Raster and imagery default options
The raster and imagery default options allow you to change settings, which are applied to all of your imagery and raster datasets. You can access these options from Project tab > Options > Raster and Imagery.
The raster and imagery options consist of the following categories:
Appearance
Cache
Raster dataset
Mosaic dataset
Perspective imagery
Raster formats
Appearance
The Appearance options allow you to set rendering defaults for rasters that you add to a view.
Check the Use band wavelength information when available check box to allow ArcGIS Pro to determine which bands are used to display multispectral data as RGB. Due to technological advances, more sensors are incorporating additional bands of information. If you consistently work with a sensor that is not one of the raster products, it may make sense to uncheck this check box and alter the Three band data and Multispectral data defaults.
The Color Scheme section allows you to set a default color scheme for the following symbology types: Classify, Discrete, Stretched, and Unique Value. To enable this option, check the Enable custom color schemes check box. Then select a default color scheme to use instead of the system default. If you want to go back to the system default, click the Reset button or uncheck Enable custom color schemes.
The Set default RGB composition section allows you to manually set the bands used as the red, green, and blue composite. You can set the band composition differently for Three band data and Multispectral data. You can type the band number in the box, or you can use the up and down arrows to adjust the band number. If a raster product is added to a view, ArcGIS Pro overrides these defaults if the Use band wavelength information when available check box is checked.
You can use the Enable custom rendering defaults option to set a specific way to display all of your datasets. Leave this disabled if you tend to work with many kinds of data, such as satellite imagery, elevation data, or classified raster datasets. Enable this setting if you work with a specific type of dataset.
You can display the background of a raster dataset in a specific color or with transparency. This allows you to hide or highlight the background. To display the background value in a specific color, check the Display background value check box, and specify the background value and the color. Usually, the background color is set to transparent so that it is hidden.
The NoData color allows you to hide or highlight these values. Typically, the NoData color is set to transparent so that the NoData values are hidden.
Cache
When checked, if an image service has cache generated, it displays the image service cache rather than the image service.
Raster dataset
The Build pyramid settings expander allows you to set the Build pyramid dialog settings, Resampling method, Compression method, and Compression quality.
Parameter |
Description |
Build pyramid settings |
Choose how to handle raster datasets that do not have pyramids built:
Resampling method |
Choose the resampling method used when building pyramids:
Compression method |
Choose the compression type to use when building the raster pyramids:
Compression quality |
The compression quality to use when pyramids are built with the JPEG or JPEG YCbCr compression method. The value must be between 0 and 100. The values closer to 100 produce a higher-quality image, but the compression ratio is lower. |
The Calculate statistics expander allows you to set the Calculate statistics dialog box settings, X Skip Factor, and Y Skip Factor.
Parameter |
Description |
Calculate statistics settings |
Choose how to handle raster datasets that do not have statistics calculated:
X Skip Factor |
The number of horizontal pixels between samples. A skip factor controls the portion of the raster that is used when calculating the statistics. The input value indicates the horizontal or vertical skip factor, where a value of 1 will use each pixel and a value of 2 will use every second pixel. The skip factor can only range from 1 to the number of columns/rows in the raster. The value must be greater than zero and less than or equal to the number of columns in the raster. The default is 1 or the last skip factor used. |
Y Skip Factor |
The number of vertical pixels between samples. A skip factor controls the portion of the raster that is used when calculating the statistics. The input value indicates the horizontal or vertical skip factor, where a value of 1 will use each pixel and a value of 2 will use every second pixel. The skip factor can only range from 1 to the number of columns/rows in the raster. The value must be greater than zero and less than or equal to the number of rows in the raster. The default is 1 or the last y skip factor used. |
Check Use world file to define the coordinates of the raster if you want to override the dataset's native georeferencing with the world file information.
Check Create tiled TIFF to write out tiled TIFF files. If the box is not checked, stripped TIFF files are created.
The Maximum number of values to display option is set to 65,536 by default. This is the maximum number of values you can get with 16-bit data. Increasing this number allows you to work with datasets that have a greater bit depth without scaling them down to 16 bit; however, this increases computational effort and lowers performance.
The Proxy files location allows you to work around restrictions that system administrators put on data repositories. For example, if you need to build pyramids for an image but only have read permissions to that folder, the pyramids are built in the proxy location.
Mosaic dataset
These options allow you to control how a mosaic dataset is presented in the Contents pane.
Expand the mosaic dataset—Display its component layers, boundary, footprint, and image in the Contents pane.
Show the boundary on the map—Display the full extent of the dataset as a polygon on the map.
Show the footprint on the map—Show the extent of each raster within the mosaic dataset on the map.
Show the seamlines on the map—Use the Build Seamlines tool to create a smoother-looking mosaic dataset when working with images collected at varying times and spatial resolutions. They are shown as feature classes on the map.
Show the image on the map—Uncheck this check box to improve performance if it is not necessary to immediately see your imagery or raster dataset.
Perspective imagery
Perspective imagery is usually oblique imagery collected at angles offset from vertical. You can display perspective imagery in image analysis mode, based on the image's coordinate system—columns and rows—rather than a map coordinate system. You can check the Set focus on the first operational perspective image layer to map check box to automatically work in the perspective view when an appropriate layer is added to a map.
Raster formats
This tab in the software shows a detailed table of the raster and imagery formats and file extensions that are currently supported.
Since the list of supported formats grows each version as new formats are supported, the table is not presented here. To see a condensed version of the formats that are supported, refer to Supported raster dataset file formats.
Enabling and disabling specific formats is not supported; all formats are enabled by default.
