back the raster on top, revealing the raster underneath it. To deactivate Swipe, on the Map tab, click the Explore button.
Use the Flicker tool to turn the layer on and off at a specified time interval to reveal the layers below. The time interval is specified in milliseconds.
Rendering
The Rendering group allows you to control the display of rasters and imagery by adjusting the Symbology, Stretch Type, DRA (dynamic range adjustment, Lock stats (lock statistics), Resampling Type, Band Combination, and Masking options.
The Symbology button is the principal interface for managing the display controls. The lower portion of the button is a drop-down menu with a selection of renderers specific to the type of data you are working with. If you hover over the button, the part of the button that is active turns blue. Click the button to open the Symbology pane, which gives you access to all of the parameters related to setting symbology, such as Stretch Type, DRA, Resampling Type, and Band Combination, including quick access directly from the tab.
The Symbology options are described below. For more information, see Change the symbology of imagery.
Stretch—Displays values along a color ramp for a single band. If the layer has multiple bands, you can select a single band from the Band drop-down list.
RGB—Displays the raster using a three-band composite: red, green, and blue. You can choose the band you want to display for each of the Red, Green, and Blue display bands. An alpha band is also supported, which acts as a transparency mask, providing a transparency value for each pixel. An alpha band can be turned on or off for multiple-band raster datasets rendered with the RGB renderer.
Classify—Assigns a color for each class or group of values.
Unique Values—Assigns a color for each value.
Shaded Relief—Displays a color 3D representation of the terrain created by merging the images from the elevation-coded and hillshade methods.
Colormap—Applies the color map associated with the dataset.
Discrete—Applies a new color for each unique value until you reach the number of colors specified; then the unique value starts at the beginning of the color scheme until it reaches the number of colors specified again. This rendering process continues until all unique values have been displayed. This is helpful for rasters with many unique values, when you do not need a legend.
You can control how the range of values is displayed using the Stretch Type button. The lower portion of the button is a drop-down list that allows you to choose the contrast stretching method. Click the button to open the Histogram page in the Symbology pane.
The Stretch Type options are as follows:
None—No stretch method is applied to the layer, even if statistics exist. To display data other than 8-bit data, image values are linearly mapped between 0 and 255. None allows you to examine absolute values in raster datasets.
Minimum Maximum—Applies a linear stretch based on the output minimum and maximum pixel values, which are used as the endpoints for the histogram. For example, in an 8-bit dataset, the minimum and maximum values can be 33 and 206. A linear stretch is used to distribute the values across 256 values, from 0 to 255. This increases the ability to see differences in values throughout the dataset. Minimum Maximum is a good choice for standardizing the appearance of multiple rasters for comparison.
Percent Clip—Cuts off a percentage of the highest and lowest values and applies a linear stretch to the remaining values across the available dynamic range of the data type. This reduces the effects of outliers and enhances the remaining data.
Standard Deviation—Applies a linear stretch between the values defined by the standard deviation (n) value. For example, if you define a standard deviation of 2, the values beyond the second standard deviation become 0 or 255, and the remaining values are linearly stretched between 0 and 255.
Histogram Equalization—A nonlinear contrast stretch is applied in which the values are spread out throughout the bit depth range. This method is appropriate when there are many pixel values that are closely grouped.
Custom—Applies the custom stretch specified by the histogram settings on the Symbology pane.
Histogram Specification—Applies the specified piecewise histogram to display the pixels values. The piecewise histogram allows you to map the input pixel values to a rendered value.
Esri—Uses a modified sigmoidal stretch that uses an S curve to find the mean, which helps prevent pixel values from being stretched beyond the maximum value. This method is used to provide a good overall contrast stretch to imagery.
Square Root—Applies a linear stretch on the square root values of the pixels. This option is only available when displaying SAR data with the Stretched symbology option.
Logarithm—Applies a linear stretch on the 10log10 values of the pixels. This option is only available when displaying SAR data with the Stretched symbology option.
DRA is a feature that automatically adjusts the active stretch type as you navigate around an image based on the pixel values in the current display. You can turn this on or off using the DRA button
. To apply the statistics of the DRA to an entire raster layer, click the Lock stats button
, and the statistics of the region will be used to update the custom statistics.
Alter the image resampling type using the options in the Resampling Type drop-down list. Nearest Neighbor more closely retains the original pixel values, whereas the other resampling techniques produce a smoother image by interpolating values.
The Resampling Type options are as follows:
Nearest Neighbor—Assigns the value from the closest pixel. This is appropriate for spectral analysis and classification because it preserves the original pixel values. It is also applied to qualitative data, such as land cover. The tradeoff is that you may see artifacts where the realignment of pixels presents a break in the feature. The maximum spatial error is one-half the cell size.
Bilinear—Interpolates the new value based on a weighted distance average of the four nearest pixels. This is appropriate for continuous datasets, such as imagery and elevation datasets.
Cubic—Performs a cubic convolution and determines the new value of a pixel based on fitting a smooth curve through the 16 nearest input pixel centers, using a 4 by 4 matrix. This is appropriate for continuous datasets used for visualization purposes. It produces a smooth output with less geometric distortion than the Nearest Neighbor option, but it may result in the output raster containing values outside the range of the input raster.
Majority—Assigns the most popular value from the 4 by 4 filter window. This is appropriate for resampling categorical or integer data, such as land use, soil, or forest type. Majority resampling acts as a type of low-pass filter for discrete data, generalizing the data and filtering out anomalous data values.
Band Combination—Provides popular band combinations for displaying imagery such as natural color and color infrared that highlight vegetation.
If you have a raster product or an image service selected in the Contents pane, you see all of the band combinations associated with that data in the drop-down menu. Popular band combinations are available depending on sensor type and bands. Hover over the band combination to display the associated band name and number. The following image is an example from Landsat 8:
You can also create custom band combinations. To do this, select Custom, load the bands you want into each color, and click Add. Then you can select them from the drop-down menu.
The Masking button allows you to choose a feature class in the Contents pane to mask out the selected raster. This is helpful if you already have a feature class of the area that needs to be masked out.
Enhancement
In the Enhancement group, adjust the display of a raster dataset using the Contrast, Brightness, and Gamma sliders. Move the sliders accordingly, or provide values. To reset the sliders, click their respective buttons.
Rotation
When displaying imagery that was collected off-nadir from vertical, buildings and other ground features appear to lean at a variety of disorienting angles, making oblique imagery hard to interpret. It can be easier to analyze imagery if building lean is oriented upward toward the top of the display. When imagery has the necessary image-orientation metadata—usually found in RPC or aerial imagery orientation files—ArcGIS Pro uses that information to rotate the imagery so buildings are pointed toward the top of the image using the Up is Up rotation type. To revert to the map view, use the North button.
When using a focused image displayed in the image coordinate system (ICS), the None button is available to set the map to the unrotated view of the image. The button is only enabled for images displayed in ICS.
